pvdhelm - There is no icon nor files for Garmin. I took it out a long time ago since it was such a dated program and current maps are hard to find. Check out the italian avicnet, I think it still has garmin included. The link is in the first port of this thread. Try 7ways, it is a much nicer looking program and the maps are easily available.
The memory problem with stock iGo is due aggressive memory settings in the stock iGo's sys.txt as follows:
[debug]
max_memory=29980000
If you comment out or delete the max_memory line you won't get those memory errors anymore. I set it up like that so the stock iGo uses minimal memory so that Primo can run without issue simultaneously as stock iGo.
phil15 - As I stated above, I have aggressive memory settings for the stock iGo and this is the reason it causes the resets. I checked on my unit and it does the same, I forgot that I had recently changed the memory settings to the lowest possible on the stock iGo. Comment out the line as above if you choose, but note that Primo may have memory problems if you do so. I never use the stock iGo anymore, only Primo and this is the reason I set it up like this. I think I might set up my unit to launch Primo when the map button is pressed and maybe hobdrive when the menu button is help down, no more stock whatsoever. Stock iGo is required to be running in the background in order to access the avicnet menus and also for button remapping and this is the reason I don't want the ezrider process killed upon launch of Primo.
