Jailbreak Appradio / Appradio Plus
By Dejan · Feb 02, 2012in AppRadio, AppRadio 2, AppRadio 3💬 621 posts👁️ 281,903 views
Page 3 of 25
Posted Feb 11, 2012 · 17:19 UTC#51
With the files in the memory card, just have the card installed when you boot the radio. It is the same process as updating the firmware.
It's not installing when I do a hard reboot. Which files from appradio + do I copy?
Posted Feb 11, 2012 · 17:34 UTC#52
This is how I have it on my sim card:
APL
CE66
SYSTEM
USER
WALLPAPER
ce66tool
ce66tool.mscr
mortscript
readme
setup
setup.mscr
swtup_.mscr
toolhelp.dll
Edited Feb 11, 2012 by ronsno
Posted Feb 11, 2012 · 18:49 UTC#53
Okay I got it working and works pretty good. The version is still in another language until you bring it up and the additional screen is still in a language other than english. Anybody out here with the skills to convert all the programming to english? I figured everything out but it would be nice to be in english :mrgreen:
By the way thanks to everyone who worked on this.
Posted Feb 11, 2012 · 20:20 UTC#54
If you want, you can translate it in english :-) just open with wordpad all ****.mscr file :-) and translate all text in french (or russian) to english :) use google translate for help
Posted Feb 12, 2012 · 19:49 UTC#55
I started out with 2.22 and AppRadio extensions after iOS5. Even though iOS5 broke much of the app ext it still worked pretty good for me. I updated to 2.45, and it broke more of app ext, but I would say it seemed faster. Yesterday I upgraded to 2.22 AppRadio +. It did all as advertized, makes all warnings disappear, but it looks buggy and at times other screens come up and at this point is not fully translated into English. I think it's a great start, but needs some fine tuning. This morning I went back to Pioneer 2.22 and updated to the latest AppRadio Extensions, I must say this is by far the cleanest solution to date. I see some people have found some bugs and im sure Mike will get them fixed quickly. Some observations:
Warning screens show up as apps are loading, but once the app is loaded they disappear. So have a little patience.
It takes a while for the iPhone to connect to Bluetooth. Again need a little patience. You can disconnect your phone and Bluetooth still works.
My relay parking brake bypass is working great.
I do not like the AppRadio phonebook, you can not scroll by letters. I find this aggravating and dangerous.
I don't like the contacts for phone use much either. If you use this to call someone it delays quite a while before it indicates you're connected, meanwhile the person on the other end is wondering what's going on.
In addition to AppRadio Extensions, I have Handsfree, voice activator, and activator loaded. Between all of theses I can talk to my iphone and get it to load apps Handsfree, works pretty slick
Overall we are closer no thanks to Pioneer!
Posted Feb 15, 2012 · 04:36 UTC#56
So i Finally got my sd card and tried to install Appradio+ just to learn that i have 2.19 firmware. So I should I switch to 222 or 245? it seems like 245 with Appradio extensions is not that bad (considering that i think i have almost all the same nag screens now)
List of nag screens that I've encountered or heard about.
  • OK button when turning on - All versions. Appradio+ can skip this.
  • Parking break on->off-> on - 2.19,2.22, 2.45 Cant be removed but is skipped if app is open ( but still cant type in maps app)
  • Alert on the phone asking to launch appradio app - 2.45. Appradio extensions Skips that (?)
Edited Feb 17, 2012 by Vendigroth
Posted Feb 15, 2012 · 17:17 UTC#57
I do not like that pioneer forces us to start their application "appradio iphone" in version 2.45. if I just listen to ipod ?
Posted Feb 16, 2012 · 07:51 UTC#58
So i Finally got my sd card and tried to install Appradio+ just to learn that i have 2.19 firmware. So I should I switch to 222 or 245? it seems like 245 with Appradio extensions is not that bad (considering that i think i have almost all the same nag screens now) List of nag screens that I've encountered or heard about.
  • Parking break on->off-> on - 2.19, 2.45 Cant be removed but is skipped if app is open ( but still cant type in maps app)
  • Parking break on - 2.22 (almost like the one above) Not sure about this one. never had 222.
Hi,
Is there a way to know you firmware revision without booting on a SD card ?
Posted Feb 16, 2012 · 18:11 UTC#59
Hi,
If you are on 2.45 it says it in the options menu. other than that i don't think there is.
Posted Feb 17, 2012 · 08:00 UTC#60
There is nothing written in my menu...So I guess I have previous revision. I'm gonna buy a SD card and try Appradio+ installation.
So what are you suggesting : upload to 2.45 and then install Appradio+ or stay with current revision and install Appradio+ ?
Posted Feb 17, 2012 · 16:47 UTC#61
stay on 2.22
i'm tested new firmware 2 weeks, and now downgraded...
Posted Feb 20, 2012 · 15:56 UTC#62
Any update to the English version?
Posted Feb 21, 2012 · 23:05 UTC#64
how is everyone here liking the appradio plus... im debating if i should install it.. firmware 2.45 is getting annoying.
Posted Feb 22, 2012 · 00:16 UTC#65
Which part of it ?
Mine is on 222 so not too bad. Just got Igo working with maps and everything. next ill clean up the main menu and everything should be good
Edited Feb 22, 2012 by Vendigroth
Posted Feb 22, 2012 · 02:31 UTC#66
Which part of it ?
well im on pioneers new 2.45 firmware.. i havent tried the appradio plus firmware.. can i update it if im on 2.45 so i can try it out
Posted Feb 22, 2012 · 02:34 UTC#67
You can go back and forth. There's threads here explaining.
Posted Feb 22, 2012 · 02:39 UTC#68
cool thanks.. ill give it a shot and see if i like the appradio plus
Posted Feb 24, 2012 · 18:50 UTC#69
new version of app radio plus will be available on this weekend....
please be a patience
Posted Feb 25, 2012 · 02:55 UTC#70
Thank you for all the work you've done with this!!!!
Posted Feb 25, 2012 · 12:22 UTC#71
can we JB the appradio, or wait the new version?
new version of this JB in french coming soon? or just update the appradio original OS?
i dont know how version i have on my appradio how i can check that?
many thanks for the future response
peux ton jailbreaké tout de suite l'appradio ou est il preferable d'attendre la nouvelle version?
la nouvel version sera t-elle traduite en francais? (auront-il besoin d'aide je suis pas parfaitement bilingue mais je peux aidé)
c'est une nouvel version de JB ou de l'OS de pioneer?
comment savoir quel version j'ai sur mon appradio? comment puis-je la trouvée?
Merci pour les future reponses ;)
Posted Feb 25, 2012 · 17:35 UTC#72
I hope U won't translate the french messages... :? Your english is not worse than your french :-P
Posted Feb 25, 2012 · 17:39 UTC#73
Salut, suivant la version du firmware de ton appradio je te dirais quelle version installé, patiente qq jours que la nouvelle version arrive :-) appradio plus est en russe c'est moi qui fait les traductions si tu veux donner un coup de main no pb :-)
Edited Feb 26, 2012 by Dejan
Posted Feb 26, 2012 · 10:12 UTC#74
i'm french, that's the response lol so my french it's not perfect but my english... no word for explain :D
Ok je patiente alors, ar contre je peux aidé mais pour la translation francais => anglais, car je ne parle pas du tout russe :S
Posted Feb 26, 2012 · 19:24 UTC#75
Tkt pas je m'occuperai de la traduction ;-)
Page 3 of 25
