Z110BT USA Upgrade with CSND-210FM (2011)
By StefanSki · Aug 18, 2011in Hacks/Mods💬 324 posts👁️ 103,107 views
Page 9 of 13
Posted Sep 28, 2011 · 19:29 UTC#201
Anyone else get any errors when trying to extract the files to the sd card? I don't get any errors when i extract it to my hard drive but get errors on everything when I try and put it all on the sd card. I just purchased the sd card so i doubt its bad but it could be I guess. Errors are mainly 0x80004005 unspecified error.
You mean you are getting errors just dragging & dropping (copy/paste)the extracted files to your SD card? Which step/update are you on? 2.003, 2.004, 3.000.
Actually, sounds like a problem with your computer. It shouldn't matter what the files are - as long as the SD is big enough and formatted. Try copying some other large files to the SD. Do you get the same errors?
Edited Sep 28, 2011 by RonS
Posted Sep 28, 2011 · 21:19 UTC#202
Yeah it was the sd card. Returned it and got a new one but cant get the update to start. Extracted the files from 2.003 onto the card and replaced the 2 files from 2.004. I tried having the avic110 folder as the root and also just having the files on the card without being in the avic110 folder. I am using version 1.00000. Is this why? I just tried updating to 2.003 without the hack and the files in the avic110 folder on the card and nothing would pop again. I am going to try the second time with just the files out of the avic110 folder and give it a go.
Edited Sep 28, 2011 by Spitfire91104
Posted Sep 28, 2011 · 21:31 UTC#203
Ok I am torrenting the z120bt update. Will update to that and then try to upgrade to 2.003. If this torrent is 2.000 I can I still use the crack with that or do i just upgrade straight from 2.000 2.004? Oh and do these updates include the bluetooth updates as well? I just asking because I noticed the purchased ones from pioneer include the second sd card.
Posted Sep 29, 2011 · 00:40 UTC#204
I'm pretty sure you can't install 2.003 or 2.004 directly on 1.000 or 1.001. It is a patch to 2.0.
The 1.0 > 1.001 > 1.002 > 2.0 > 2.003 > 2.004 > 3.0 path will work, but I think you can do it quicker.
I think you can go 1.0 -> 1.002 > 3.00
This assumes that your 1.002 SD is made from the Pioneer 1.001 + the ShortFuse hacked files. The reason I think you may be able to go straight to 3.0 from 1.002 is that Pioneer says the CNSD-210FM upgrade is for either a Z110 or Z120. So I bet the password hack in 1.002 is all you need.
AFAIK, no one has reported doing it this way. Worst case is 3.0 doesn't let you past the password entry screen. Then you just go back to the 2.0 > 2.004 > 3.0 route.
Oh ya, SD2 is the new Parrot BT. Actually there is BT (Firmware dir) on SD1 also. I guess you are supposed to update BT from SD1 first, then insert SD2 and do it again.
Edited Sep 29, 2011 by RonS
Posted Sep 29, 2011 · 01:27 UTC#205
Update. Got it updated to 3.001 the long way lol. So far only updated bluetooth with the sd2 pack in the 2.003 update i torrented. Only thing is I lost voice control. When i hold it down on the headunit or the button on my steering wheel i assigned it to it just mutes instead.
Posted Sep 29, 2011 · 02:49 UTC#206
Thanks StefanSki
After I did what you said instead of what I thought you said. Everything went fine. :huh:
Posted Sep 29, 2011 · 05:27 UTC#207
Wow thx for the upgrade. Everything went perfect......i'm just hoping the bluetooth update fixes the background noise issue that the other caller experiences.
Some great seeders out there too! Took all of 15 min to download! Will seed for a few months. Cheers.
Posted Sep 29, 2011 · 09:46 UTC#208
I thought if you hold down the "voice" button, the radio is SUPPOSED to mute? I suggest you TAP the "voice" button, and see what happens.
Posted Sep 29, 2011 · 09:55 UTC#209
I'm no longer convinced the BT noise over phone calls can be fixed thru a software update. I have a BB Tour for ages, so I haven't tried any other phone to test other options. I'm hoping the iPhone 5 doesn't have this issue since it will be my next phone.
FYI, the noise over BT phone calls almost goes away when you hold the "HOME" button and turn the screen off. This tells me there is interference pickup from the head unit over BT.
FYI, the noise over BT phone calls disappears when you mute the phone call from the phone itself (NOT THE HEADUNIT).
Posted Sep 29, 2011 · 16:03 UTC#210
I have an iphone 4, the call quality on my end is good. I can hear the caller loud and clear. My issue is that the caller can hear all the background noise of the wind etc when i'm driving down the highway at 70mph. if i'm stopped then the caller has no complaints. When i'm on the highway it get so bad the caller want me to call back later with a better connection lol.
This seems to be a different issue than you are experiencing, although i will try your tips thx for the info.
Cheers
Posted Sep 30, 2011 · 04:21 UTC#211
I tried the initial update and it said it completed - however upon reboot i am still showing version 2.0000 (I have a 110bt that was previously updated to the 120bt software). Im i missing something?
Posted Oct 01, 2011 · 21:04 UTC#212
Upgrade worked perfectly on my AVIC-X920BT.. However, the map is still missing for my neighborhood that was built in 2004... darn!
Posted Oct 01, 2011 · 21:07 UTC#213
I did report this to the tele atlas folks when I got the unit. I guess they didn't have time to put it in.
Posted Oct 02, 2011 · 18:03 UTC#214
When u get to that screen that shows verions 2.000, push and hold the upper left hand corner of the screen (pretty sure there will be a wrench icon). It should then change screens and show u what u have.
Posted Oct 02, 2011 · 21:34 UTC#215
Also as jman0711 said check that but also make sure you placed the hacked files into the correct folders. It will say it updated, then might say it failed or completed but leave 2.0003 and not 2.0004.
Posted Oct 03, 2011 · 00:23 UTC#216
Wow, I forgot to check back and see if the cards had been received and uploaded for a week... It's been busy on here...
Downloading now, will upload at 900k for about a week or so, most likely more because I'll forget it's running... :mrgreen:
Thanks to all the others who donated and those who are seeding. Looks like I'll have it in about 8 minutes start to finish...
Also, has anyone successfully done the 1.000 Z110BT to 3.0 thing yet? I saw some suggestions about only possibly needing to do the shortfuse to get to 1.002 and then go right on to the latest. I'm wondering if anyone has tested that theory...
Edited Oct 03, 2011 by simcam68
Posted Oct 03, 2011 · 17:53 UTC#217
i am trying to go to 1.01 z110 to 2.0 I have posted in the other thread that I am stuck someone please help...When I insert SD I wait 2 min and notheing happens...I assuming I labeled something wrong?
Posted Oct 03, 2011 · 21:53 UTC#218
Definitely was happy to see a few weeks later that someone came up with a solution to getting the update up on torrent. I've been seeding this on my desktop and already pushed up about ~7GB's, so looks like people are grabbing this up, which is good. I'm going to give it a try tonight on my Z110BT.
Posted Oct 03, 2011 · 22:15 UTC#219
am trying to go to 1.01 to current..Please advise
Posted Oct 04, 2011 · 01:58 UTC#220
worked like a charm, so in reality the update is on only SD1???
and the bluetooth update is on SD2??
i was confused at first when the first update completed and it said it was on 3.0 already.
Posted Oct 04, 2011 · 18:53 UTC#221
dunno why but i redownloaded and it all worked the 2nd time around....strange....
Posted Oct 05, 2011 · 04:01 UTC#222
I haven't been back to this forum in awhile and was just checking in to see if there was anything new going on for my z110. To my amazement, I found this gem of a thead! Thank you to all the members who made this possible!! Everything worked perfectly!!! I'll be seeding the torrent though the end of this month. I purchased the last map/GUI update a year ago and received a bad SD card from Pioneer. It took them 6 weeks to get me a new card while I drove around with my z110 stuck on brick mode and their customer service was terrible to say the least.
Also, has anyone with a z110 tried the 3.001 update for the z130 with this crack? I only ask because the notice on Pioneer's website said only to apply the 3.001 update to the z130.
Posted Oct 05, 2011 · 04:32 UTC#223
Nevermind, I checked the application version and it is already 3.001 with this upgrade. Thanks again to the members who made this happen.
Posted Oct 05, 2011 · 12:30 UTC#224
I don't know the answer, but I think you raised an important point. A Z110/120 + CNSD-210FM does not equal a Z130BT. They are different internally and functionally. It merely updates the maps and adds some new applications; and support for the new traffic tuner. I think, on this board, we should not refer to an upgraded unit as a Z130. It will eventually lead to problems and confusion.
Just my $.02.
Edited Oct 05, 2011 by RonS
Posted Oct 05, 2011 · 18:31 UTC#225
Just Updated My X920BT using the same instructions in 1st post.
thanks a lot guys!
EDIT: fixed the missing neighborhood for me
Edited Oct 05, 2011 by markvis
Page 9 of 13
