Chuck88's Mod v3.4b with Pioneer FW 4.0 and Primo 2.0 - Updated 2013-04-13
By Chuck88 · Nov 09, 2010in Completed Mods/Themes💬 851 posts👁️ 212,464 views
Page 13 of 35
Posted Apr 19, 2011 · 18:11 UTC#301
I went out and replaced the sys.txt with yours but it still reverts back. i turned off the smart zoom which seems to show more sky. that seems to be ok, the 3d car worked too. thanks chuck
Posted Apr 19, 2011 · 19:25 UTC#302
You should be able to save the smartzoom tilt settings. Did you try to delete the User\UserData\igo folder and restart? It might be a left-over problem from another mod.
Posted Apr 19, 2011 · 23:24 UTC#303
hi chuck. just tried this and still wont save my settings.
Posted Apr 20, 2011 · 01:14 UTC#304
I am so sorry my friend, I've put the wrong SYS.txt in the release. I changed it since the implementation of the modifiable smartzoom parameters version, BUT ONLY IN MY AVIC!!!
Abb is going to laugh at me, he will argue that nobody uses smartzoom since nobody has reported this issue :lol: ... or everybody is happy with my personal settings built into the SYS.txt.
So here it is, the SYS.txt that enables you to modify and save the smartzoom settings.
Sorry again!
UPDATED SYS.TXT, please replace the one that you have under "\My Flash Disk\APL2\iGo".
SYS.TXT
Edited Apr 20, 2011 by Chuck88
Posted Apr 20, 2011 · 03:41 UTC#305
Works like a charm now!! appreciate all the help and fast responses. great looking out for. this is the first mod I've added to the unit and i find i am rediscovering the joys of the unit. Thanks again Chuck.
Posted Apr 20, 2011 · 12:08 UTC#306
Glad that I was helpful and thank you for your support. ;-)
Posted Apr 23, 2011 · 14:38 UTC#307
Hey Chuck running your new update and love it for the most part. a few things i would recommend modifying of without sounding disrespectful would be the the contacts image should be changed i think that takes away from the unit looking professional, another thing i noticed was the the street signs changed to blue verses when they used to be green. also the street signs got smaller and harder to read i would recommend changing those back to a larger font or at least create a setting that allows the user to Change them to their choice. But those are just my opinions, I'm grateful for what you have produced already.
Posted Apr 23, 2011 · 23:15 UTC#308
Thank you for your comments. :razz:
1) For the contact image, you can edit or change the following files (compressed within Images.res):
You can also revert to another Theme in this forum by swapping the Images.res. Search with this keyword "Images.res" or "Theme". It is saved under "My Flash Disk\APL".
2) EDITED: You have to select Map Preference "US" under Regional Settings.
3) Highway signs: I have no plan to make the signs larger at this time as it will cover pretty much the whole screen during navigation (too crowded). I will see if I can have other ideas at a later time.
Upcoming update is coming its way ...
Edited May 17, 2011 by Chuck88
Posted Apr 24, 2011 · 15:02 UTC#309
I will just wait until you fix it. and possibly one day you will change the contact image if not i will just have to live with it
2) I made a mistake by associating Miles/hours with Blue highway panels. I will correct that in the upcoming update. In the meantime, you can the file laneinfo_signpost_eu.ini identical to laneinfo_signpost.ini at "ui_pioneer\common", within the DATA.zip.
Posted Apr 25, 2011 · 19:48 UTC#310
Answer to point 2) edited and reposted above.
Posted May 02, 2011 · 05:21 UTC#311
bonjour,
merci chuck pour ton mod.
rendez vous avec motte et bandit972 pour les nouvelles mise a jour. :mrgreen:
continue comme ça :lol:
Posted May 05, 2011 · 15:27 UTC#312
Switching from your rival's mod package as I get no Nav audio. Now, while I installed following the instructions, none of the buttons work, hence the unit is unuseable.
Do I need to reload 3.1 and format or is there a shorter way to accomplish this.
Thanks in advance.
Posted May 05, 2011 · 17:04 UTC#313
Thanks in advance.
Well, first of all, there is no such thing as RIVAL's MOD in this forum, as nobody charge anything for the mods, so there is no rivality between modders. You select the one based on your personal preferences. We are here to contribute to the community, there is all. Lot of modders are gone partly because lack of appreciation, not necessary monetary, in my case all I want is "thank you for your efforts", but still, very few did that. <_<
As for your problem, I think that it is not related to the MODs, you should reset the configuration of the WinCE (saved under "\My Flash Disk\User"), but unfortunately, I don't know how to do it without reloading FW 3.0x. Perphaps, may I suggest to selectively delete configuration files (or RENAME THEM is safer) before wipping the whole Flash out. Yeah, that's a time consuming process ... :mrgreen:
Remember, there is no FW 3.1!
Posted May 09, 2011 · 02:15 UTC#314
Well, first of all, there is no such thing as RIVAL's MOD in this forum, as nobody charge anything for the mods, so there is no rivalry between modders. You select the one based on your personal preferences. We are here to contribute to the community, there is all. Lot of modders are gone partly because lack of appreciation, not necessary monetary, in my case all I want is "thank you for your efforts", but still, very few did that. <_<
As for your problem, I think that it is not related to the MODs, you should reset the configuration of the WinCE (saved under "\My Flash Disk\User"), but unfortunately, I don't know how to do it without reloading FW 3.0x. Perhaps, may I suggest to selectively delete configuration files (or RENAME THEM is safer) before wiping the whole Flash out. Yeah, that's a time consuming process ... :mrgreen:
Chuck. I stand corrected and happily so. Thanks for the reply and support. I suspected that there might be an issue with the version, but being new, I have little confidence.
I do know that the unit was near brick status and doing the 3.x install was key to making it work again and the key to the mod kingdom, which made my thoughts of reverting to that procedure logical. I will try to do as you suggested.
Again, thanks. Mike
Edited May 09, 2011 by whalepirot
Posted May 10, 2011 · 02:18 UTC#315
Mod v3.1 released!
Please see installation instruction at the end of first post. If you are upgrading from v3.0, simply replace DATA.zip and SYS.txt.
Download Chuck88’s Mod v3.1: Faster, simpler and better ... now with SmartTrack!
Chuck88's iGo Nav Mod v3.1.zip
Chuck88's Packaged WinCE 5.0 Emulator for PC
Posted May 10, 2011 · 02:34 UTC#316
Mod v3.1 released!
This could be very well my last version, unless there is major bug, which is very unlikely.
This forum is losing momentum, and it is no longer like it has once been. People is still downloading a lot, but no one care to involve anymore. :roll:
Good lucks to every one!
Edited May 10, 2011 by Chuck88
Posted May 10, 2011 · 17:52 UTC#317
Chuck
Thanks so much for your latest work.I am afraid you may be right regarding the forum.I really hope the forum can get back to where it once was but now mainstays like Abb seem to have gone I really fear the worst.I really would like to pass on my appreciation to you and the other mods and wish you all the best for the future.
Posted May 10, 2011 · 21:09 UTC#318
Thanks Ovalball for always been there to encourage modders of this forum. Your support is greatly appreciated! :rolleyes:
Posted May 10, 2011 · 23:59 UTC#319
Looks great Chuck! Gave it a whirl today and am impressed, especially at the "SmartTrack" feature (I prefer 2d over 3d). I had been a long time user of Diaftia's mods and although I do miss some of his features/interface I think I will stick with yours for now. A few questions, is it possible to customize the zoom level/speed on SmartTrack? If I could get it to zoom out even further at higher speeds then there would be no need for the overview mode (while driving south it is difficult to see what is ahead). Also, what do you mean by "True LCD backlight OFF during "Screen OFF" function (from the map screen)"? I do not see an option for "Screen off" on the map screen, only in the menu screen. Sorry to hear this may be your last mod, it is a very good one and I like what you did with the autozoom and icon menus (took awhile to figure out before learning they are identified via text by pushing the menu icons twice).
Posted May 11, 2011 · 01:20 UTC#320
Sorry for not being explicit for the pushing twice icons. I didn't put the instruction in the first thread. :oops:
The SCREEN OFF function is brought up by touching the START BUTTON on the lower left corner, then pushing the icon right above the EXIT button. From there if you push the lower left corner, it will totally turning OFF your screen, including the Bluetooth blue LED ... 3 pushings!
As for the level/speed customization, I didn't have time to do that and I just, before v3.1 release, felt that there is no interest from this forum, despite some 150 downloads of v3.0 within the first month. I am not sure yet, but if I have spare time I will probably do it for myself in the future, and if so will eventually post it or send you a copy of the modified files (don't interpret this as a promise though). If you want to customize the feature in the meantime, please refer to the beginning of the navigatemap.ui file, everything are there, but hard coded.
Enjoy it, as I do everyday. The SmartTrack feature is especially useful during normal driving, or during navigation for the route that you already known (i.e. you don't need to see closely on turns), by turning OFF the "During Navigation" feature and by leaving "2D Normal Driving" at YES.
Edited May 11, 2011 by Chuck88
Posted May 11, 2011 · 02:16 UTC#321
Thanks for this updated v3.1 mod. This one rocks with the smarttrack feature! You can also turn the lcd screen off by pressing the 1st icon on the top left corner if you have the earth icons on. Then, hit the bottom left. That'll just take two steps.
It's a shame that our forum is dwindling and talented mods are leaving, like yourself. I really enjoyed your mods and wish you the best of luck. I'll continue to use your mods until you return someday....
Posted May 11, 2011 · 02:49 UTC#322
Thanks kluong6, that pleased me. :rolleyes:
Oh yes, I forgot you have enabled the top icons bar on your deck.
Cheers!
Posted May 11, 2011 · 09:25 UTC#323
merci chuck pour le travaille effectuer,je vais essayer la mise a jour 3.1.
RDV peut etre avec MOTTE et BANDIT972 :smile:
bonne route pour la suite de nos avic.
nico
Posted May 11, 2011 · 18:18 UTC#324
I would also like to thank the super mod. THANK YOU Pat. P.S. I firmly believe that this is not your last work!!
Posted May 16, 2011 · 19:56 UTC#325
Just got around to trying out your latest....Awesome MOD! Thanks a lot!!! :-)
Page 13 of 35
