Chuck88's Mod v3.4b with Pioneer FW 4.0 and Primo 2.0 - Updated 2013-04-13
By Chuck88 · Nov 09, 2010in Completed Mods/Themes💬 851 posts👁️ 212,464 views
Page 9 of 35
Posted Feb 09, 2011 · 23:15 UTC#201
Oh and 1 more thing, that emulator that Chuck was helping me with in earlier post might be a good idea too. Keeps you from running back and forth to you car when modding. Unfortunately I haven't been able to get it up and running yet ( help anyone? ) so I can't give you a step by step on that one.
Who knew customer service would be so great and that help plenty on the back up portion hopefully the modding goes smoothly also. Also will my steering controls work with a modded software?
Posted Feb 09, 2011 · 23:32 UTC#202
I have read about that on here somewhere, I do believe you will have to buy something that you connect to your unit to get it to work. As I don't have them I didn't pay much attention. Try searching.
Posted Feb 09, 2011 · 23:41 UTC#203
Steering wheel controls are not software specific. If you have the unit that convert your steering wheel controls to "wired remote" control for the factory software, it will continue to work the same way.
Posted Feb 09, 2011 · 23:54 UTC#204
So you saying if my car currently have steering wheel controls working with current non modded software then when I put the modded software on the unit it will still have functionality
Posted Feb 10, 2011 · 00:39 UTC#205
It absolutely should. to add steering wheel controls to an aftermarket stereo, you need a control box like the PAC or AXXESS units. These controls you the remote control input and connect that to your steering wheel.
Who installed your unit?
Posted Feb 10, 2011 · 00:42 UTC#206
CAR TOYS
Posted Feb 10, 2011 · 02:06 UTC#207
CAR TOYS
Yes, for sure it will still work after you install any of the mods available.
Posted Feb 10, 2011 · 02:07 UTC#208
What was the problem that you've encountered?
Posted Feb 10, 2011 · 02:24 UTC#209
I loaded all of the files, had to download and install virtual pc to instal the mobil 5.0 (if I'm remembering correctly) then copy and pasted the text it told me to and double clicked on the icon (Pioneer " " ") and I got a quick dos window then nothing. I just recently had to reinstall windows 7 on my MacBook pro so everything was wiped out. But that's the OS I'm using. Windows 7 Ultimate (specifically).
Posted Feb 10, 2011 · 03:56 UTC#210
Where do you find the icon Pioneer " " "? You have to double-click on the batch file RUN_AVIC.bat to start the Emulator. My batch file has the following contents, please change to suite your configuration:
"C:\Program Files\Microsoft Device Emulator\1.0\deviceemulator.exe" /video 800x480x16 /memsize 256 /c nk.bin /sharedfolder "D:\!Personal Folders\My Temp\My Flash Disk\APL2\iGo"
Create the CONTENT\map folder, only put one file to it, the one *.FBL file for your region. Delete the basemap.fbl file.
Make sure that you put appropriate license files in LICENSE.
Don't forget to put the hacked EZRIDER.EXE to use map. Then the DATA.ZIP and the SYS.TXT files. After all that, double click on EZRIDER.EXE to start iGo Nav.
Edited Feb 10, 2011 by Chuck88
Posted Feb 10, 2011 · 04:09 UTC#211
Hmmm,
In the first download I got from the wiki section it instructed me to create a new text file with the text I copy and pasted, that in turn created the icon on my desktop that I tried to describe. When that didn't end up working I went back and downloaded from the rapidshare link you had posted for the other forum member and I think most of the changes you mentioned were already done ( basemap deleted, one map in the folder ect. ) the one thing I know for sure I didn't do is change the license and EZrider. Maybe that's my problem.
Posted Feb 10, 2011 · 05:36 UTC#212
I just read the instructions and is a bit lost on getting started ......this will me my first time using your software so am I using testmode or another method next question do I delete the whole disk drive or do I open the drive the select all the delete
Posted Feb 10, 2011 · 06:22 UTC#213
For Chuck's mod you need to first downlod it and extract the files to and empty sd card ( just to make it easier ) you also want to put that test mode (V2.3) folder on there as well. Having the test mode folder on your sd card allows you to boot into that windows screen where you see " My Device", you'll need to double click on that and you will see all of the folders that you will be altering. If you want you can open Chuck's zip once you've downloaded it to see what's inside. The same files he provides you wit will also be inside of you "My Flash Disk" (which hopefully you've backed up) and you just REPLACE/OVERWRITE what is on your unit with the files Chuck gives you. DO NOT DELETE. that will be when you start to run in to freezes, reboots, and blackouts.
Good luck and let me know if I can help any further. :)
Posted Feb 10, 2011 · 13:10 UTC#214
Hmmm,
Silly question, just want to make sure: did you install the Microsoft Windows CE 5.0 Emulator by executing this file: standalone_emulator_V1.exe?
Posted Feb 10, 2011 · 15:28 UTC#215
I believe I already done something wrong basically so far what I done was download the chuck files move them to the sd card along with testmode then placed the sd card in my nav cut on my car once the nav entered testmode I went to my sd drive and selected everything but testmode and selected edit copy then went to my drive and without going to specific folders selected edit paste then process never overwritted anything just added the files which took 3 minutes.... So how do I undo what I just did and insall files the.correct way?
Posted Feb 10, 2011 · 17:36 UTC#216
You would have to identify the unspecific folder that you have dropped files to and cut all those files (see original ZIP archive for reference), then go to \My Flash Disk\APL2\iGo, then paste them there.
If you don't want BLUE highway signs, don't copy the ui_pioneer folder.
Posted Feb 10, 2011 · 18:31 UTC#217
I understand the second part but not the first part I assume that zip file guide is located in your thread I want to make sure I don't delete the wrong files I think it duplicated some of the original files I think have to take a second glance
Posted Feb 10, 2011 · 21:08 UTC#218
You really need to know where you've dropped the files the first time!
If WinCE never asked you to overwrite a file, then you can safely assume that you've dropped the files in a folder other than the "\My Flash Disk\APL\iGo". So you have to locate this folder and move the dropped files.
To help you out, my files are summarized below:
DO NOT LOOK IN "\My Flash Disk\APL\iGo" for deletion, as this folder contains original Pioneer files. Once you find them, select all of them and select CUT from Explorer, then go to "\My Flash Disk\APL\iGo", select PASTE from Explorer, and confirm replacement of file first.
Note: You can delete "ui_pioneer" (only one file inside) if you want green highway signposts.
???Did you make a backup of "\My Flash Disk"???
Posted Feb 10, 2011 · 23:56 UTC#219
Ok Chuck, I'm sorry to keep bothering you with this but having that emulator up and running will be a HUGE step in the right direction for me. I tried what you suggested but couldn't locate the "hacked EZrider.exe" or the appropriate lisence file you mentioned. I'm sure I didn't do something incorrectly so I'm going to delete and uninstall everything I did and start over from scratch. Would it be possible to get a step by step?
Edited Feb 10, 2011 by MoneyGreen7467
Posted Feb 11, 2011 · 00:50 UTC#220
Yes I did and I found the files and got the nav working however the 3d cars is not showing up
Posted Feb 11, 2011 · 01:07 UTC#221
First of all, did you get this Windows after executing the batch file?
To be able to run the Emulator, you have to install the Emulator, downloaded from the Wiki.
You got to tell me what stage you have reached in the Emulator. If you have iGO working on your AVIC with newer map that you didn't pay for, then you already have the hacked EzRider.exe and appropriate license file, just copy them over from your AVIC.
Posted Feb 11, 2011 · 01:09 UTC#222
I assume that you have the "3DCars" folder under the "iGo" folder, you have to bring up the Applications Menu within the mod, then select the first icon of the second raw, with a car on a blue background.
From there, press INIT., restart your AVIC, then from the same location of INIT., press this time on SCAN LIST, wait a minute or so, then there you go! :rolleyes:
Edited Feb 11, 2011 by Chuck88
Posted Feb 11, 2011 · 01:22 UTC#223
Chuck,
Nope, didn't even get that window. Double clicked on the batch file (desktop icon) then a quick DOS window poped up then dissapeared right away and that was it. Nothing happened after that. Not sure if my maps are updated but if I'm not mistaken the very fist mod I did on my unit was Abb's V2.x, maybe those are the maps I have now. From there went to Abb's V4, then yours, and now Diafitia's.
Posted Feb 11, 2011 · 01:40 UTC#224
You didn't reach the stage of MAP or EZRIDER yet, you have to bring up the Emulator like the pic shown above.
Here is the checklist:
  1.
  2. Make sure that you have installed the Emulator!
  3. Make sure that deviceemulator.exe is here: "C:\Program Files (x86)\Microsoft Device Emulator\1.0\" or "C:\Program Files\Microsoft Device Emulator\1.0\".
  4. Make sure that the file NK.BIN is in the current folder.
  5. Make sure that there is a folder called "iGo-Chuck88" or anything else on top of the current folder.
  6. Now with all this, make sure that you have a batch file call RUN_AVIC.BAT with the following contents "
    "C:\Program Files\Microsoft Device Emulator\1.0\deviceemulator.exe" /video 800x480x16 /memsize 256 /c nk.bin /sharedfolder "iGo-Chuck88"
    And modify to fit your configuration as abve.
    Good luck!
Posted Feb 11, 2011 · 01:53 UTC#225
Thanks Chuck,
Unfortunately stuck at work for another 5 hours, but I'll try that out fist thing when I get back home to my laptop.
Page 9 of 35
