"update build - version 1.0.222 (now in version number indicates the firmware version, for which the assembly is made​​), respectively, for the new firmware version 2.45 is also prepared1.0.245 build,
what has been done:
- Added configuration management tool assembly (runs from the additional menu)
- Added ability to set the action after startup (the entrance to the application menu / submenu run), the action set on "utilities settings"
- Replaced the keyboard and added keyboard control utilities (show / hide)
- Changed the appearance of additional menu interface, similar in style as appradio (section applications) (thanks DjSKAM)
- Fixed minor bugs
I note that the results of tests I did not like new firmware 2.45 , so while I would recommend not to rush to change the firmware"
- Serhy
here is links for download:
appradio plus 1.0.222
appradio plus 1.0.245
pass: avic
