Chuck88's Mod v3.4b with Pioneer FW 4.0 and Primo 2.0 - Updated 2013-04-13
By Chuck88 · Nov 09, 2010in Completed Mods/Themes💬 851 posts👁️ 212,464 views
Page 14 of 35
Posted May 17, 2011 · 00:16 UTC#326
Hey Chuck on your latest built the map signs never changed back green
Posted May 17, 2011 · 00:54 UTC#327
Are you talking about the highway signs. I have Navi Settings->Regional Settings->Map Preference set to US, and it is always green. If you change it to either US (green)/UK (blue), you have to exit this screen, then reboot your AVIC.
Oh yes, just in case you have it modified, make sure that neither the file "ui_pioneer\common\laneinfo_signpost.ini" nor "ui_pioneer\common\laneinfo_signpost_eu.ini" is presented outside the DATA.zip file.
If you compare both files (extracted from DATA.zip), you should see ONLY the RGB values are different.
Let me know.
Edited May 17, 2011 by Chuck88
Posted May 17, 2011 · 01:01 UTC#328
Anybody else in the US/CANADA has this issue, the highway signs in BLUE?
bigben10687, see the above post ...
Posted May 17, 2011 · 02:00 UTC#329
Mine's still green. No issues here with us maps.
Posted May 17, 2011 · 12:31 UTC#330
I never modified anything because I dont know how to, but if you recall on your previous build you mentioned that you knew the maps was blue and it was something that you would revert back to green in your upcoming update
Posted May 17, 2011 · 13:56 UTC#331
On my previous post, I just forgot that there is a setting and I updated it since then. Please reread it here: Edited Post.
If still not working, I would delete the configuration folder under "\My Flash Disk\User\UserData\iGo" in TestMode v2.3, and restart the AVIC.
Posted May 17, 2011 · 22:43 UTC#332
Thanks Chuck -- Installed on my x910bt last night, so far works great!
Posted May 18, 2011 · 01:05 UTC#333
You're welcome! Glad that you like it. :rolleyes:
Edited May 18, 2011 by Chuck88
Posted May 18, 2011 · 02:45 UTC#334
Thanks for this updated v3.1 mod. This one rocks with the smarttrack feature! You can also turn the lcd screen off by pressing the 1st icon on the top left corner if you have the earth icons on. Then, hit the bottom left. That'll just take two steps.
It's a shame that our forum is dwindling and talented mods are leaving, like yourself. I really enjoyed your mods and wish you the best of luck. I'll continue to use your mods until you return someday....
Well, I am still here ... in fact, I am working to smooth the SmartTrack map level changing, instead of setting the next level right away with huge step, it will gradually smooth down to it. Work great on my AVIC now, I will do more testing before releasing it because the algorithm behind it is fairly complicate, especially when navigation is ON, so stay tuned.
Posted May 18, 2011 · 11:14 UTC#335
Hey Chuck,great news you haven't gone into retirement just yet!!Always look forward to seeing your work,you should be very proud of your efforts.
Posted May 18, 2011 · 14:09 UTC#336
It has been more than a year that I am around and contribute to the community, but eventually someone has to pickup the works and continue the tradition. I am doing less and less modding to the iGo software these days, because of the lack of time, and also in part, the lack of interest of all those downloaders but NOT subscribers.
You can expect that my next update to greatly improve my SmartTrack feature would be the final update.
Oh yeah, I have to thank you ovalball, I enjoy very much your company around this forum. :rolleyes:
Posted May 19, 2011 · 01:56 UTC#337
Excellent! We will be more than glad to test or let you know with the next release. I have avic411/mods on my favorite, so I'm usually on here twice a day, sometimes more. Welcome back.
Posted May 19, 2011 · 13:09 UTC#338
Hey I went through the setting you said but didnt see a configuration folder
Posted May 19, 2011 · 17:38 UTC#339
The configuration folder is \My Flash Disk\User\UserData\iGo, so go to \My Flash Disk\User\UserData and delete the iGo folder.
Posted May 19, 2011 · 19:43 UTC#340
I just deleted that folder but the signs are still blue, that is a blue screen frame with the freeway name in green is that how you wanted it or is the sign suppose to be green?
Posted May 19, 2011 · 20:29 UTC#341
Did you change the Regional Settings->Map Preference back to "US"? US is green frame and UK is blue frame.
On my first post of this thread, you can see in the middle of the bunch of images, one of them are showing two highway signs in GREEN.
Let me know.
Edited May 19, 2011 by Chuck88
Posted May 19, 2011 · 20:32 UTC#342
Yes I did check and its selected as us and it has been like this since your last 2 builds
Posted May 19, 2011 · 22:50 UTC#343
Yeah, I think I know what it is ... it is a left-over from a previous build v2.8x, and you've unknowingly put the file under it (laneinfo_xxxx.yyy), which was a patch for the european users.
Please delete the folder named "ui_pioneer" under "\My Flash Disk\APL2\iGo", and bingo!
Posted May 19, 2011 · 23:10 UTC#344
That was it, thanks I million
Posted May 19, 2011 · 23:13 UTC#345
Cool! :cool:
Posted May 20, 2011 · 18:26 UTC#346
There seems to be some glitch when I press the menu button, then settings, then navi settings. It'll take me back to the maps screen instead of the actual navi settings screen.
Posted May 20, 2011 · 19:19 UTC#347
I can't check that in the emulator, so I will check with my AVIC later on.
When you press the "Navi Settings" button, the built-in script of AVIC, not under my control, is calling an iGo script for that matter, so I don't know what was called.
Any error message?
Anybody else can confirm this problem?
Edited May 20, 2011 by Chuck88
Posted May 21, 2011 · 11:01 UTC#348
Any error message?
No error message, it'll just take me to the maps screen.
There's recently been a ramdisk memory release. I wonder what you thought of it? http://forum.mobilism.org/viewtopic.php?f=49&t=187595, more info http://www.amv007.narod.ru/en/index.html
Edited May 21, 2011 by kluong6
Posted May 21, 2011 · 13:23 UTC#349
In fact, it will take you back to the last STATE screen of the iGo navigation software, the one before you swithch to the MAIN MENU. I will check that. Thanks.
For the RAMDISK, I will read that too.
Posted May 21, 2011 · 13:35 UTC#350
Yes same issue also
Page 14 of 35
