🔒 Locked
AppRadio Extensions 2.0 Beta - Full iPhone control
By mikedecaro · May 06, 2012in AppRadio, AppRadio 2, AppRadio 3💬 2,444 posts👁️ 945,070 views
Page 54 of 98
Posted May 04, 2013 · 20:09 UTC#1326
I use the supplied cable that comes with the DA100 that has the USB and iPhone 30 pin connector. Now i have the Apple Lighting HDMI adapter and i connect the HDMI from that in to the back of the head unit. I connect the Lighting cable from the adapter to the USB on the original cable for charging. All works very well.
Posted May 04, 2013 · 20:50 UTC#1327
Played angry birds on my 8500 today
It works a lot better
Posted May 04, 2013 · 21:52 UTC#1328
I've got an 8500 too with an iPhone 4S. So nice to be able to use Navigon again without it crashing after a few seconds. Beta 11 fixed that issue for me. Haven't tested everything yet, but it's not crashing now like it was. Thanks for all the work. I know it's not much, but you should find an extra $20 in your PayPal account Mike.
Thanks for an awesome app and trying your best to keep it working properly and adding functionality
Posted May 04, 2013 · 21:58 UTC#1329
Just realised that i was running the beta before the latest. I am now update.
However i don't know if this has ever worked. I tried to arrange the icons and also put 3 icons down on the quick launch but on switching off the stereo and switching back on the icons are not saved. Has this always been the case?
Posted May 04, 2013 · 22:53 UTC#1330
beta 11 works like a charm (8500+i5-6.1.2). great job mike!
only thing off a bit is the screen calibration. but a working touchscreen is a HUGE step forward
Posted May 04, 2013 · 23:18 UTC#1331
yeah screen calibration is a bit off. would be good if there was a way to adjust the sensitivity of the touch screen. sometimes seems hard to get the screen to pick up that you have touched it.
Posted May 04, 2013 · 23:19 UTC#1332
mike is there anyway to get a clock in the car media player app?
I would love to have the clock in a bunch of apps, but coding for each one specifically (location, color, etc) would be difficult. I'll have to think of something.
hello,
what BETA APPEX uses this guy? I would like to have the same flow
That's a demo of the Mimics hardware mod. Not AppEx.
Just tested (iPhone 4, iOS 6.1.3, AVH-P8480BT), and the 30s crash is in fact gone :)
However, touching the side black bars exits the app but doesn't load AppRadio back, I have to call it manually on the iPhone screen every single time.
And I'll back mams on the slowness issue, on all unsupported apps. Even Google Maps run painfully slow. Heavier apps, like TomTom or Sygic, are virtually unusable, lagging 2-5+ sec between a touch and a response, and updating the screen at 1 frame every 3 sec or even more.
Anyway, thanks for your huge efforts on trying to free us all :)
What do you mean by exits the app? Does it close back to the home screen? or switch to the AppRadio app but not show on the head unit?
I'll look into the slowness on the iPhone 4. It's been a problem for a while now, I just haven't be able to get it fixed yet.
Edited May 04, 2013 by mikedecaro
Posted May 05, 2013 · 00:14 UTC#1333
Since I'm considering upgrading one question I have is for the iPhone 5 users; How are you connecting to the AppRadio SPH-DA01
There is no i5 solution for the DA01/02.
Posted May 05, 2013 · 00:24 UTC#1334
X8500 with Iphone 5 6.1
tested latest update from Cydia.  unfortunately appradio is still crashing for me.  i was able to play angry birds for a few minutes fine.
when i played a video, and left it running without touching screen, the appradio app would crash and id lose touch capability. after about 20 seconds not 30.
tried rebooting several times but same behavior.  i did notice some apps correctly going to landscape now when they didnt before.
Posted May 05, 2013 · 02:14 UTC#1335
Yes, it closes back to the home screen (on the iPhone), black screen with no touch input on the unit. I need to re-open AppRadio manually.
Posted May 05, 2013 · 02:30 UTC#1336
Really ? Why what are you on ?
6.12
Posted May 05, 2013 · 02:32 UTC#1337
Please make sure you don't have anything else that might be messing up your apex, I have an iPhone 4 and although I experience what you say it not all the time and it doesn't happened with every app, apps like music and video or mail or messages work great when clicking on the black bars it loads appradio app again, when using other applications like cydia and some that are not originally supported by appradio that's when I experience the problem of taping on the black bars and appradio app doesn't launch. On the same note when I open appradio and I get the welcome Adrian's iPhone screen on the unit after it loads and I select an app like music and then tap on the black side bar to go back to the appradio home that shows my apps on the unit, it dosent go back to where it was before but instead it loads again the whole thing with the welcome Adrian's iPhone screen again, this takes also a long time and makes it hard to switch applications, what I've been doing is I've been pressing the home button and this allowed me to see the iPhone screen and then I can launch another app from there, hopefully we can get all this fix on the next beta, :) thank you so much mike...
Posted May 05, 2013 · 03:24 UTC#1338
Thanks for your input. However, I can't see what could possibly mess with AppEx, as it's the only thing I have installed from Cydia, other than iBlacklist app.
Pressing the home button once on my 8480 (8400), has no effect at all. That's the behavior on all units that have AppRadio Mode, afaik.
Did some more extensive tests a while ago, and found that the black screen issue while tapping black bars is aleatory. Some apps, like Sygic and TomTom, do it more often, but some times the bars work as intended.
Another thing that I noticed, is that Google Maps and MotionX almost always crash to springboard, but leaving full touch control active.
After all, I think that solving the iPhone 4 slowness issue is much more important than these weird app behavior, that can be addressed later :)
Edited May 05, 2013 by DMZamora
Posted May 05, 2013 · 21:58 UTC#1339
The calibration of touch is quite off i am finding more and more. sometimes its taking two or three finger presses to get it to do something.
Posted May 05, 2013 · 23:34 UTC#1340
I gonna ask a dumb question here - the important note says only compatible with v1.8 of appradio. I can't find that version. Only 2.2.0 is showing.
Also, it shows that this is compatible with avic-z150. Pretty positive I'm not doing something right here. I still see all the standard apps and have no way to choose or add additional ones.. pretty lost here as you can see
relevant details:
iphone5
iOS 6.0.2
installed appradio extensions v 2.0.1-173 from decaro.com/repo
avic-z150
Edited May 06, 2013 by 2000se
Posted May 06, 2013 · 04:26 UTC#1341
relevant details:
iphone5
iOS 6.0.2
avic-z150
Please see the FAQ entry for iOS 6 located at http://avic411.com/index.php?/topic/36595-appradio-extensions-faq-read-this-before-posting/
Edited May 06, 2013 by rickthecabbie
Posted May 06, 2013 · 12:06 UTC#1343
come on now....don't be like that. i'm asking a question here.
iOS 6
What version of the AppRadio app do I need?
The latest version available in the AppStore.
There is an option in the Settings app to select which apps are displayed.
Edited May 06, 2013 by mikedecaro
Posted May 06, 2013 · 12:59 UTC#1344
Wait - I think I understand now. You mean the settings in the settings app for the phone.
Just found that now. I was thinking that I should be seeing that under the settings button inside the app radio app. But it's not. It's inside the settings app for the phone.
DOH! Got it now. Thanks!
Posted May 06, 2013 · 13:02 UTC#1345
List the options you see in the settings for AppEx.
Posted May 06, 2013 · 13:22 UTC#1346
Thanks mike -thanks vblue42. I edited my post right above yours to include what I found out after looking around a little bit more. I guess I was an idiot for not looking there until now.
We'll see what happens when get the phone plugged in.
Posted May 06, 2013 · 13:48 UTC#1347
Glad to help.
Posted May 06, 2013 · 14:02 UTC#1348
hello,
mike thank you for having responded to my question
where I can download all BETA? (1,2,3 beta,, 10), I'd like the best beta for iphone 4
thank you
Posted May 06, 2013 · 14:26 UTC#1349
hello,
thank you
Go to the first page of this thread.
Posted May 06, 2013 · 14:38 UTC#1350
on the first page there is just the latest beta
existe a page, where i can download all BETA of Appex ?
thank you
Page 54 of 98
