Forgive if it is here as I am a bit slow today is appradio + for Firmware 2.5 out and in english, I have looked through the posts but cannot see it.
Robbie
Robbie
Robbie
Yes appradio plus 2.5 is out, i believe all versions are multi lingual now. I think its on pg 21 post #313.
As to my problem i had, i have solved it. figured i would post the solution, just in case ne one else has these problems.
1.) Use appradio plus install files to access Win CE
2.) Go into the control panel, then memory management, switch to the Nand (built in memory) and unmount it.
3.) from here proceed to format that same partition.
4.) I rebooted here not sure if necessary. Will now auto load WinCe,
5.) Go back to memory managment and select Nand device then create a new partition named Nand
6.) Take an SD card and install latest firmware onto (current version 2.5)
7.) Copy all files from sd onto the Nand storage
8.) Reboot, install new boot files (2.5 boot files), reboot
9.) then continue to reinstall firmware 2.5, once all those files are complete you are almost done
10.) now download and install appradio plus 2.5, and give all respect to Sserhy
Hi. I'm a complete novice when it comes to tech things. I just bought the new app radio from car toys and had it installed there in my 2012 A3. I would like to install the app radio plus because I can't stand the warning messages and don't care for much about the radio interface except for the iPod and Bluetooth hands free.
I have an iPhone 4
The only exposed wire for the radio is the iPhone connector, is there supposed to be a USB plug that I would connect to to download new software to the radio?
Is there anything else I need to know about installing app radio plus?
If the app radio plus upgrade works and I can basically control my phone from the radio display I would be truly thrilled as this would be a huge upgrade. If the plus app merely allows me to use the appradio without clicking ok or ignore 3 times everytime I turn on my car I would be satisfied and would no longer feel I need to return the "crap radio."
Thank you!!
Had a brief read through this post . But cant find my answer.
Basically everything installed fine
But ! when i run certain things on the appradio .. Such as explorer or anything sortta windows related , i get the appradio screensaver/demo mode . Basically its a screen telling me how to swipe ? looks like something that would be on there demo machines in store.
Has this happend to any one else ?
*Edit* After another reboot , seems to not do it any more ![]()
I realize now I bough appradio 2. Was that a mistake? Can I install appradio plus through USB on sph-da100 appradio?
Installed Igo with some files located on here , great stuff ![]()
Does sound work on installed CE applications ? i see mention of it throughout this post .. But can any one clarify for me ?
Appradio+ is worth it just for the satnav !!turns a 200£ device into a £600 device
For the moment they cant access to the sound driver. That's why we havent any sound in the Windows CE mode. But lobokiller is working on it.
Interesting .. I actually find it amazing you can still control the radio/music while using IGO . I was sortta expecting it to close down the whole appradio GUI to run it .
Once sound is sorted , it will make a even better stereo !
My opinion:
I actually use this config:
Jailbreaked Iphone with displayOut and Tomtom.
Appradio "normal".
I use Display out to Have my Tomtom on the Appradio Screen when i click on the "Ipod Mode"
I can also use Tomtom and still control my Radio.. But not the Ipod.
I think next Update will really change the functionnement of the Appradio and will give us more opportunities.
(Excuse my english, im french ^^)
My opinion:
Appradio "normal".
Pourquoi n'utilise tu pas la derniere version demike de appradio extention? Tu pourra controler tomtom depuis ton appradio ![]()
Perso je trouve dommage de devoir user les ressources de nos iphones pour le gps alors que l'appradio est capable en autonome de le faire et c'est bien plus precis et fluide... Et de plus sa permet d'utiliser l'iphone pour autre chose
C'est vrai que mike qui est un amateur (amateur éclairé, mais amateur quand même) réussi en partie à faire dialoguer le tactile de l'iphone avec l'AppRadio.... Pourquoi Pioneer n'y arriverai pas !!!
Pioneer ne veux pas c'est sa la difference, ce sont des cons chez Pioneer... Desole de le dire comme cela, perso moi plus jamais je prendrais un autoradio de cette marque... Traite le client aussi irrespectueusement je n'ai jamais vue cela.
Funny question: If I install AppRadio Plus, can I undo it and reset the unit as factory default?
Yessssss..... no problems..... You can very easily uninstall
Merci pour ce tuto
Apres le JB peux t-on utiliser TOMTOM et FB depuis l'appradio ??
Merci
Non !!!! juste iGo !!! sauf si tu trouves Tomtom pour Windows CE 5 processeurs MIPS
mais tu peux utiliser tomtom et fb grace à appradio extention beta 2 !!!
Hi i was wondering if any one could clearly explain what each setting does?
if u press the new appradio plus button, located behind (same button) as the original settings button.
This opens up the appradio plus screen,
scroll over to the next slide and there is a setup button press it,
now a lot of different settings can be edited.
Stuff like...
Enable hot button
Change location of menu button
Can anyone explain exactly what each setting does when turned on and off.
there is a list of 8 different settings, i understand the timezone ones (which dont seem to help anyways)
please list all settings as 1-8 and what each does.
Huge Thanks in advanced.
Stuff like...
Enable hot button
+1
Stuff like...
Enable hot button
Wait, what am I missing?
I installed AppRadio Plus and I don't see such menu options.
Just to make sure, can you guys tell me if I missed something? This is what i did:
So what did I missed?
Thank you guys.
boujour je m'intéresse au jailbreack de mon appradio tout neuf mais je l'ai mis a jour avec la version 2.56 !!!
ma question est-il possible de le cracké grace a la derniere version proposé sur ce topic ou dois-je attendre une autre version
merci a vous !!!
merci a vous !!!
Pour le moment la derniere version fonctionne avec la 2.50, si tu veux installer appradio plus, tu dois downgrader
Thank's for all!!!
I have resolve my problem on my Radio regarding wallpaper's problems
I have install the firmware mod and with explorer I have modify the Wallpapers folder on the system.
:-P
:-P ![]()
Hi to all, i 'm not sure but seems that new firmware have an improved radio fm reception ...
so the same question again and again ?
can the appradio work with appradio extension on 2.56 firmware ?
is there a new version on the "road" ?
