Chuck88's Mod v3.4b with Pioneer FW 4.0 and Primo 2.0 - Updated 2013-04-13
By Chuck88 · Nov 09, 2010in Completed Mods/Themes💬 851 posts👁️ 212,464 views
Page 15 of 35
Posted May 21, 2011 · 16:08 UTC#351
Yes same issue also
Problem fixed! I will update this in the next released.
Posted May 21, 2011 · 16:17 UTC#352
No error message, it'll just take me to the maps screen.
There's recently been a ramdisk memory release. I wonder what you thought of it? http://forum.mobilism.org/viewtopic.php?f=49&t=187595, more info http://www.amv007.narod.ru/en/index.html
The Navi_Settings problem has been fixed and will be post in the upcoming update. You can still access it with v3.1 by using on map screen icon.
The RAM disk is not working in my Emulator, and I didn't venture into my AVIC.
Anybody has tried running the ramdisk_ppc.exe under AVIC to create a RAM disk?
Posted May 21, 2011 · 16:23 UTC#353
Great, we'll be waiting for the next.
Posted May 21, 2011 · 16:53 UTC#354
Hey Chuck,how does it feel to be carrying the whole forum on your shoulders my friend?Maybe we should rename the place Chuck411 :D
Posted May 21, 2011 · 18:17 UTC#355
I tried loading on the emulater which it was able to open the file, but haven't tried running it on the avic.
yeah chuck, you're definitely moving up on the avic411 elite moders.
Posted May 22, 2011 · 03:33 UTC#356
Hey ovalball, you must be kidding :unsure: .
I just hope that one day diaftia and abb1 will return for the sake of this forum, but if they don't, I guess that is OK and I can certainly understand that, they've done their part to this forum, and largely. With this being said, and unfortunately, I am also counting my days in this forum too. :shock:
You know I am very very proud of my achievement on the creation of Chuck88's SmartTrack feature of my own, and I like it so much that I no longer use the original iGo SmartZoom, especially in 2D driving/navigating (the transition will be smoothing on the next update). But like the chinese proverb says, every good thing has an end. So I just hope that somebody, or many of them will eventually pop in, take our mods and then continue modding. B)
Best regards!
Edited May 22, 2011 by Chuck88
Posted May 22, 2011 · 03:48 UTC#357
Hey Chuck I haven't been around for awhile but I love the things you have come up with in your theme. I was trying it out on my Wife's Deck which is a carbon copy of my flach disk. seems to just reload and reboot I then took tried the WINCE and remove her maps and replaced with yours and it works great on WINCE. I think it has to do with my maps being IntegrationVersion 03.000000 Base Contents 20100120R3 and your IntegrationVersion 02.000500 Base Contents: 20090509R3. I really would ahte to downgrade all my maps to work on this. Is there any way you can help me out getting this to work.
Number1Guru
Posted May 23, 2011 · 03:41 UTC#358
Number1Guru
Hummm, my mod shouldn't have anything to do with the map versions. Is it however possible that you don't have the valid license or the EZRider.exe. I would have to check ... in the meantime please try other combinasons if you could.
Posted May 25, 2011 · 10:01 UTC#359
bonjour,
@chuck comment fait on pour avoir les panneaux d'autoroute en vert,sachant que je n'ai pas de dossier uipionneer dans APL2 et que mon avic et en version US dans paramètre régional.
et dans le paramètre custom setting fade pourcentage on ne peut pas régler le pourcentage;pour ma part il reste a 100% peut être un bug
merci pour la réponse
bonne journée
nico
Posted May 25, 2011 · 12:38 UTC#360
Nico,
Pour le pourcentage, tu dois sélectionner la première option à ICONS.
Pour les panneaux en vert, c'est tout ce que tu as à faire comme décrit, je ne vois pas autre chose qu'on restarting de ton AVIC après avoir sélectionné US.
P.S.: Pas de dossier ui_pioneer dans APL2\iGo, et non pas dans APL2. :rolleyes:
Ciao!
Edited May 25, 2011 by Chuck88
Posted May 25, 2011 · 21:12 UTC#361
Hi Chuck.Heading off to France for a 2 week tour.Looking forward to seeing how smart track performs.Will be logging on via wi fi to see if you have added/changed anything.Thanks again for all your fine work.
Posted May 25, 2011 · 21:28 UTC#362
Ovalball,
I will send you a PM.
Have a safe trip to France!
Edited May 26, 2011 by Chuck88
Posted May 25, 2011 · 23:25 UTC#363
Chuck;
I have the Altitude fix E-Rider. the license is global
Posted May 26, 2011 · 01:02 UTC#364
Chuck;
I suggest to load my WinCE 5.0 Emulator in your PC, in which my mod v3.0 was included, as well as EzRider.exe and appropiate license files (read the simple instructions in that thread), just add one of your maps to the Emulator. If my v3.0 works in your PC, just take everything under APL2\iGo and copy them to your AVIC, that should work well. From there, replace v3.0 by v3.1.
WinCE 5.0 Emulator
Good lucks!
Posted May 26, 2011 · 02:52 UTC#365
WinCE 5.0 Emulator
Good lucks!
Ok the WINCE 5.0 Emulator Worked, I then copied over your 3.1 on that and my map, pio, Buildin Files. Does the 3.1 have the Telephone Fix , and Nav Nag screen about don't operate vehicle or whatever it says. I have the Video fix and I also need the Elevation to read actual Feet not miles. since I am above 8700' almost all the time
Posted May 26, 2011 · 11:56 UTC#366
v3.1 has all the fixes except the Elevation fix, which is from the EzRider.exe. Once it is working with your setup, just replace the EzRider.exe to have the Elevation fix.
Don't forget to update the DATA.zip with the one from v3.1, because the one included in the Emulator is v3.0.
Posted May 26, 2011 · 18:49 UTC#367
bonsoir,
je n'arrive toujours pas a avoir les panneaux vert d'autoroute :angry:
Posted May 26, 2011 · 19:38 UTC#368
bonsoir,
Nico, tu as fait cela? Suggestion
PAS DE UI_PIONEER sous APL2\iGo, si cela ne marche toujours pas, dis-moi quelle version tu as, regarder sous l'écran ScreenOFF.
Posted May 26, 2011 · 22:46 UTC#369
I got everything working Awesome including my Blue Theme with this version Chuck; Thank you I do however have issue with EZRider elavation fix it still shows up as .9 Miles instead of the Actual Feet, although if I go into GPS it tells me the Actual feet of 4856'
Posted May 27, 2011 · 05:11 UTC#370
Good to know. For the elevation fix, you have to go to diaftia's thread and download the correct EzRider.exe.
Posted May 27, 2011 · 08:57 UTC#371
bonjour chuck,
je n'ai pas de UI_PIONEER sous APL2\iGO
j'ai mis la dernière en date 3.1
merci,bonne journée
nico
Edited May 27, 2011 by bsm58
Posted May 27, 2011 · 15:21 UTC#372
Nico, je ne sais pas comment t'aider!
Si tu regardes à l'intérieur du DATA.zip, tu trouverais sous ui_pioneer\common deux fichiers, l'un laneinfo_signpost.ini et l'autre laneinfo_signpost_eu.ini. Tout dépend sur ton setting de "Map Preference" sur US ou UK, le système chargera l'un ou l'autre fichier.
La seule différence est au niveau de RGB, donc la version US a RGB(0,97,19), et la version UK a RGB(0,112,255). Ouvre les fichiers et tu pourras la constater toi-même.
Tu peux à ce point par contre extraire le fichier laneinfo_signpost.ini et de renommer laneinfo_signpost_eu.ini, créer un folder ui_pioneer\common sous iGo et placer ce fichier dedans, et redémarrer. Comme ça il n'aura plus de fichier qui change de couleur à bleu (toujours vert).
Posted May 27, 2011 · 15:30 UTC#373
Well I done what you said the elevation fix works great except on the 3d map screen it shows up in miles.
Posted May 27, 2011 · 16:29 UTC#374
@chuck merci pour ta reponse,je vais essayer ça
nico
Posted May 27, 2011 · 22:18 UTC#375
pourquoi tu ve des pannneaux verts??? les panneaux aitoroute sont bleu...le vert ce sont les departementales...
Page 15 of 35
