Oh no, it looks like you are having similar issues that patper is having. Perhaps this problem is common in European units with the settings files supplied. Well, maybe we can try a few things and cross our fingers. Try the following steps in order:
1. Since you have a European f900, try putting the following lines in your sys.txt file:
[device]
type="PIONEER AVIC-F900EW"
Either comment out or delete all other lines under the [device]. Also add:
[gps]
port=2
baud=9600
Once again, comment or delete all other lines under [gps].
2. Restore Primo's default settings. Restart the unit and before launching Primo, delete the "save" folder in the Primo directory. Maybe the unit is confused because it was first initialized in Canada and is now attempting to get a fix in the UK.
Patper tried some other possible solutions we suggested but he didn't have any luck. If all else fails, you could obtain a copy of Primo (1.2) elsewhere and give that a shot. Use the sys.txt from the download in post#1 and perhaps it will work. I wish I was able to a simulate issue, it would make it easier to troubleshoot. Good luck, let us know how it goes!
Yeah!!!!!
Thank you Ryar!!!!
I used your settings above but with port = 7 and commenting ";" all other lines out and it picked me up immediately!!!
I made the changes directly to the SYS.TXT file in the Flash/APL2/Primo folder using Total Commander on the unit itself (using a pen to type...).
Now for a drive to see how it works.
