Hi all,
I finally found the gimmick again for the AVIC X710BT rebooting after exiting from Primo v1.2 (same for all units???), either the navigation is completed or user-requested exit: play radio (or A/V turned OFF) is not good enough, you have to have USB or SD or iPod playing to prevent rebooting!
However, you can just switch to SD or USB or iPod then go back to radio (or turned OFF???), there is no rebooting neither! As long as the audio channel is opened with SD/USB/iPod, it will be OK thereafter.
Unlike ryar, I don't have rebooting problem after exiting Primo in TestMode, though.
Chuck!
Makes sense, I never have an SD card in hence the reboots. Note that I do not reboot in testmode after exiting, and never did.
With thanks to ryar, my setup is now completely functional, with soft and hard key to swtich between MainMenu and Primo. Below is my CwGoPrimo.mscr file contents:
kill ("ezrider")
kill ("ezrider.exe")
waitfor ("MortScript V4.2", -1)
SendOK
Run ("\My Flash Disk\APL2\Primo\extension\AEKMap\AEKMapScan.exe" )
sleep 2000
kill ("AEKMapScan.exe")
Run ("\My Flash Disk\APL2\Primo\extension\AEKMap\AEKMap.exe" )
Run ("\My Flash Disk\APL2\Primo\extension\Button\button.exe")
Run ("\My Flash Disk\APL2\Primo\Primo.exe" )
Attached is the complete set of files that I use now, and I made real Primo icon at the bottom-center of the MainMenu. The missing Primo BMP file is also included as well as the new scripts UI files are also included.
Good lucks.
It looks good Chuck, thanks. Note the hard keys are not fully functional and that is why I took out the AEkmapscan and AEKmap launch upon start (CwGoPrimo.mscr). Your volume control will work, but only Primo's volume control (eg. main units volume is set to 10 of 20, Primo volume 100%, the dial will not increase the main volume above 10 of 20). It is also buggy when pressing the Map or Menu buttons while in AV (Pimo screen or Main Menu screen come up, but when the screen is tapped it brings you back to AV). Also, the right/left on the knob no longer change song, ect but only rotate the screen. Anyways, I didn't feel the keymap would be best for everyone so I left the option up to the user (HardKeyTest).
I updated the main download to include your UI_pioneer folder yesterday; if anyone is running with a another mod besides Chuck's do not copy this folder onto your unit (or you can copy the entire My Flash Disk from the main download and delete the APL2\iGo\ui_pioneer folder).
