No luck.
I did all the changs you suggested and still no luck. Without the address of the map (UK copied as per instructions and sys.txt amended) Primo returned an error saying it oculdn't find the map, I carried on and there was no map. Despite this I guess the systme was still putting me in London as the buildings came through and Westminster Abbey and the Houses of Parliament were right next to me (where Primo had been putting me previously with the maps).
Garmin and TomTom still don't pick up a GPS signal.
Two things I noticed.
1 There is a "crash.txt" in the Primo folder. I have copied it to my SD card and will share it later when I am home. There might be info in there?
2 When the systme is warming up it briefly flashes the portsplitter status window. I can see there that port 7 and 9600 baud are set. Sys.txt specifies port 6. If I change the sys.txt entry to 7 I get a message about "attempting to detect GPS hardware" (something along those lines anyway). I am not sure how to run the portsplitter and change the port. If I run it once avicnet has started I get an error?
Stock iGO is looking good to me now ... Although that has changed a bit as well ...
Oh, I thought it was putting you in France before? When you comment out the lines under folder it will look for maps, ect in its own directory. So long as you put a basmap file in the map folder it won't give you a "no maps found" message. Are you certain you put the maps in the same directory that you ammended your sys.txt? There are 2 as I stated above, Primo and Primo2. Try launching Primo in test mode.
The sys.txt is set to port 6 because the port splitter splits port 7 to 5 and 6 I believe, and all 3rd party programs use port 6. If you shut off the port splitter or choose to not auto-launch it you will need to set your sys.txt to port 7 but remember if the stock iGo is running other GPS programs won't see it. You need to close or kill the ezrider process first.
What unit do you have? You seem to have some issues that I don't experience. I am running AVICnet on my NA f500bt and my f900bt and it works perfectly. I also loaded the Euro version and did not experience any issues, although I cannot vouch for TTS or TMC.
I never looked at a crash.txt file so i'm not sure it will help.
Ovalball, can you let us know if you are having any issues on your unit with the Euro release?
