🔒 Locked
AppRadio Extensions 2.0 Beta - Full iPhone control
By mikedecaro · May 06, 2012in AppRadio, AppRadio 2, AppRadio 3💬 2,444 posts👁️ 945,070 views
Page 5 of 98
Posted May 27, 2012 · 07:50 UTC#101
Can you add ......
Posted May 27, 2012 · 19:09 UTC#102
Any app that contains support for external displays but is not approved by Pioneer will not work properly. I have to manually add them to a whitelist. If you post the bundle identifier for the app, I can add it.
Turns out it's a bit more complicated than just adding them to the white list. I'll have to work on this for beta 3.
Posted May 27, 2012 · 19:58 UTC#103
The application TOMTOM works very very well!
Edited May 27, 2012 by msieurlolo
Posted May 28, 2012 · 05:53 UTC#104
Hey Mike, let me start off by saying, great job with this!!!
I tried out the beta 2 for a little bit tonight and I noticed that the display out works pretty good but I have noticed one issue.
I have my phone mounted in landscape with the dock connector on the left side. This causes issues with the apps touch control functions on the app radio. I did figure out that they all worked fine if I flip the phone over to have the doc connector on the right side.
I was wondering if you can make a toggle in the appradio extensions setting to designate which way the landscape mode is in, ie doc connector right or doc connector left and the touch controls in the extension flip to work in either mounting direction?
I'm looking forward to trying out beta 3 in the future.
JC
Posted May 28, 2012 · 17:46 UTC#105
Okay, I'm missing something. I downloaded the beta, but don't know how to install it. It doesn't show up in Cydia. Please give me instructions,
Thanks, Ron
Nevermind I went back through this thread and found it under Page 6.
Edited May 28, 2012 by ronsno
Posted May 28, 2012 · 18:17 UTC#106
SSH connects you with iFunbox for example
Look the screenshot
Go to Systeme de fichier
Go to /private/var/root/Media
Go to Cydia
Go to AutoInstall or create it
Copy the file. DEB in the directory AutoInstall and reboot
Sorry for my bad english
Edited May 28, 2012 by msieurlolo
Posted May 28, 2012 · 18:19 UTC#107
THIS is WAY easier......Email to yourself, click on the file....use iFile (free) to Install......Reboot......DONE!!!!! Check Cydia after re-boot an it will show the correct Beta
Posted May 28, 2012 · 18:21 UTC#108
Keep it in your Inbox.....if you want to roll-back to the un-beta.....just uninstall in cydia then re-install in cydia
now I can go switch between beta and non-beta without a computer!!!!
Posted May 28, 2012 · 19:08 UTC#109
I installed it using ispirit but the second method sounds much easier as I had to go back and forth with the ispirit, but ispirit is a great program.
Posted May 28, 2012 · 19:16 UTC#110
Mike,
I played around with this and it's great. I noticed it doing a reinstall of the AppRadio App alot, kept bringing up welcome to my iPhone. Is there a preferred setup? I'm assuming it's the default but just checking. Hitting the black bar on the right takes it back to the app screen most of the time. When I used approved the apps, the back and forth is smoother, so I concluded the unsupported causes the appradio to reboot when hitting the home screen. Anyway fantastic progress, your work is making this HU more of what it should have been from the factory. Anyway to get some of the unsupported apps to show up in landscape, such as phone?
Thanks again, Ron
Posted May 29, 2012 · 09:35 UTC#111
Hi Mike,
I really like the appradio extensions. Its just awesome to control navigon directly from the radio. Im using it on the avh 8400bt. Ok as its still beta state sometimes the screen stays black after switching to the iPod source and back but you already mentioned this and after restarting the appradio app its working again most of the time.
I think it would be really cool to have the following features implemented:
- Resize the Screen to fit to the radio display (on my radio navigon doesnt use the full height in landscape mode)
- option to turn off the iPhone screen (Looks somehow stupid when both devices show the same stuff and anyway you dont need the iPhone screen since you can control everything from the radio
Greetz from Germany,
Martin
Posted May 29, 2012 · 12:38 UTC#112
Has Anybody tested this out on Appradio 2 ?
I'm having issues controlling the iPhone. nothing comes up accept the official appradio App and then nothing happens....
Edited May 29, 2012 by digzz
Posted May 29, 2012 · 13:53 UTC#113
SBRotator (in Cydia) adds landscape support to some of the built in apps. I use this tweak so I plan on making sure it plays nicely with the AppRadio.
The full height issue is a bug (see the first post). Still trying to resolve it.
I've tried a few things to make the phone display turn off but haven't been successful yet. It's on my list but low priority.
Posted May 29, 2012 · 15:31 UTC#114
It's ok now ....It's kind of working .....
One issue .......I can't get the official Apple music App to work .....the icon just loads on the screen ....
Is there a issue with using the Apple official Apps ?
Posted May 29, 2012 · 17:48 UTC#115
I found out something interesting yesterday.........I know that I had mentioned earlier about Pandora not "backgrounding" when running non-pioneer apps.......BUT, I noticed that the system app "messages" will work with pandora in the background!!!!!! Safari didn't though........Didn't know if the "messages" app had some kind of different permissions???
Just thought I would throw that out there and see if it helps
Posted May 29, 2012 · 18:10 UTC#116
Okay just tested this with the new App Radio (1) Firmware 2.56 (Euro) and works without issue
Posted May 29, 2012 · 18:56 UTC#117
Has this issue been resolved in the latest beta ?
Only works with AppStore apps (meaning no Maps, Photos, Calendar, Phone, etc.) ???
Posted May 29, 2012 · 19:20 UTC#118
What's new with 2.56?
Posted May 29, 2012 · 20:40 UTC#120
The restriction was removed but I haven't tested every single app yet.
Posted May 29, 2012 · 22:10 UTC#121
Maps and Phone don't work.......I've only tried those 2
BUT, as I stated earlier "messages" work....EVEN WITH PANDORA running!!!!!!!!!!
Edited May 29, 2012 by breaksraver13
Posted May 30, 2012 · 16:45 UTC#122
Using Beta 2 with 2.50 FW....
This is probably the same for everyone, but this is my observation:
- Touch works the first time something is loaded, but if you go back to the Appradio app then load a different app, all you get is a black screen. You have to then go back to the iphone, close Appradio, then relaunch it.
Great job so far, Mike. Once this is polished up, I think I speak for everyone when we thank you in advance for finally making our Appradio "useful." Btw, while this has nothing to do with AppEx, is CarMediaPlayer absolutely useless for everyone else? It actually works about once every 20 times its loaded...Very aggravating.
Posted May 30, 2012 · 17:08 UTC#123
Hey Mike
Thanks so much for "digging in" and fixing that which Pioneer is unable or not willing to do for us!
I've installed Beta 2, and everything that was working with your prior release is still working.
I'm having an issue with the new "controlling non-supported apps" feature. When I add the app to the App Radio screen and launch it, I'm still just getting a black screen after I click past the parking break screen. Any idea what I might be doing wrong?
Apps I've tried:
iHeartRadio
ooTunes
Its possible these are TV Out enabled apps already, so that might be my issue, but I'm not certain.
Current setup:
iPhone 4
App Radio 1: FW 2.45
App Radio App: 1.71
App Radio Ext: 1.9.9-2
Thanks so much for your effort!
PS: I'm also wondering how you started developing this iPhone Extension? I'd love to start learning, I have a basic understanding of the iPhone development environment and Objective C. Would you consider open sourcing this extension? I'd love to dabble :)
Posted May 30, 2012 · 17:48 UTC#124
I just made a small contribution to the great Mike! Thank you from Rome...
Edited May 30, 2012 by pistillo99
Posted May 30, 2012 · 18:39 UTC#125
Hello,
I tried now for the first time AppEx and get it installed. But I can't find the 'More Apps' button. Could anybody please describe or show me (by photo or video) where I can find this one.
Thx!
Negropo
Page 5 of 98
