MB-3DCars1.0 Add-On up to 1.1a -07/14/10 UP-
By misterblue · Jun 22, 2010in Hacks/Mods💬 108 posts👁️ 22,078 views
Page 4 of 5
Posted Jul 11, 2010 · 07:39 UTC#76
Will 3d cars work on the d3
No, all these mods are for the 'X' & 'F' series only!
Posted Jul 11, 2010 · 19:51 UTC#77
this add-on work with iGo8.3xx system (any system with minor adjustments...) :wink:
Posted Jul 12, 2010 · 19:33 UTC#78
ok thanks, is there anything cool like this you can do with the d3
Posted Jul 12, 2010 · 22:27 UTC#79
That question was already answered above. These mods will not work with the D3. I know this because my friend has one and he now has an X series so that it can be modded. I would suggest you to do the same as they are cheap now and with the mods, you will be having a system that is so much more
Posted Jul 13, 2010 · 07:17 UTC#80
in fact, to be precise, this add-on is compatible with all devices running iGo8.3xx with some small adjustments (not just AVIC X & F series).
Posted Jul 14, 2010 · 09:07 UTC#81
Update 07/14/10
This is the revision a of this add-on.
Why a revision ?! Well I recently encountered a problem when using the change of 3D vehicle and 3D size. I ended up with corrupted file sys.txt (empty) which results in a blockage of the AVIC on "Please wait, ...."
Although there have been several personal tests and some tests of beta testers, no one had encountered this problem. To remedy this so that you avoid this unpleasant time (especially on vacation!) I changed the timmings execution of certain parameters.
Fixed Vehicle 8 file was corrupted.
I take this opportunity to complete the function init. which can automatically add the parameters necessary for the operation of this add-on when you use a mod + file sys.txt other than MB-IDT3.0-4x
pack Install_MB-3DCars1.1a-AddOn.exe
Posted Jul 14, 2010 · 12:08 UTC#82
Does that mean thatl this .exe work on other mods that have the 3d cars installed? If not, can you tell me what parameters you have changed so that I can manually make the change? The only time that I ran into the startup mode problem is with car #8 which is now fixed, but you are saying that there is another problem that causes this as well?
Posted Jul 14, 2010 · 15:33 UTC#83
This has nothing to do with a bug in a vehicle file. I made that version .exe because I'm not home right now.
You must install this revision that improves overall functioning, is the simplest.
Edit :
The curious will have noticed that my version of this add-on Gurjon, contains fewer models than the version Dimka. This is normal, I chose to remove all the bogus models as well as those with no real texture or really without interest as "airbus, spacechip, mal, femal, dolphin, etc..."
Is a question of personal taste, I liked my version of the add-on is pretty handy :wink: I still kept some particular models for fun :mrgreen:
Posted Jul 16, 2010 · 04:09 UTC#84
MB, i changed last line of code in 3DCars/ui/3DCars_800_480.ui so that it reads "Cancel" instead of "Annuler"
Thought you might want to also..
Posted Jul 16, 2010 · 07:42 UTC#85
It'sa shame that nobody has reported this problem before, I will have it fixed!
This is already fixed for next version in preparation... Thank's Hube2002 :wink:
Posted Jul 16, 2010 · 15:21 UTC#86
Misterblue, what exactly is this new update supposed to prevent? I have thoroughly tested both variances (with my mod) using the June 27th files. I found no freezes or problems with this going through all changes, car change, size change (1-6), and had no problem. I tried your July 14th update and found no difference except that once, the system rebooted when I went from ipod to map, and then it was ok. However, with the June 27th file there was NEVER any problems, so, why the update? Did other people experience problems with the June 27th file? Now mind you, I am using different car files than you are and that may be the difference, but changing the car size has never been a problem with your earlier file.
Posted Jul 16, 2010 · 19:06 UTC#87
I decided to go a step further on this, while I was looking at the code I decided to change the text some more. Not that anything was wrong with it, just tinkering...One most people probable won't see was a message box the had the text "elapsed time waiting", I changed it to "Program Timed Out"
Pictures shows the rest..
I was just fooling around, trying to make the text match better with the function of the button
one thing I would like to change is the text from "No" to "Cancel" on the "Restart AVIC" screen above but I think it is in the mortscript and I don't know how to edit it.
Posted Jul 16, 2010 · 20:39 UTC#88
@ Hube2002 :
It is interesting, but you have to change the type of warning to each of my updates, since I created different messages. And as we say at home : "The flavors and colors, it does not argue!"
@ abb1 :
I do not know if what I write is well written. I have no other answer for you, one that is already in my message that contains this revision "a" is a little higher.
It appears you have not found what served the adjustment I made.
For the problem with the iPod, I do not see any link with my add-on?! for me there is none!!!
Adjustments of this review may not interfere in the functioning of the ipod.
This message is not directed at anyone in particular.
I recall that the principle of this add-on is to be "independent" of any mod (and can be adapted for other devices using iGo8.3), it should only be supported to operate. This allows for easy updates without replacing data.zip. That is how had developed Gurjon is way too that Dimka was kept by adding new models and this is how I decided to adapt it for AVIC without requiring users to use my mod, but so can use it with any other mod.
An update is an update. Nobody is obliged to do, but then did not come that you have a problem blocking your AVIC start (read about this update)
MB-3DCars1.2, in development.... but not come out until the end of the month and maybe a little later.
Posted Jul 16, 2010 · 23:05 UTC#89
@ abb1 :
Damn, I wish that I spoke french! I dont really understand this. There was no mention prior about a problem with an ipod, I have seen the adjustments you have made and exactly where you have made them. they are related to the car image size which you said in an earlier post caused the sys.txt file to be wiped out and caused the system to reboot. the reason that I posted my question was that I have fully tested your car mod under all circumstances before adding it to my mod and there were no problems with restarts except for the one car file. There may have been others but I replaced them all with newer files and had no problems.
What has an ipod got to do with that? I dont understand? there was no mention earlier that I could see with a problem with an ipod.......
Posted Jul 17, 2010 · 00:32 UTC#90
Damn, I wish that I spoke french! I dont really understand this.......
Me too....
@ Hube2002 :
Don't know what this means.....
Posted Jul 19, 2010 · 16:20 UTC#91
The language barrier is not easy, that's all!
Posted Jul 19, 2010 · 19:47 UTC#92
@ abb1 :
That is true, but can you please explain what the ipod has to do with your update. This was not mentioned in any post prior, and was just brought up here in a reply to my post. What has the ipod got to do with your update? That reply makes no sense to the english language. I know it is difficult, but can you please explain it, because nobody here has a clue what you mean at times, and before we install an update, we have to know what it is for. Thanks
Posted Jul 21, 2010 · 20:50 UTC#93
@ abb1 :
MB,
Look like that you have no problem to read english, so I can offer my service to translate from french to english. I guess you are using some web translators which are generally sucks, Google's included.
You can either PM me or directly post here in french.
Posted Jul 27, 2010 · 09:46 UTC#94
I found a 3Dcars with 210 models in it at http://www.igo8navigation.com/3dcars_210-t455.0.html;msg3361#msg3361 I don't know if it works, I can't install it at this time as I've no more space left after installing x3.1 and Abbs Chrome mod. Just thought I'd point out the find in case someone wants more car options.
Posted Jul 28, 2010 · 20:58 UTC#95
JrFaust, thank's for your contribution but this version of the add-on do not work on avic and contain a lot of application not necessary for to us.
I am preparing an update of my version and will contain all the interesting new model for the version you found.
please wait :wink:
Posted Aug 04, 2010 · 15:42 UTC#96
This might be a dumb question, and I looked thru the whole thread and cant seem to find anything regarding this, but I just need someone to verify if this works with the avic emulator or not?
I have been trying to intigrate this mod into diaftia's mod (yes I know abb1's mod already includes this) but I cant seem to get it to work in the emulator. When I hit the init button, or the scan button after I hit yes, it looks like it trys to reboot but instead it just hangs.
Ideas?
Posted Aug 04, 2010 · 16:37 UTC#97
I didn't manage to get it work neither in the Emulator ... when I press "Scan List", nothing happens.
Posted Aug 04, 2010 · 22:22 UTC#98
Chuck88 as indicated, some functions of this add-on as others do not work with the emulator, only a test directly on the AVIC allows the use of functions "Init.", "Scan List ", "Resize" and auto-restart.
Posted Sep 27, 2010 · 20:04 UTC#99
I have been trying to add this mod to mine and i get everything running and the selection screen comes up but no images of cars show and the scroll bar is dark. Any ideas of what i could be doing wrong. Please help. Thank you.
Posted Nov 07, 2010 · 04:47 UTC#100
I have a F900BT that has been upgraded to Ver 3.0201 with the 06-2010 Maps.
I have copied and replaced to Sys.txt file in the APL2\iGo Directory
I have copied the 3dCars Folder to the APL2\iGo Directory
I have rebooted the AVIC
I don't Vehicle Type option when I go to Navi Settings - Map Screens - 3D Settings
Have I missed a Step?
What do I need to do?
Can anyone help
Tx
Page 4 of 5
