Primo for AVIC F series!
By ryar · Sep 09, 2011in Completed Mods/Themes💬 315 posts👁️ 87,155 views
Page 9 of 13
Posted Oct 13, 2011 · 13:24 UTC#201
You must delete the WAV and others what they are in Russian!
Posted Oct 13, 2011 · 13:36 UTC#202
i deleted the both folders completely.. I will go through all the .wav files and delete all the Russian one I find.
Posted Oct 13, 2011 · 13:51 UTC#203
It appears that ALL the spoken audio files in AUDIO are in Russian. Any idea where the others are? Are there any I can copy over from iGO? I get English speedcam warning s there. One point, Primo tells me in English when I am over the speed limit (to be deactivated very soon), so where are those warnings?
Posted Oct 13, 2011 · 13:52 UTC#204
Here are for you EN Audio ...
EN.zip
Posted Oct 13, 2011 · 14:08 UTC#205
Palexr - how you're doing on the GPS??
Posted Oct 13, 2011 · 14:30 UTC#206
Sometimes it works, sometimes it doesn't... Annoyingly.
You?
Thanks for the voice files. I just put them in the AUDIO folder?
Edited Oct 13, 2011 by palexr
Posted Oct 13, 2011 · 16:23 UTC#207
Thank you.
Posted Oct 13, 2011 · 19:19 UTC#208
Ryar
Reinstalled previous settings and traffic is back.First road test tomorrow so fingers crossed.
Posted Oct 13, 2011 · 20:26 UTC#209
Ryar
I take it you are not having issues in the UK? Can I ask what unit you have and if it is a European one or a US one?
Could you share your sys.txt
Just wondering why mine can't seem to put me on the map reliably. If I wipe the save folder the machine starts me off in Paris! But it then, usually, starts working. Funny thing is, the car is in Paris but if I go into where am I the latitude and longitude are for here in the UK.
Posted Oct 13, 2011 · 21:07 UTC#210
I've got a European 900BT.
If you PM me with your e mail address I will send you the sys.txt I am using.As I said I have yet to go on a route but I am picking up satellites etc,when parked upî”Tomorrow is D day for me...off out on the road.Traffic works fine,speed cams are showing and text to speech all working ok.Only issue is with the sound,only audible when playing via SD card.
Posted Oct 13, 2011 · 21:29 UTC#211
I tried it and error message came up for line 26 testmode 1? I believe it is in the start.ui.. Jimbo
Delete the ui_pioneer folder and add:
1 run 'START_APPLICATION "\My Flash Disk\APL2\iGo\run\button\button.exe" ""'
in your start.ui file inside your data zip right under
<state st_Start>
<script init>.
Posted Oct 13, 2011 · 21:49 UTC#212
For Euro AVIC users try the file below. It is a never initialized fresh copy of the May 2011 release with a minimal sys.txt. Delete the entire Primo directory in My Flash Disk and copy onto your unit. I tested it on my US f500bt and it worked perfectly. I hope it solves your satellite and speedcam warning issues. Please leave some feedback as to how it works and if it solved any issues you have been having.
http://hotfile.com/d...ay2011.rar.html
Edited Oct 13, 2011 by ryar
Posted Oct 13, 2011 · 22:26 UTC#213
Oops, double post - dangers of using smartphones.
Posted Oct 13, 2011 · 23:27 UTC#214
<state st_Start>
<script init>.
I got it working. I will let you know how everything works.
Thanks Again
Jimbo
Posted Oct 14, 2011 · 13:39 UTC#215
thanks for you efforts, but, nope, still in central Paris apparently... I haven't been able to get it to work for past dozen goes now, not sure what else to do.
As i said the Lat and Long are correct, I believe, they certainly move with me as does the altitude, it just doesn't seem to translate into an postion on the map very often.
Edited Oct 14, 2011 by palexr
Posted Oct 14, 2011 · 15:04 UTC#216
Just completed first trip using Primo,about 150 miles.Apart from losing traffic info,everything went perfectly.Junction views are brilliant,a big improvement on IGO.Looking forward to learning more about it in the days to come.
Posted Oct 14, 2011 · 15:21 UTC#217
I PM'ed you about the sys.txt? I'm having no luck. which is really annoying as it is clearly so much better than std IGO.
Posted Oct 14, 2011 · 16:12 UTC#218
I am on it as well as Palexr :neutral:
Posted Oct 14, 2011 · 16:19 UTC#219
Does anyone read Russian? I believe there a few threads on other forums about this - I think that is where this came from...
Posted Oct 14, 2011 · 18:36 UTC#220
So weird. More then half the people posting in Primo threads seem to be from Europe and no one has mentioned similar problems. Even a newer version and sys.txt didn't help? Maybe ovalball can help since he seems to no have the problem.
Posted Oct 14, 2011 · 18:37 UTC#221
Use Google Chrome, it will translate the page to English for you.
Posted Oct 14, 2011 · 18:41 UTC#222
oops, double post
Edited Oct 14, 2011 by ryar
Posted Oct 16, 2011 · 18:56 UTC#223
Hello, please also about SYS.TXT
Thanks in advance Pat.
Posted Oct 16, 2011 · 20:00 UTC#224
Hi all.Just completed a round trip of over 300 miles with no real problems.Lost traffic info but I think this is an issue with settings in so much the TMC info is available at the outset of the journey but doesn't update.As soon as I can I will post my sys.txt on here(hopefully tonight)and maybe other European users can try them and see if things improve.
Posted Oct 16, 2011 · 20:19 UTC#225
Please see below the sys.txt I have been using(quite successfully)with my 900.
[device]
:type="PIONEER746UC" ; US F700/900/710/910
;type="PIONEER749UC" ; US F500
type="PIONEER746EW" ; Euro F700/900/710/910
;type="PIONEER749EW" ; Euro F500
[utility]
calibratefix=0 ; ; If gps signal don't lost write - "0"; if lost write "1"
[interface]
vga=0
show_exit=1
show_minimize=1
extra_settings=1
shutdown_time=0
capture_to_jpeg=1
show_mapchanger=1
show_programs=1
[rawdisplay]
highres=0
stretch=1
screen_x=800
screen_y=480
class="landscape"
[Keybind]
xa6 = "ZOOMIN";Up
xa8 = "ZoomOut" ;Down
xC4 = "MINIMIZE" ;Menu
xaf = "VOLUMEUP" ;Dial right
xae = "VOLUMEDOWN" ;Dial left
xD5 = "ROTATELEFT" ;Left
xa7 = "ROTATERIGHT" ;Right
xC3 = "MAINMENU" ;Map
x8D = "ANNOUNCE" ;Middle button
[folders]
has_secondary_root=0
sdcardpath="\my flash disk\APL2\"
;app="..\..\Primo"
maps="..\..\IGO\content\map"
buildings="..\..\IGO\content\building"
dem="..\..\IGO\content\dem"
poi="..\..\IGO\content\poi"
[gps]
baud=9600 ;- write "baud rate"
port=7 ;- write port
source="virtserial"
set_messages="0" ;
[mapchanger]
map_ta="TELEATLAS" ; - you can write other title
map_nt="NAVTEQ"
map_ot="TOP MAP"
[tripcomputer]
num_of_trips=4
[vr]
disabled=0
[3d_config]
disable_roadsign_navigation_mode=0
roadsign_lines_per_screen=10
rotated_roadsigns=0
[sound]
csv_voice_enabled=1
ding=0
[debug]
skip_eula=1
screenshotsavecameraini=0
screenshotfilename="\captures\ecran_%02d.jpg"
show_battery_percent=1
experimental_features=1
show_networkservices=1
catch_all_keys = 0 ; 0=No 1=Yes (I suppose)
[lua]
backlightdetails=1
[gestures]
border_width=130
[network]
available="0"
[tmc-http]
enabled=0
[http]
enabled=0
[other]
demo_enabled=1
[map]
show_oneway=1
2dheadup=1
show_oneway_3d=1
poi_grouping_distance=0
3d_max_zoomlevel=800;
3d_min_zoomlevel=30;40
speedcam_visibility=500;
3d_max_tiltlevel="8700"
3d_default_tiltlevel="8200"
3d_max_zfar=5000
3d_buildings=1
3d_landmarks="1"
3d_roads="1"
3d_tunnels="1"
follow_gps=1
[2d]
guidancearrow_disappearlevel=600
guidancearrow_maxshift=12
minguidancearrowsize=20
minguidancearrowsize_zoomlevel=1200
maxguidancearrowsize=65
maxguidancearrowsize_zoomlevel=0
[3d]
planned_route_track_width="5"
planned_route_track_contour_width="1"
planned_route_contour_width="1"
max_pois_on_horizont="5"
[navigation]
junction_view_distance=300 ;(200)
junction_view_distance_ramp=300 ;(400)
junction_view_distance_highway=400 ;(800)
simple_crossborder_warning=1
use_duration_for_tunnel=0
show_current_city=1
show_city_in_next_street = 1
show_city_in_next_street_distance = 1000
autoreplan_action="AUTO"
gps_pos_to_road=1
show_countrychange=1
[camera.roundabout]
enabled=1
[feature]
text_guidance=1
signpost_coloring=1
tmc_event_coloring=1
tmc_traffic_side=1
ding=0
[dynamiccompressor] ;TTS voice
compressor=1
gain=10
[tts]
automatic_direction_conversion=1
announce_exit_directions=1
always_say_road_names=3
skip_exit_numbers=1
[warning]
speedcam_enabled=1
speedcam_warning=1
speedcam_max_lookahead=1000
speedcam_maxdistance_from_road=50
; S P E E D C A M - C A T : 0
[speedcam_category:0]
approach_beep_distances="950,450"
approach_beep_sound="Fixed_Camera"
overspeed_sound="over_speed_limit"
min_frc=5
; S P E E D C A M - C A T : 1
[speedcam_category:1]
approach_beep_distances="450,450"
approach_beep_sound="Mobile_Camera"
min_frc=5
; S P E E D C A M - C A T : 2
[speedcam_category:2]
approach_beep_distances="950,150"
approach_beep_sound="Redlight_Camera"
min_frc=5
; S P E E D C A M - C A T : 3
[speedcam_category:3]
approach_beep_sound="Section_Start"
min_frc=5
; S P E E D C A M - C A T : 4
[speedcam_category:4]
approach_beep_sound="Redlight_Camera2"
min_frc=5
; S P E E D C A M - C A T : 5
[speedcam_category:5]
approach_beep_sound="Railroad"
min_frc=5
; S P E E D C A M - C A T : 6
[speedcam_category:6]
approach_beep_sound="Give_Way2"
min_frc=5
; S P E E D C A M - C A T : 7
[speedcam_category:7]
approach_beep_distances="950,550"
approach_beep_sound="FixMobil"
min_frc=5
; S P E E D C A M - C A T : 8
[speedcam_category:8]
approach_beep_distances="450,150"
approach_beep_sound="Speed_Breaker"
min_frc=5
; S P E E D C A M - C A T : 9
[speedcam_category:9]
approach_beep_sound="Children"
min_frc=5
; S P E E D C A M - C A T : 10
[speedcam_category:10]
approach_beep_sound="Dangerous_turn"
min_frc=5
; S P E E D C A M - C A T : 11
[speedcam_category:11]
approach_beep_sound="Tunnel"
min_frc=5
; S P E E D C A M - C A T : 12
[speedcam_category:12]
approach_beep_sound="Dangerous_way"
min_frc=5
; S P E E D C A M - C A T : 13
[speedcam_category:13]
approach_beep_sound="POI"
min_frc=5
; S P E E D C A M - C A T : 14
[speedcam_category:14]
approach_beep_sound="RPS_Post"
min_frc=5
Page 9 of 13
