i downloaded the v1.4, but whenever i try to extract the folder, it requires a password. i cant extract anything..does anyone know what the password is for this or have they had this issue?
Password is : avic411
Folks I think its time to put this thread to bed for good. There is very little that can be done with this hack to the point that it is not even worth the trouble. This has been going on for over a year now and no real progress and no sign that there will be any from this point. I will likely lock this thread in the coming days unless someone can give me a good reason to allow it to continue.
Hello VBLUE42, well from my point of view it is important to keep it alive. I would like to get full hack mode on my X940 including copy and paste function.
In post #682, Ralpharn suggested to check file structure to compare it to the X930... Well, i'm affraid I don't have the skills of condiczek and others here but still, this is something I could do if I can get a few pointers and help as what to look for. Every folders, subfolders and files? Anyone have a complete listing of the X930 file system? There is still people here, still worth a bit of trouble imho.
Well I will take others suggestions under advisement. I guess Im just tired of seeing updates to the thread only to look and not see a significant update to the capabilities of this hack. At this point, I really don't think its going to progress. Also people are coming here thinking they are going to get the same ability to hack these units as they did with the previous F/X series and that is just not the case. IMO its offering more of a misleading disservice that it is helping at this point. I suggest you guys that are concerned PM the author of this thread and inquire as to weather he is still developing this proceeder or if he has reached an end.
Here it isAnyone have a complete listing of the X930 file system?
You need "files visible from testmode" (I hope that key file is there) and Ndata (part1 and part2) from that page.
Please chek files especially PRG0/ folder. I hope it should be something like ***.FLG file with zero length. For instance mode.flg or test.flg But do not delete anything yet!
They (pioneer service) should have back door! %)) Also it is possible that testmode can be started different way to get proper working one. so we need someone who will check file by file all software inside.
I don't see any point to lock it. Why?? May I suggest you to remove "stiky" tag and let it live as is?... I will likely lock this thread in the coming days unless someone can give me a good reason to allow it to continue.
Done.
Hi Ralpharn and many thanks!
I've started checking the file structure and so far, from the first page, everything seems to be the same exept
the User Folder which is shown on top, here I will copy and paste from your text to show the slight difference
X940BT Folders structure:
USER (main applications are here)
NDATA (map and other files)
NDB
SD (sd slot)
SD2 (empty)
SD3 (empty)
SD4 (empty)
USB (usb conector)
USB2 (empty)
USB3 (empty)
USB4 (empty)
Under NDATA I have found
partcode.txt
release.txt
and another \ndata folder
when I go in this folder then I have 8 other pages of subfolders
00
02
03
then the other folders goes in hex
ect ect
The only .flg files I have found so far are under
user\setup\inistate\initstate.flg
user\rw\inistate\initstate.flg
Both of them with the same time stamp and are empty, 0Kb
I can see but can't copy anything, i can take pictures of everything though
just not sure how much I can upload here
Btw, does it matter if I have both testmode and hackmode condi's key file on the sd card or is it one at a time?
Thank you for your effort. NDATA forlder looks like it have same structure as X930 ones. Inside NDATA folder is 3 objects:
partcode.txt (inside the file text "CWW3225-")
release.txt (inside text: "PLU1-3-A")
and another \ndata folder with lots of folders.
BTW are you sure you have 01 folder?
My unit has there:
00, 02, 03, 04, 05, 06, 07, 08, 09, 0A, 0B, 0C, 0D, 0E, 0F, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 1A, 1B, 1C, 1D, 1E, 1F, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 2A, 2B, 2C, 2D, 2E, 2F, 30, 31, 33, 34, 35, 36, 42, 43, 44, 45, 46, 47, 48, 49,4A, 4B, 4C, 4D, 4E, (with map) and AV, BG, BT, FE, INIDATA, L3D, SDUSB, SKY, SOUND, symbol, TEL, TTSData, VBT Folders.
Hackmode.key only works if you have hackmode installedBtw, does it matter if I have both testmode and hackmode condi's key file on the sd card or is it one at a time?
According to the pictures you uploaded you have USER/RW/Syslog folder that we do not have.
Anyone know if this will work for the x710??
No it will not. There is a sections in the forum for the previous X series that is full of detail however. Also be aware that most related to the previous F series also applies for your unit. Have a long read in the hacks and mods sections of the F and X series forums.
No I don't, my mistake, corrected it, i will have to check with your list if it's the exact same structure
anyone have a link to the proper password help section for the x710? just to save me hours of searching ![]()
There is no option for that series of unit other then to send it to Pioneer and pay the price.
It contain a file named PATHERR.LOG and seems to be a GPS log file
I will upload picture
My unit has there:
my partcode.txt (inside the text is "CWW4587-'' )
my release.txt ( inside the text is "PLU-1-4-B'' )
I will upload pictures of my ndata\ndata
According to your pictures x940bt has folders:
DEMO_IMAGE
RENEWAL
in NDATA\NDATA that not present in x930bt
DEMO_IMAGE
RENEWAL
They don't seem to contain anything interesting, i will upload pictures.
However I did find what seems to be a filter file for USB and SD in ndata\ndata\sdusb\filter.flr , could it be as simple as debug insted of testmode...? could you compare with what you have in the X930 and what you think. I will upload picture as well
Here is update for European F40/F940 (analog of Z140 and X940) http://www.pioneer.eu/uk/support/software/AVIC-F940BT/index.html
Here is update for European F40/F940 (analog of Z140 and X940) http://www.pioneer.e...40BT/index.html
it would be great if we use that update for F30BT ![]()
hi guys,
im back to business lol
got some very interesting news, will give you detailed info later.
for now I can tell you that i've got f30bt with 'semi-working' f40bt firmware.
and of course - like in f40bt - i have testmode-copy/paste disabled lol
br
condi
I hope you wouldn't mind if I attach it herei hope this patched Testmode solve problem with copy paste.
...for now I can tell you that i've got f30bt with 'semi-working' f40bt firmware.
Glad to see you again!
Can you delete PRG.FLG file from your limited testmode? it will make PRG0 active and you will have working testmode (and software from F30) again.
I assume that you have updated your device (and got PRG.FLG file he-he...)
Which features are not working on your 'semi-working' f40bt firmware?
