Hi Mike and Tomfolery,
Regarding the tweak to kill the appradio app when disconnecting the power cable, im not sure i understand the reasoning for this or the value it adds.
All the tweak does is kill the appradio app, its still available as Mike said from the app switcher, but most of us are going to be using an app like Car Media Player when we turn the ignition off, so actually when you disconnect the power Car Media player or whatever else you might be using is still running. So saving battery or whatever other reason for this tweak has not been acheived.
Would it not make more sense instead to jump to the the first springboard page when power is disconnected, effectively killing any app that may be running? Not sure if that would acheive the desired effect as i dont understand backgrounding and if there will still be any other apps running in the background that will be draining power?
I currently use Activator to acheive this effect, but in my case its simply because i want all apps killed when i disconnect the power. In an ideal world i would want all apps killed and the phone to jump to the lock screen, that way i dont have to press the sleep button before/after i disconnect the phone from the cable/dock.
Hope that makes sense.
Cheers
Max
P.S Mike, once again thanks for all your work on this
