Abb's Chrome 'All-in-One' V5 - Feb 12/11
By abb1 · Feb 13, 2011in Completed Mods/Themes💬 146 posts👁️ 49,226 views
Page 5 of 6
Posted Jun 30, 2011 · 09:53 UTC#101
Hello ABB1 Thank you
You miss in the community of avic,I soon hope for a new work of you
Jean-louis
Thank you JP! I received a huge promotion with the job that I was with for the last 12 years and this new position is taking up 75% of my time, so I have little time any more for modding. On top of that, they relocated me and the movers somehow, lost all my connections to my spare Avic (the one I use for modding by my desk), so now if I mod, I will have to run back and forth to my car, which I do not have time to do. Once I get everything back in order, I will be back :) !
Edited Jun 30, 2011 by abb1
Posted Jun 30, 2011 · 16:51 UTC#102
ABB1,
Congratulations for your career development and I am pressed to see again your work
Jean-louis
Posted Jul 20, 2011 · 23:16 UTC#103
Where do we put the blue colour if we want it? the data file is a zipped file?
Edited Jul 20, 2011 by hanibal
Posted Jul 21, 2011 · 00:36 UTC#104
Create a new folder called APL2\iGo\ui_pioneer\800_480 and put your new BMP files in there.
Posted Jul 21, 2011 · 01:16 UTC#105
and put it where wheb we boot up in safe mode?
Posted Jul 21, 2011 · 02:07 UTC#106
Either ways: 1) Boot to TestMode to do the trick. 2) From an Windows Explorer shell even when iGo was running; reboot to see the change.
Posted Jul 21, 2011 · 11:22 UTC#107
Hi Chuck, you have me confused on this one! If you create a new folder outside the 'DATA.zip' file, with the bmps in it, you would still need a script forwarding the change to that location. Am I missing something?
Posted Jul 21, 2011 · 11:29 UTC#108
I'm still confused as well.
Posted Jul 21, 2011 · 11:54 UTC#109
No. As I dicted in the first post of my mod (please read), the files outside the DATA.zip structure with the same folder name always has preseance (read priority) over those inside the DATA.zip files. This is how I developed my mods without zipping and rezipping the new changes.
Read the first post of my mod Chuck88 :blink: and the scripts that I added in iGo\Extension folder as an example of how to copy BMP files to "replace" those within DATA.zip.
Edited Jul 21, 2011 by Chuck88
Posted Jul 21, 2011 · 12:39 UTC#110
This will then NOT change any original files, and if you no longer wanted the blue, you just delete the folder and it will be back to normal. Now, if there was only a way to do this with the 'image.res' file supoorting the main screen images, we would be all set. Hmmmmm, I will have to try this out......
Edited Jul 21, 2011 by abb1
Posted Jul 21, 2011 · 14:44 UTC#111
Now you understood! You're exactly right!
As for the Images.res, I didn't try it yet as those don't get modified often.
Good to know that you're back and try something else. :grin:
Posted Jul 21, 2011 · 16:17 UTC#112
Well, I won't be doing too much. During my relocation, the movers lost my wires for my spare Avic that I used for modding. I got some hookups, but I still need to fuse them with my power supply, which I have to figure out how to do again :(. They also lost my SD card with all my Avic files on it. That's not a biggie as I have files backed up on my PC.
Posted Jul 21, 2011 · 20:45 UTC#113
so how do i add the new blue theme that was added by some one else?
Posted Jul 21, 2011 · 20:59 UTC#114
Well OK, again, create a new folder called "\My Flash Disk\APL2\iGo\ui_pioneer\800_480" and put your new *.BMP files for the Blue Theme (by this someone else) in there. :o
Then reboot!
Posted Jul 21, 2011 · 23:49 UTC#115
What about the old file in the data zip?
Posted Jul 22, 2011 · 00:36 UTC#116
Apparently any location outside the Data.zip has precedence, so the folder with the blue images outside will dominate
Posted Jul 22, 2011 · 02:38 UTC#117
Leave them there! :rolleyes:
Posted Jul 22, 2011 · 03:24 UTC#118
Abb, to make it clearer, I was not talking about one single folder outside of the DATA.zip: you can just unzip the DATA.zip on top of APL2\iGo by retaining the folder structure, then delete the DATA.zip. Got it now? :shock:
When I mod, I open my editor and open as many UI files as I need, then directly edit them and save them on the fly, then launch or reset the AVIC Emulator. Script error? Just undo and save! I don't even need to exit the editor to see my changes, let alone zipping and rezipping and loading to SD then SD to AVIC!!! :mrgreen::mrgreen::mrgreen:
With your setup (externel AVIC), you really really wasted lot of time, and I would never mod if I have to do that. :blink:
Edited Jul 22, 2011 by Chuck88
Posted Jul 23, 2011 · 18:20 UTC#119
Hey All,
First Off, Abb WELL DONE! Great Mod, Great functions. Very useful (I use Every DAY)
My only question is this.. is there like a "lower volume" or "Attn" button.. A mute but not quite mute button. I know essentially Play/Pause will provide the function of mute (for some reason just not the same :( ) but is there a button or something I am missing that will lower the audio level (not the volume knob, but a temporary lowering, then resume at previous level by simple press). As if you had to have a quick car conversation then resume but wanted low level music in the background.
hope that makes sense.. Anyone?
Edited Jul 23, 2011 by macknup
Posted Jul 23, 2011 · 21:21 UTC#120
i tried putting that file out there and it did nothing. i did',t want everyting blue so i'm glad it dod'nt work!
Posted Jul 24, 2011 · 02:55 UTC#121
Thanks for the info Hanibal! I haven't tried it yet as I still need to get an SD card to replace the one that I have lost. I was going to play around with it, maybe I still will, see if I can get something working.
Posted Aug 01, 2011 · 20:56 UTC#122
Hello ABB1,
I took your logos to create my bar of task , for your work thank you
Jean-louis
Posted Aug 02, 2011 · 20:44 UTC#123
Hello ABB1,
Jean-louis
No problem! That is why I share my work. I am glad that you are enjoying it! Cheers :)!
Posted Sep 03, 2011 · 23:38 UTC#124
Love the mod very nice
Questions what do the schemes do not sure if I want to delete more maps to make room for it
Also is there a post that shows what all the icons on the map do?
Again thanks very nice
Edited Sep 03, 2011 by Ally68
Posted Sep 07, 2011 · 02:16 UTC#125
No problem! That is why I share my work. I am glad that you are enjoying it! Cheers smile.gif!
How do you invoke this screen?
Page 5 of 6
