AVICnet 2.1 for AVIC F series, working OBDII! Updated 2014/04/30
By ryar · Oct 19, 2011in Completed Mods/Themes💬 700 posts👁️ 270,055 views
Page 27 of 28
Posted Apr 19, 2014 · 08:52 UTC#651
hello,
i have a big problem, i've bricked the av.exe on my f920bt and now it doesn't start
can anyone please help me with this file or with the original back-up folder?
Posted Apr 19, 2014 · 18:21 UTC#652
It won't work on your F920BT, only the following:  F500BT, F700BT, F900BT, F90BT, X710BT, and X910BT.
If you didn't flash a new wince image from the service menu simply revert to your backup and you should be ok.
If you did flash a new wince image find the latest one for your unit and flash that.
Edited Apr 19, 2014 by ryar
Posted Apr 19, 2014 · 18:29 UTC#653
Ryar I think I got mine working good with 2013 maps...however in primo the time is off...time is correct in radio and default maps. I can't find setting for it ..I also see no difference between primo or primo2
Posted Apr 19, 2014 · 22:15 UTC#654
ryar, thanks again for keeping this unit relevant. Really want to get this OBDII feature running. Do you know if anyone has had success with the ELM327? If not, can you point me to the one you have?
Posted Apr 24, 2014 · 21:19 UTC#655
Ryar,
First of all I want to thank you for the great work you did. I wonder if there is a possibilty to out the stock igo maps also on the sd card. Am I right, that it won't work at the moment because there is no run folder in the stock igo folder? I read something like there is a need for at least one map file on the flash drive in the italian forum, but I translated with google because i don't speak Italian and I'm not sure if i understood right.
Moreover i deleted max_memory line to avoid system crashs of the stock nav app, but it didn't change anything. The stock app keeps crashing when it comes to the point to show the map. Have no idea why at the moment.
And last but not least IGo just shows me English as system and audio language, although i copied all the language files back.
At the moment I haven't found a solution for that, would be nice to be able to change everything into German.
But these are peanuts, the job you did is extraordinary.
A plus.
Edited Apr 25, 2014 by Bummel
Posted Apr 29, 2014 · 08:18 UTC#656
I have the same problem on my F700BT , when I press map button unit restars
"- TMC should work with stock iGo, thanks matyana " - but how to check it while stock app keeps crashing ?
Posted Apr 30, 2014 · 08:25 UTC#657
I don't know why it is crashing, maybe the settings need to be adjusted rather than deleted or it holds it's last value.  Last I checked increasing the values stopped unwanted behavior; playing with this helped me find the lowest possible memory usage on the stock igo.  I don't use stock iGo and mapped my buttons so the Map button launches and controls Primo, there is a download in the second post which will allow you to do so.  I even deleted the contents in my iGo/GFX folder to save space so sorry I can't check to see what the issue is.  Memory settings in the sys.txt is the only thing I played with however so it must be the issue.
Edit:  I think I found it, can someone copy this onto their unit and let me know if it still crashes when you press the map button:
my flash disk.rar
Edited Apr 30, 2014 by ryar
Posted Apr 30, 2014 · 15:00 UTC#658
Hello Ryar,
First of all I want to say thanks for trying to help us solve this reboot problem.  I have tried your fix from the above post and am sad to report that it didn't change anything on my unit.  Please be advised that I am using your flashdisk copy of Avicnet, not the original, and have made no changes to the memory settings.  Thanks again for your efforts!
Redeye
Posted Apr 30, 2014 · 20:35 UTC#659
I grabbed some files off my test unit right before it bit the dust and tried them and now it is working.  I think it was a corrupt file or something, sorry about that.  Anyways, I re-upped on the 2nd page of this thread.  If you don't want to copy the whole thing just copy and overwrite everything from the my flash disk/apl2/iGo folder except the content folder onto your unit if you used the 14/04/05 release.
Posted Apr 30, 2014 · 22:09 UTC#660
Great job ryar.....works like a champ....thanks so much for sticking with us!  I prefer the stock iGo when I'm driving locally but use Primo when I'm traveling.  Your efforts made that possible!  My hat's off to you!
Posted May 03, 2014 · 18:31 UTC#661
Thanks Ryar for your help. Just came back from a holiday trip and will try to update tomorrow. Moreover found out that you have to copy apps you want to start into a your storage device/apl#/appname folder or it won't find the apps. Did so and running Igo from the sd card.
# is determined by the path on the flash disk.
appname by the name of the folder on the flash disk.
For my unit (f900bt euro) Primo had to be in the folder storage card/apl2/primo3.
I used german language from the italian avocet, works fine, but not everything is translated. I use current maps can be found on the links given on the second page of the thread.
Furthermore I am looking for a compatible bt dongle. Any suggestions?
Also bought a elm327 bt module. (read all posts first order later, is something I would recommend :) ) but i m not sure if it turns off so i will probably order the usb version also, cuz it's less than 20 € on amazon.
Next thing is to connect an active usb 2.0 hub so i can connect more than a storage device at once. Also got an huawei e220 here which will be the next to be connected if the usb hub is working.
So far
Posted May 04, 2014 · 11:16 UTC#662
Ryar big thx for your great job, but I would like to report some problems with new update.
First is TMC and it is not new problem, changes in ini file with ports number for msdn and tmc funcions doesn't solve it. Stock iGo is still not receiving TMC messages (in Poland) Still frequency scans but nothing is found. In Primo TMC is working only if ezrider process is killed before runnig primo. Maybe it is possible to divide the port with TMC as in the case of GPS? You do not need to kill ezrider.
Second problem is internet and modem menager. I use huawei e1550 modem, i setup everything and it is conneted. When i try to open opera mini, i have info to check network settings, so I use modem menager to check my APN, but My settings are not saved. As I wrote the modem is conneted, i don't know what is wrong.
If some of you could help I'll be very grateful :-)
Posted May 28, 2014 · 18:05 UTC#663
New update looks good, but is it for F700BT devices ? On my unit after udate, bluetooth stop working, any idea?
Posted Jun 11, 2014 · 16:48 UTC#664
ryar, multiupload is down :( only redirects to some ad sites, can u reup plz?
Posted Jun 13, 2014 · 02:15 UTC#665
Hi Ryar
The links doesnt work anymore. Can you please repost? Does anybody has screen shots of the mod?
Posted Jun 18, 2014 · 01:03 UTC#666
anyone have copy of these files, megaupload is dead... :(:???:
Posted Jul 10, 2014 · 13:34 UTC#667
its not that the links are dead, its that they are unreachable from the US. I used a proxy last time I DL'd them but the speeds were horrid.
would be nice if someone uploaded them to a US friendly site.
Posted Jul 12, 2014 · 00:20 UTC#668
Well, I'll be in europe in 2 weeks, guess I'll grab them then...
Until then, I at least got updated 2013 maps off ebay for cheep.
Posted Jul 21, 2014 · 13:52 UTC#669
man...so looks like none of the proxy sites are allowing access to multiupload from the USA...
Ryar, you think you can put this on a USA friendly site?
heck put it up on drop box...i can gie you access to my drop box which has 50Gb.....please let me know...
i am on the older version that somone posted on page 2, but have been having issues. no gps grabs a lock even though 10 satilites are shown. also the settings menus are not avail until i go into primo 2 (the fartehst to the right on the navi menu) then the Avic symbol has the reset text.
also no bluetooth, & no regular system menu...
& been having constant reboots...
I want to get a stable copy, that way i can add my changes for hobdrive & WolfNCU (i got that working now :) )
Posted Aug 07, 2014 · 19:13 UTC#670
any good fix for primo2 gps searching for sats? it works fine if I stop the vehicle and reboot they system
Edited Aug 11, 2014 by sgtarky
Posted Aug 07, 2014 · 21:36 UTC#671
Sorry but also in europe are the multiupload links down. I only get a client to download.....iLivid download manager, but after then nothing more.
Please help me to get the right link so that I can try this on my F910BT to install because I am getting really sick of the Igo default navigation.
Thankx
Posted Aug 14, 2014 · 15:26 UTC#672
Ryar, please post to a better / more accessible file server...alot of users in cannot access these
Posted Aug 14, 2014 · 18:52 UTC#673
It looks like multiupload is down, I will re-up on mega.  Just one small change, with the "map button launches primo" option a long press on menu will take you to hobdrive from the AV screen where as it would not before.
Edit:  Upload failed after several attempts in mega.  Someone want to suggest another upload site?
Edit 2:  NVM, re-upped on mega.  Link in post #2
Edited Aug 17, 2014 by ryar
Posted Aug 27, 2014 · 18:20 UTC#674
still unable to DL..
i am able to hit the MEga site, & put the code in to decrypt,but then it errors out & says retrying
Posted Aug 27, 2014 · 18:32 UTC#675
nvm....looks like its running now
Page 27 of 28
