AVICnet 2.1 for AVIC F series, working OBDII! Updated 2014/04/30
By ryar · Oct 19, 2011in Completed Mods/Themes💬 700 posts👁️ 270,055 views
Page 3 of 28
Posted Oct 25, 2011 · 21:28 UTC#51
c'est plutot l'inverse
j'ai le tmc sur igo primo et pas sur primo
Sorry, I don't understand. You have TMC on the stock iGo and not Primo? Sorry, I couldn't tell you as I don't have TMC here.
Posted Oct 25, 2011 · 21:36 UTC#52
I'll double check but i'm pretty sure commented out only the Primo sys.txt, removing all mention of where the maps might be. I then copied the UK map, buildings, poi and base map from igo to primo. I then deleted the save folder on the user folder. I went through a reset defaults in primo. It returned an error about not finding the maps but allowed me to continue whereupon it put net to Big Ben. Nit Paris anymore. Tomorrow I'll launch it in test mode and see what happens.
Maybe pioneer released various different models incompatible with this hack? A far as I know it is a bog standard F900BT of the euro variety.
It centers on Big Ben, thats great news! That means that it is either the building file or the POI file which decides where the map is centered before you get a GPS fix for the first time. Mine centered on our Parliament building and then gets a fix on my location when I started it for the first time. I am optimistic that Primo does not like multiple building files and won't center on your location if it initializes in another county. Perhaps it will turn out it worked out for the best that your system couldn't find any map files. I look forward to your results with only one of each map/poi/building/dem file.
Edit: Please disregard the last statement. I managed to simulate the same GPS problem you are having. I use Primo 100% of the time, but today I shut it down and started it up a few minutes later while driving. It then would not show a location on the map but had a fix on 11 satellites. I deleted the save folder and restarted and problem went away. It seems if you don't get a fix in the same location you shut the unit off this problem sometimes occurs. I found the file which stores your last known location in the save folder. Tomorrow I will try to simulate the problem again, delete that file and see if it centers on my location of the map afterwards. If it works I will add a script to delete that file before launching Primo and add it to the main downloads, as well as separately for those who already have AVICnet installed so they can apply the patch without deleting everything and starting from scratch.
Edited Oct 26, 2011 by ryar
Posted Oct 26, 2011 · 13:02 UTC#53
Good to know that I'm not mad.
As an update. I couldn't get Primo to find my map in primo>content>maps (UK and basemap) so I returned the sys.txt to the original. The maps were found, I got a "your maps appear to be out of date" message and then the system located me immediately at my true location! I didn't delete the save folder.
Posted Oct 26, 2011 · 15:18 UTC#54
Has anyone in the uk managed to get TMC traffic working with the version of primo contained within this mod?If so,can you tell me how please!I did have it working spasmodicly with the previous version but can't get it going on this one.Thanks.
Posted Oct 26, 2011 · 16:07 UTC#55
I will check, I'm pretty sure it is working though.
Another question. Rather than a USB modem is it possible to use a USB wifi stick? I was thinking of tethering to my Android phone.
Edited Oct 26, 2011 by palexr
Posted Oct 26, 2011 · 17:49 UTC#56
Another question. Rather than a USB modem is it possible to use a USB wifi stick? I thinking of tethering to my Android phone/
I know it worked with the download in http://avic411.com/index.php?/topic/32522-primo-for-avic-f-series/ but have noticed in the download with this thread that there is no TMC folder in the contents folder.Also there is no reference to TMC in the sys.txt. I did replace the new Primo folder with the older one,but then i couldnt get a GPS fix.I am 95% there,just need a working TMC and I will a happy bunny!!
Posted Oct 26, 2011 · 18:37 UTC#57
I TMC works - the SYS I did not do anything...
Posted Oct 27, 2011 · 01:59 UTC#58
Not much to add...just wanted to reiterate how much fun I'm having with this release.
Posted Oct 27, 2011 · 06:27 UTC#59
OK, I believe I figured out a little bit more for those who are having the the problem with the map not showing the current location despite having a GPS fix in Primo. It seems Primo does not like to be shut down abruptly without going through its exit cycle and causes this bug to occur on some units. An abrupt shutdown happens on my f900bt whenever I shut off the ignition, unlike the standby that occurs in my f500bt. Oddly, if the unit get a GPS fix in the same area it was shut off it will show my location on the map.
For anyone having this problem I have not found a way to reverse it, your only option at this point is to delete the entire save folder (located at my Flash Disk\User\\UserData\Primo). You can copy the user.upoi file before deleting and put it back after the unit initializes to retain your favorites (pios). When you start up and initialize for the first time, choose all your options and make sure to choose the GJ skins in the display settings (day and night). From now on when you are using Primo allow it to exit before shutting off the ignition, you can do this by tapping the bottom bar on the map screen and then the exit icon in the bottom right. You can also add an exit icon to the quick menu. Note these options are only available with the GJ skin. I will fix the Close Primo button to close the process rather then kill it and re-upload the packages when I have some free time; in the meantime avoid using it if you are experiencing this issue. For those who do not have the problem with the map not displaying the current location this post can be ignored.
The weird thing is my f500bt never had this issue after using Primo on it for nearly 3 months, only my f900bt has recently had this problem. Perhaps the battery in the f500bt prevents it from having an abrupt shutdown?
If you are experiencing this issue please provide some feedback whether or not these steps worked for you, and provide details if the bug returns.
Edited Oct 27, 2011 by ryar
Posted Oct 27, 2011 · 06:44 UTC#60
It would be nice, but I wonder how many USB wifi sticks come with Windows CE drivers and software?
That's good to hear! I am still anxiously awaiting my OBDII reader and have located a few more OBDII Windows CE programs. Man, shipping takes forever from China!
Posted Oct 27, 2011 · 08:31 UTC#61
Thanks Ryar, I will do as you say. I had noticed that it seemed to be something to do with how Primo stops working, but I haven't been using the GJ maps and so didn't have the exit icon. must've missed that at the start. Unfortunately removing the Save folder is not a 100% guarantee that it will work the next time. It works sometimes, sometimes not. What I have found by trial and error to work is replacing all the files that are in My flash disk which are not in folders. These:
So far copy the ones from the download over the ones on the unit works, though it isn't really a viable solution.
I will try your suggestions.
EDIT
I'm not sure what I am supposed to see with the GJ night and day skins? I selected them but couldn't see any difference or a way of getting to a "exit" button? I did it in Primo not Primo w/o. I don't get a bottom bar in the map screen? I remember that in your other download from your "Primo for AVIC F series!" thread that Primo had a power off button in the top menu, is that what I should see?
EDIT 2 OK, I've got the GJ skin going and can see the bar at the bottom. there are a lot more options going on there. TBH, I prefer the default one, it is less cluttered and looks better. I have re-activated the exit button on the on the main menu in the default skin. Will this close Primo in the way you describe? I'm using this button and it seems ot be working with some consistency.
EDIT 3 Does TMC only work in GJ skin? Nope got it working in the Default skins as well.
Edited Oct 27, 2011 by palexr
Posted Oct 27, 2011 · 08:52 UTC#62
Can I copy the maps from my Garmin nuvi(registered to me and activated)and just paste it into the Garmin folder in avicnet?Will this work??Exciting times on 411 at the moment!!
Posted Oct 27, 2011 · 14:28 UTC#63
Nearly there.TTS working on both primo and primo2.TMC working on primo 2.only problem is on primo I have the speak command icon(microphone)instead of the traffic icon.When it is all working correctly I will put a link for anyone in the UK to try it.
Posted Oct 27, 2011 · 22:10 UTC#64
Is there some way to get ezrider to unload itself when you launch something else? It seems like its still running.
Posted Oct 28, 2011 · 01:43 UTC#65
You should be able to unless they are licensed for your other unit. I remember
The microphone can be removed in the settings, but I can seem to find where!
In the menu settings you can have iGo close when you start a new application; I don't think it frees up all the memory using this method however. You can put a kill command in the .mscr file for what you are trying to launch. For example, the primo.mscr in the primo2 run folder has the command:
kill ("ezrider")
kill ("ezrider.exe")
which successfully ends the ezrider and frees up most if not all the memory it was using.
Edited Oct 28, 2011 by ryar
Posted Oct 28, 2011 · 01:55 UTC#66
Palexr, thanks for the info on which files you replace to regain the map position. I tried it and it worked once, but not a second time. You are right, deleting the save folder worked yesterday but doesn't seem to every time. What I have found to work best is change the sys.txt to gps port 5, launch, reset to defaults, delete save folder, restart unit, change back to port 6, launch. It worked each time I tried it so far, but it isn't feasible to do every time. I can confirm that each time I allowed the unit to shut down properly it restarted with no issues what so ever and my location is displayed. I have read the gpspara.bin files are the last gps coordinate/positions but didn't delete those.
As you have found the power button you know it can be enabled by changing the sys.txt show_exit=0 to a 1. I took it out because it didn't seem to work properly in this newer version of Primo (May 2011). I think I will revert back to the Feb version because I didn't seem to have as many issues with that release. Using that button it should exit properly. Sorry, I don't have TMC here so I can't tell you if it is working on the GJ skin.
Posted Oct 28, 2011 · 08:39 UTC#67
Decided to take a breather for a bit on this.
With the problems I was having with Primo I was relying on iGO and the interface was annoying me so I deleted everythiing and re-installed my very first back-up of the stock Pioneer iGO that I had made before installing any mods way back when. Using AVICnet had taken the version down to 3? The stock one had an upgrade to 4xxx1. Teh only mod on there right now is removing the nag screen.
BTW, I can still run Primo off a SD card. If I boot into testmode and launch it from a folder on the card it works. No sound obviously but hey. I have tried it twice, making sure to exit via the GJ exit button and so far that works.
As you say, deleting the files or the save foldeer isn't a 100% method. However, using the GJ exit button didn't seem to work 100% of the time either hence the delete.
Posted Oct 28, 2011 · 15:21 UTC#68
Let me ask - she would be added to the origo iGO8 info about speed??
Thank you Pat
Posted Oct 29, 2011 · 21:49 UTC#69
Thank you Pat
Sorry Pat, I don't quite understand what you are asking. Can you please rephrase the question?
Edit: A little off topic but what model do you have? Is it a f900bt?
Edited Oct 30, 2011 by ryar
Posted Oct 30, 2011 · 01:49 UTC#70
Well, I found out a little more regarding the not displaying location on the map issue. I can get it to display my location by remaining stationary when launching Primo, and at that point it navigates as it should. If the car is in motion when launching the issue occurs. After it happens once it is only possible to reverse by doing a hard reset (reset button on the face of the unit or hard reset option in Avicnet settings) and remaining stationary until it reboots twice and launches Primo.
edit: Upon further testing the vehicle does not need to be stopped for the entire hard reset, just when Primo is launched.
I'm not sure if it is the gyro sensor (I did the hardware bypass), the speed wire (I grounded mine), or the stock iGo manipulating the gpspara.bin files (I changed the sys.txt to port 4 so it never gets a signal), but Primo does not want to launch when moving. So far as I can tell, the only units having this issue are the f900bt and x910bt. My f500bt runs avicnet perfectly, perhaps because it doesn't have a gyro sensor or speed wire.
Can anyone who is using avicnet and/or Primo comment on what unit they have, it they are/are not having this issue, what bypass they have used and what firmware they are using? It would be of great help towards solving this issue if we can get some information together, the more the better. Thanks in advance!
It looks like people with other devices are having this problem too: http://www.mobilepas...hp?f=210&t=6803
http://www.mobilepassion.org/viewtopic.php?f=210&t=1958
Posted Oct 30, 2011 · 02:43 UTC#71
I'm not sure if it is the gyro sensor (I did the hardware bypass), the speed wire (I grounded mine), or the stock iGo manipulating the gpspara.bin files (I changed the sys.txt to port 4 so it never gets a signal), but Primo does not want to launch when moving. So far as I can tell, the only units having this issue are f900bts and x910bts. My f500bt runs avicnet perfectly, perhaps because it doesn't have a gyro sensor or speed wire.
I have af90bt with 3.1 or 3.02 firmware with both hardware bypass and ground speed wire. I do have problems getting the gps working on both on Avicnet and primo.
Jimbo
Posted Oct 30, 2011 · 15:51 UTC#72
Jimbo
Thanks for the response Jimbo. One more question; does Primo display your position on the map after a hard reset (assuming you are stationary when you launch)?
Posted Oct 30, 2011 · 16:17 UTC#73
No... It show Buildings and says "Auto detecting GPS".
Posted Oct 30, 2011 · 19:04 UTC#74
That is a different issue all together. Check Primo's sys.txt and make sure under gps it reads: port=6 and baud=9600. If you shut off your port splitter you need port=7 and have to kill iGo before launching Primo (Primo w/o iGo8). Note Primo w/o iGo 8 is loacted in the APL2/Primo2 folder.
Posted Oct 30, 2011 · 19:44 UTC#75
Same problem here (Netherlands), the unit keeps om saying "Auto detecting GPS" location is somewere in Berlin with 3d buildings. Port and baudrate confirmed in sys.txt. The unit is a F900bt with I think firmware 3.02. Also tried Igo8 on port 6 and Primo on 5, no succes.
Will try to change data.zip --> config\devices\pioneer746ew.ini
Thank you for you afford so far Ryar, great release!!! Anything else we can try to get a fix?
Page 3 of 28
