Primo for AVIC F series!
By ryar · Sep 09, 2011in Completed Mods/Themes💬 315 posts👁️ 87,155 views
Page 7 of 13
Posted Oct 05, 2011 · 18:59 UTC#151
Pacajo, really pegged satellites after a while ... But when you turn elsewhere, again looking for. :neutral:
Patper, I found a post where someone claims they could get a satellite fix in the US but not Germany. It is here: http://www.mobilepassion.org/viewtopic.php?f=210&t=1958
That person seems to believe that it may have something to do with the licenses, perhaps you do not have a working license for your Euro maps?
On another note, what language do you have Primo set for? Perhaps you have English (US); if so try setting it to English (UK).
Posted Oct 05, 2011 · 19:19 UTC#152
hmmmm, but why find satality (at home). , But when I turn elsewhere
looking for??
Language - Czech.
Posted Oct 05, 2011 · 21:02 UTC#153
Well, for my part I never tried iPod ... so please post results. :mrgreen:
Got it working with an SD card. Strange, but be because of my cheap Chinese knock-off iPod cable. Thanks again for your post Chuck, at least now I got it working.
Posted Oct 07, 2011 · 09:17 UTC#155
I reinstalled everything again + mod v3, 4, and unfortunately it's still the same ....
So I'm afraid I have to stay with IGO8. :neutral::?:neutral:
Posted Oct 07, 2011 · 12:30 UTC#156
Installed primo today and I like it a lot.Shame about the sound only being available when playing via SD card,otherwise I have everything else up and running.One thing I have found is that if you scan the mp3 files on your SD through the internal music player and play them through that the sound does mute when the voice instructions are being given.Also you get full control of your music from the map screenî—
Posted Oct 07, 2011 · 15:23 UTC#157
The only problem that I've encountered is that the sound quality is sometime mediocre at best with the Primo MP3 player.
Posted Oct 07, 2011 · 15:24 UTC#158
Sorry to hear that but that must be something with your unit! If you have a friend having the same AVIC, try your installation procedure over his unit, just to see.
Posted Oct 07, 2011 · 15:31 UTC#159
You're right of course Chuck regarding sound quality.Unfortunately my RV is not the quietest vehicle on the road so sound quality isn't that apparent to meî
Posted Oct 07, 2011 · 15:52 UTC#160
Chuck - I hope that this is some kind of betrayal, and perhaps for that matter ..... I hope ... :idea:
Posted Oct 07, 2011 · 17:57 UTC#161
patper, sorry but I'm not sure that I understand well your statement. :shock:
Posted Oct 07, 2011 · 18:31 UTC#162
Sorry for my English... :neutral:
Posted Oct 07, 2011 · 19:14 UTC#163
Patper try the upload below. It is a clean install from a European source, never initialized and has a meager sys.txt. There is no skin, but at this point we want to see if it gets you a gps fix. Let me know if it works.
http://hotfile.com/d.../pr1m0.rar.html
Posted Oct 07, 2011 · 21:37 UTC#164
I've done Deleting the entire disk and installed the original software and then v3, 4 - and Primo runs without problems .... tomorrow I'll try how it behaves when driving.
Posted Oct 07, 2011 · 22:56 UTC#165
Yeah, that is bad, because you can hear constantly glitches. Additionally, you can no longer control the player with the steering wheel mounted controller!
Posted Oct 07, 2011 · 22:57 UTC#166
I have a rear view camera and from time to time, Primo won't let go its map screen to show the rear view video when I am backing up.
Anyone has this issue? ryar?
Posted Oct 07, 2011 · 23:37 UTC#167
I have the same behavior on the odd occasion, maybe 20% of the time. A reboot seems to fix it for awhile.
Posted Oct 08, 2011 · 09:46 UTC#168
Primo will not boot ....
Posted Oct 08, 2011 · 17:11 UTC#169
Correction - also looking for ...
Posted Oct 08, 2011 · 17:15 UTC#170
I gave back Ryar AVICMod09.22.11.2 and everything in order. (still in the garage) ..
Posted Oct 10, 2011 · 10:08 UTC#171
Hi,
I discovered - in the garage if I wait until it starts Primo, so everything is alright !!!!!
But if Primo sputím elsewhere, so looking for!!
Any advice??
Thank you Patrick
Posted Oct 10, 2011 · 14:30 UTC#172
Ryar could you please tell me where I can find the settings for traffic in Primo?I have had to reinstall chuck 3.4 and now I can't get traffic working.I did have it running superbly before the re install.
Posted Oct 10, 2011 · 17:32 UTC#173
I'm not sure, I have TMC disabled in mine. You could create a shortcut to Traffic in Customize Quick Menu. I see there is a line in the sys.txt which reads:
[tmc-http]
enabled=0
Perhaps that should be a 1? If you have your old sys.txt and save folder inside the Primo directory if you replace both you should get all your old settings, ect back.
Posted Oct 10, 2011 · 17:59 UTC#174
[tmc-http]
enabled=0
Thank you I will try that.
Posted Oct 11, 2011 · 15:29 UTC#175
so it ake itthat you've got primo working in the uk? Did you use any particular settings? I can't get it to work. The main screen comes uip, satelittes are found, but the display just says Looking for GPS signal... with a green background.
Page 7 of 13
