🔒 Locked
AppRadio Extensions 2.0 Beta - Full iPhone control
By mikedecaro · May 06, 2012in AppRadio, AppRadio 2, AppRadio 3💬 2,444 posts👁️ 945,070 views
Page 38 of 98
Posted Mar 03, 2013 · 22:08 UTC#926
Hi guys,
Does anyone know that if an unsupported app like Google Maps is launched through the Appradio app with AppRadio extensions installed whether it will then use the GPS antenna that comes with the radio or whether it will revert to using the antenna in the phone (like it does if it is simply mirrored with the HDMI cable).
Cheers,
Luke
Posted Mar 03, 2013 · 23:20 UTC#927
"Beta 8 will show as 2.0.1-42 in Cydia"
sry im not so good english... is this "Beta 8 will show as 2.0.1-42 in Cydia" for ios 5 or ios 6?
Posted Mar 04, 2013 · 02:11 UTC#928
Hi guys,
Cheers,
Luke
More than likely the antenna on the phone...
Posted Mar 04, 2013 · 10:37 UTC#929
Hi Myke, really thank you 4 your job... i have a question: every time i have to install a new beta version, i must unistall the oldest version? i means now i have the beta6 version in my iphone, first delete it and than install  the beta8 version or just add the beta8 extension?
Tks again!!!
Posted Mar 04, 2013 · 10:39 UTC#930
Tks again!!!
Posted Mar 04, 2013 · 10:58 UTC#931
For iOS 6.
Posted Mar 04, 2013 · 17:59 UTC#932
Hey guys, long time lurker.
I Have the appradio 1 and an Iphone4 with IOS 6, I jailbroke the Iphone and installed cydia and appradio extensions from cydia hoping to really bring this deck alive. I finally read the first page of this thread and realized well okay, extensions isnt compatible with IOS 6 so thats why it was crashing my phone.
My question is, should I look into downgrading to IOS 5.1 or wait for it to be compatible?
Posted Mar 04, 2013 · 19:22 UTC#933
There is a version that *IS* iOS 6 compatible; check the first post for his beta repo. Touch support isn't there yet but at least you can get it to somewhat work. Your two options would be downgrade, or just use the beta and wait as it keeps growing all the time.
Posted Mar 04, 2013 · 19:23 UTC#934
I'd do the downgrade to iOS 5 and use all features extensions, but at me iphone 4S :-(.
Posted Mar 04, 2013 · 19:23 UTC#935
Btw, sorry for the double-post, but @Mike, one of your later updates seems to have solved my laggy scrolling issues for the most part. Some screens still don't scroll 100% but for the most part it's gotten better. Idk if it's just coincidence with time or if you fixed something but problem seems to be solved for the most part here.
Posted Mar 04, 2013 · 19:25 UTC#936
I just installed and tested the latest version of AppRadio Extensions in IOS 6.2.1 - Iphone 4 with the 8400bt unit. The AppRadio interface works much better compared to IOS 5.0.1 with no lags at all. My problem is when I tried to use Navigon. First of all the left and right sides of the Navigon application are outside the visible area of the unit but I can live with that. My main problem is that the display of the car in the map lags. The position of the car is almost 100 meters (maybe more) behind the actual position. The audio directions although are working properly. The same problem appears also in IOS 5.0.1 and the Cydia version of AppRadio Extensions. Any suggestions?
Thanks in advance and keep going with the great work.
Edited Mar 04, 2013 by andapo
Posted Mar 04, 2013 · 20:02 UTC#937
I did download that, but I have no idea how to get it onto my phone
Posted Mar 04, 2013 · 22:19 UTC#938
The latest Beta8 edition has seemed to get rid of all the lag I had when scrolling through the apps in the apps menu.
I am running 6.1.2, 2.63 and Beta 8 on iphone4.
Posted Mar 04, 2013 · 23:05 UTC#939
Thanks for that, yeah I thought as much. I'm just intrigued to know how the apps running on the radio know to switch to the radio antenna. I thought it might have something to do with being run simultaneously with the app radio app because the app radio app is listed in the location services in the iphone settings, so if the google maps app is running in extensions (providing a way is found to do this in iOS6), it might be able to do this?
Posted Mar 05, 2013 · 14:17 UTC#940
Just to clear some confusion: the issue with utilizing unsupported apps is NOT with AppEx, but with the AppRadio app version, correct? I was finally able to get the app downgraded to 1.8.2 about a week ago and now the unsupported apps work - but the lag can be a bit irritating. So upgradring AppEx would solve the issue? I have this running on my jailbroken 4 running 5.1.1; I have yet to jailbreak my 4S but would consider it if it solved lag issue.
Posted Mar 05, 2013 · 16:13 UTC#941
hey guys im new to this and technology itself.  Just wanted to check: Has any1 been able to get the iphone 5 to work off the app radio.  and use the app radio touchscreen instead of th eiphone 5 touchscreen?
Thanks and sorry if its a redundent question.
Posted Mar 05, 2013 · 16:26 UTC#942
I thought I saw a version out there that was working with the new AppRadio App but still on iOS 5?  Is that out there somewhere, or am I imagining things?
Posted Mar 06, 2013 · 00:05 UTC#943
I second that, I saw it before but can't find it now...
Posted Mar 06, 2013 · 14:16 UTC#944
Hi Mike and everyone else here in the forum, I've been away for a while and just updated my iphone 4s to the 6.1.2, today I was testing the Appradio extensions and I noticed something weird, the apps are full screen now and it would be perfect if they wouldn't go out of the screen check out the attached picture, is anyone else experiencing this??, is it normal now on the beta 8???
I dont see this issue on my 4S running 6.1.2. Do you have anything else installed that may be conflicting with AppEx? What AppRadio model are you using?
Tks again!!!
You don't have to uninstall first. Just install the new version over it.
The version of AppEx in Cydia is the latest for iOS 5.
I removed the iOS 5 update from the first post because it needed a lot more work than just fixing the icons in the menu.
Edited Mar 06, 2013 by mikedecaro
Posted Mar 06, 2013 · 14:38 UTC#945
Mike,
iam guessing that there is still no progress with backgrounder or an alternative of it ???
Posted Mar 06, 2013 · 15:18 UTC#946
After downgrading the appradio app to 1.8.2, my iPhone 4S (6.1.2) doesn't seem to recognize the AVH8400...
That is, in the app... When using YouTube the display out works as it should...
It just keeps giving the 'connect to appradio' screen..
Updating to the most recent version works properly.
It worked before the update with the same cable without issues...
Posted Mar 06, 2013 · 17:48 UTC#947
I don't have anything else I used to have the landscape tv out, but when installing the beta 8 cydia required me to uninstall that tweak, my appradio unit is a Pioneer AVH-X4500BT DVD receiver, that has appradio mode, all the previous betas up to beta 6 worked just fine for me, I don't know if the landscape tv out tweak left something that its conflicting with the apex beta 8 or what's going on...
Posted Mar 07, 2013 · 15:22 UTC#948
I have an iPhone 4s w iOS 5.1.1
In Cydia the app radio extension that says is installed is 2.0.1-1
On my device
Everything seems to work ok once in a while I experience glitches like when I plug my phone in to the radio sometimes I manually have to open app radio app
Also once in a while the complete screen shrinks
But other then that it works great !!
I'm wondering if I should upgrade to iOS 6 ???
And also should I upgrade or try another version of app radio extensions ?????
Posted Mar 07, 2013 · 15:25 UTC#949
Adrian Santiago,
try and check the "tv out" setting (on the iphone) when it's connected to the appradio.
I had the same issue with Carmediaplayer.  after setting the option "full screen" (or wide screen, not 100% sure) to "on", it displayed as it should.
Posted Mar 09, 2013 · 06:06 UTC#950
The developer who made Accelerate is updating backgrounder, just received a conformation email from him today.  Quasar is almost done also.
Page 38 of 98
