🔒 Locked
AppRadio Extensions 2.0 Beta - Full iPhone control
By mikedecaro · May 06, 2012in AppRadio, AppRadio 2, AppRadio 3💬 2,444 posts👁️ 945,070 views
Page 16 of 98
Posted Aug 18, 2012 · 20:11 UTC#376
After a long install, I finally have my appradio 2 installed with e-brake bypass. I am running appradio firmware 8.15, software 1.7.3, and appradio extension 2.0 beta. All of the compatible apps(car media player, nav free, dashcommand) work. when i push the icons for the appradio extensions apps nothing happens. it shows that I am pushing them(it highlights), but none of the apps will actually open. I have tried updating the firmware, but that only disables the ebrake bypass. Any help would be greatly appreciated! side note; mike this is an amazing job you've done here, keep up the great work and thanks!!
I'm also running an iphone 4s on 5.0.1
No I am unable to uninstall appradio extensions from cydia(tries to install CHD, which is already installed and doesn't complete the unistall). Any help with any of this would be great. thanks
Posted Aug 21, 2012 · 18:52 UTC#377
I figured out how to force uninstall appradio extensions 2.0(wouldn't unistall from cydia) so I could start again. Everyhing works excellent until I put appradio extensions back on, the new apps(extensions apps) show up, but do nothing when I push them. I know this is still beta, but was wondering if had a solution or even the same problem?
Posted Aug 21, 2012 · 21:43 UTC#378
hey guys, bought the SPH-DA100 today, havnt installed it properly yet, but have plugged it in to play. Should I upgrade to firmware 8.17?
How do I go about finding out my current firmware?
Finally, the parking bypass, do you have to use a relay or can you just wire it to an earth or 12v live?
Posted Aug 21, 2012 · 21:54 UTC#379
I would avoid 8.17 for now do to bypass reasons.
Im guessing by the fact that you use the word "earth" instead of "ground" that you are probably from Europe or somewhere else other then the US. If thats the case, traditionally "earthing" the the P brake wire will achieve the bypass without any other complicated schemes. Please keep us posted however and update the official bypass thread for this unit. Good luck.
Posted Aug 21, 2012 · 21:56 UTC#380
Reinstall AppEx until it works. I had the same issues when I first installed and that is what fixed the issue for me. And be sure you are installing the file from the first post in this thread.
Posted Aug 22, 2012 · 05:51 UTC#381
Ha, one word slip and the English man is revealed!
Thank you very much for your response VBLUE42, when I get round to installing it I will report back.
Everything seems to work for me, I do get the occasional black screen and some AppEx apps are a bit slow to respond and dont always scroll, but I am guessing Mike is working on this? Any idea when the next update is due?
Thanks again Mike!
Posted Aug 22, 2012 · 06:48 UTC#382
Nope, last I saw he was a little stumped on an issue and was trying to figure it out. Im sure he will let us know soon.
Posted Aug 23, 2012 · 08:07 UTC#383
After many fresh installs of the App and even after a complete phone restore and fresh jailbreak, the siri icon shows up(doesn't work) and none of the AppEx apps will even show up now. the only thing that is working is the custom wallpaper, the movie skip, and showing the clock. Any suggestions. These looks so good! I just want to get it up and running.
Posted Aug 24, 2012 · 14:28 UTC#384
Hi Firstly many thanks for this I have just bought a appradio2 on the back of your work, pioneer should be paying you for the extra units they have sold due to your work.
I have a small problem whenever i load apex from ifile i cannot get siri option to show in settings.
iam using a jailbroken iphone 4 with ios 5.1.1 and siri installed and working through siri.ru hack
Can anyone shed any light on this or suggest a solution.
Many thanks again
Andy
Posted Aug 24, 2012 · 14:36 UTC#385
It only works on the 4s.
Posted Aug 24, 2012 · 15:56 UTC#386
how are the new developments going?
Posted Aug 25, 2012 · 04:20 UTC#387
Hi, I'm having problems when I install the Appradio Extensions, I have tried installing the new beta 3 trough ifile and the 1.1.4-1 version which I can find in cydia. Every time I install the AppEx on my iphone, it starts rebooting again and again until I uninstall the AppEx. I don't know what else to do to make it work, I have an iphone 4s on 5.1.1.
Posted Aug 25, 2012 · 17:37 UTC#388
Is it possible to use the Siri button for Google Sasa?
Since I have no 4S I have to resort to this alternative.
I deleted after installing Google Sasa (Siri), the AppRadio Extensions. Then performed a Respring and then AppRadio Extensions reinstalled.
During installation I get the following error:
dpkg: serious warning: files list file for package 'original.siri' missing, assuming package has no files currently installed.
dpkg: serious warning: files list file for package 'com.myrepospace.hunterbeckham.bassamrepo' missing, assuming package has no files currently installed.
When I go into the settings under AppRadio Extensions look I find no way to turn Siri on.
Ist es möglich den Siri Button für Google Sasa zu verwenden?
Da ich kein 4S habe muss ich auf diese Alternative zurückgreifen.
Ich habe nach der Installation von Google Sasa (Siri) die AppRadio Extensions gelöscht. Danach einen Respring durchgeführt und dann AppRadio Extensions erneut installiert.
Bei der Installation bekomme ich folgende Fehlermeldung:
dpkg:serious warning: files list file for package 'original.siri' missing, assuming package has no files currently installed.
dpkg:serious warning: files list file for package 'com.myrepospace.hunterbeckham.bassamrepo' missing, assuming package has no files currently installed.
Wenn ich in die Einstellungen unter AppRadio Extensions schaue finde ich keine Möglichkeit Siri einzuschalten
Edited Aug 26, 2012 by AppRadioExtensions
Posted Aug 28, 2012 · 01:05 UTC#389
Sounds like a conflict with another tweak. Try disabling/uninstalling some other things you installed from Cydia.
Posted Aug 28, 2012 · 01:28 UTC#390
Updated the first post with a link to Beta 4. This version may or may not fix the black screen problem for everyone (I'm testing out some new ideas). Let me know if it works for you.
I also added a setting to disable an app's built in support for external displays. The some apps block you from using the external display when they are in use. This will let you mirror those apps to the AppRadio screen.
Edited Aug 28, 2012 by mikedecaro
Posted Aug 28, 2012 · 06:17 UTC#391
Awesome, thanks mike, have installed, will give it a go and let you know!
Posted Aug 28, 2012 · 22:02 UTC#392
Tried Beta 4, didnt let me run any apps from my phone that previously worked on beta 3, like messages, just stays a black screen on the unit.
Reverted back to beta 3 and all working fine again.
I got an iPhone 4, 5.0.1.
Posted Aug 28, 2012 · 22:42 UTC#393
Did it work on the first app you pressed and nothing after that? Or nothing at all?
Did you notice the black screen stuck on the springboard at all?
Temporarily took down the link. Need to fix one more thing before everyone tries it.
Posted Aug 28, 2012 · 23:27 UTC#394
I posted an updated version. Can you try this one and let me know if you experience the same problem?
Posted Aug 29, 2012 · 05:48 UTC#395
Nothing worked at all, I pressed home button on phone and just bought up the keyboard and kept the appradio screen there.
Will download now and try for you
Posted Aug 29, 2012 · 07:06 UTC#396
Just tried it and messages worked, then I went to switch to safari and it didnt work, screen stayed black, but safari was loaded on my phone.
Screen on phone doesnt go black, appradio connected screen stays there, but cant escape out of it, same as black screen really.
Hope that helps
Posted Aug 29, 2012 · 14:27 UTC#397
I had the same issue then I did the following.
Unistalled App Radio Extensions from both Cydia and deleted it from iFile - restart the phone
Installed updated version of Extensions checked cydia and settings to see that it was there - restarted the phone.
Everything works fine....
The only issue I have is that coming out of some unsupported apps and trying to go back into other apps it won't let me, I press any app and it won't start.
Mike - Please please please try and make some home buttons for NAVFREE, WAZE and other supported Pioneer apps that would be awesome. Everytime I'm in one and I need to get out I have to go to the phone.
Posted Aug 29, 2012 · 15:45 UTC#398
Does this happen every time or only for certain apps?
Can't you just press the home button on the radio and the Apps button to launch the AppRadio app? I'm trying to get away from adding custom home buttons to apps and this method has been working great for me.
Posted Aug 29, 2012 · 16:21 UTC#399
Hey Mike the app switching issue happens almost 99% of the time.
For the home button issue if I'm in a supported Pioneer app like NAVFREE, WAZ, Dash Command, the home button on the app radio itself doesn't work. I have to double tap the home button on the phone and then select the app radio app from the multi task pane to get back to the main screen.
Posted Aug 29, 2012 · 17:54 UTC#400
With waze clicking the button brings you back to the app list. ( at least it does for me without appex. I removed it due to email/push issues )
Page 16 of 98
