Motte, note que j'ai inscrit ton nom dans la page BLANK SCREEN pour ta contribution.
Merci pour le hint. A+.
chuck,Thank you
chuck,Thank you
Hi Chuck88.
Thanks for your great work . just one question where can i find mapchanger button.
Hi Chuck88.
Hi Bigboy,
I am sorry
but I think that I forgot to put the map changer back in my latest mode. I will add it shortly (tomorrow).
More than 100 downloads and you are the only one who has found it
. Great feedback!
Please check back tomorrow!
Chuck.
Hey Chuck -
Mod is awesome, I really really like what you have done with it. I'm a fan of smartzoom, so I've been running an older ABB mod for many many months.
So a question about this one, seems I'm one of the few that likes the top-menu buttons - I really like the single press to get to my quickest items. So in past mods, there was a shortcut on the top-menu to flip directly from 3d/2d/2d-N. In this one it seems to have disappeared, and looks like it was replaced with the MSN button (again, I use this one daily, MSN traffic works great here).
So 2 questions I guess:
First, any way to put the 3d/2d/2d-N button back - maybe replace the power button? I know I can get to 3d/2d/2N fast with a couple presses using the Map Browser, just not when I choose the icons.
Second, with the auto-fading bar turned on, I don't seem to be able to select the percentage.
Or am I overlooking something on both?
Thanks again to you and the other modders for keeping this forum rolling. If you have a Paypal account, pass it along.
Cheers.
Thanks for your kind words. I am really glad that you do like it; this makes me feel good!
As for the PayPal account, I don't think that I deserve it yet, I just want to share with others. Thanks for your thoughts anyway. ![]()
Don't worry for the 2D/2DN/3D thing, you can simply press the compass to get the map changes, yeah it is that simple! Here are the description of on-map items and their respective functions:
If I didn't read your post tonight, the MSN/TMC button on the top bar will be replaced by something else, since I don't have it with my X710BT unit ... lucky you!
As for the fading percentage, you would have to get into the Custom Menu, select "Icons", then enable the "Auto Fading Bar", now you should be able to toggle the percentage from 100% to 25%. If not, let me know the version number that you are using.
Normal driving:
Navigation:
If I don't hear from you for the percentage issue the latest tomorrow, I will post minor update v2.80e shortly (put back the map changer).
Cheers!
Chuck.
Weird. I knew where the fading was to toggle, but last night it was staying greyed out even with the icons on. This morning no issues. Maybe I got something whacked by doing all the mad-clicking trying out all the new stuff. Either way, that part is resolved.
I see I also overlooked tapping the compass to change map view in the instructions, thanks for the reminder.
One last thing that I wanted to ask (beside still wanting a paypal), and that is about the colors on the POI search screen with the keyboard. Is there any way to make the fade a little darker? It's pretty hard to read as the character colors kindof disappear into the fade. See this thread for an example:
I believe that you have caught a bug for the fading %. If you could reproduce it systematically, pleaes do let me know so it will get fixed.
As for the Chrome background for the keyboard entry, I would have to check for the BMP as it is from Abb's original mod. Maybe Abb could shed somelight on the name of the BMP (i.e. I guess we don't might to having a black background for the text entry field).
Later!
Mod v2.8e is up! Add "Map Changer" to the Applications Quick Menu.
Enjoy!
Still running the mod from yesterday (2.8d), but ran into an issue tonight with the 3dcars. I picked a random car (blue is all I remember), prompt then avic rebooted, and now it reboots as soon as I get to the map screen, over and over. If it boots to the Main Menu it's fine until I hit the map button. I replaced the data.zip, sys.txt, replaced the entire 3dcars folder again, and cleared all the userdata, but the reboots are still going. Can you tell me where the pointer is to the cars so I know which file I might need to edit/replace?
This is a generic problem with 3DCars addon. It appears that not all the cars have been tested by the original modder, which lead to this problem (not only my mod, but any mod in this forum running 3DCars addon). It is a matter of try-and-error. For myself, I'd choosen the Hummer to represent my SUV, and it works, and that's it!
For your problem, all you have to do is boot into Testmode v2.3 (for FW 3.x), delete the folder \My Flash Disk\User\UserData\igo, and reboot. This has nothing to do with DATA.ZIP or SYS.TXT, it is with the embedded car image from the 3DCars external addon, whose selection should be stored in that folder. You would have to setup again your personal preference afterward.
Good lucks!
Good lucks!
Weird definitely not in UserData, I know that I had that deleted before since it seemed the obvious place and just did the same again. Tried with no userdata, no userdata + 3dcar folder gone, tried replacing userdata with a backup copy I had - all no dice. I was finally able to get it working by changing settings to default on a reboot that didn't go to map. Either way I'm back up and rolling now with the arrow which is just fine. I have a blue tundra so nothing in 3dcars close to it anyway, so all good. Thanks again Chuck. You need paypal. ![]()
The only way to fix this is that we HAVE to know what car it was that was loaded and then we have to delete it or fix it. So please, when changing any cars, remember which one it was so that we will know which ones are duds. These cars were created by russian modders for entirely different GPS systems, so there may be a couple that do not work. I tested out about 75% of them and only ran into one dud which was car #8 and that is now fixed. I didn't test them all though as it is very time consuming ![]()
It is indeed! Abb how about setting up a thread to poll from users as on which car works and which doesn't?
So you will eventually have a bug-free version of the 3D car ![]()
Hello,
I tested all the cars of the version of MIsterblue they work all ![]()
Motte
Not a bad idea, but there are 93 possibilities, and that is a lot. When MisterBlue first incorporated this mod, there wereseveral cars that were not working. I did a search on some of the russian sites and I found updated replacements, so that is why a lot of mine now work. I spent three days testing about 40-50 cars which took a while with the constant reboots and all that I tested were ok, however, some of the ones that I missed may be duds. That is why I need to know which ones they are. One post was complaining about a jeep that caused the reboot, but I tested all the jeep looking vehicles and they were all ok, then it was said that he couldnt remember the exact file. It is very important to remember what car is used in case it is a dud. I got a feeling that it is just ONE vehicle that is kinda in the background that is causing these problems, I just need to know exactly which it is.
Hello,
Motte
NOT when he first posted it they werent, just look back at the threads. He probably did the same thing that I did and installed the updated .mdl files in a later release.
Hey Motte, is this the case?
If so, can you provide link to MB's bug-free 3DCars?
Thanks.
Sorry,
Consult his site or write him it mp
Motte
whoopidoo2,
If you are looking for the entry field of the POI search, here is the bmp to replace: inside the DATA.zip\ui_pionner\800_480\746_32K_MN-050_24b.bmp. Instead of updating the DATA.ZIP, you can extract the bmp from Pioneer's original iGo DATA.ZIP, which is blue, and save it under \My Flash Disk\APL2\iGo\ui_pioneer\800_480.
For myself, I just remove the BMP from my code in templates_800_480.ui, like this:
;<template xinputfield bmp="746_32K_MN-050_24b.bmp" x=2 y=66 z=5> <template xinputfield bmp="" x=2 y=66 z=5>
Happy modding!
Sorry I've been gone for a couple of days - I will try that later today, and THANKS for digging it up!
Can't download this mod?
This is what I get:
The file link that you requested is not valid.
This is what I get:
Hummmmm, within my 4shared account, even myself can't download it ... must be a bug or my account was blacklist.
Reuploaded and seems to be fine now!
Enjoy!
This worked. Thanks!!!
newbie here...I followed instructions exactly and everything works great except I do not have any themes. A few of the the new themes are listed, but the map is still standard regardless of which theme I pick. Where did I go wrong?
I assume that you are talking about SCHEME, and not THEME. For theme, you have to change the IMAGE.res in the \My Flash Disk\APL.
So for schemes, you would have to copy all schemes (*.zip files) to \My Flash Disk\APL2\iGo\CONTENT\Schemes. What do you see in this folder?
Let me know if my understanding is wrong or provide more info.
