App Radio/App Radio 2 Bypass Confirmed!!!
By VBLUE42 · Jun 11, 2012in AppRadio, AppRadio 2, AppRadio 3💬 314 posts👁️ 185,710 views
Page 1 of 13
Posted Jun 11, 2012 · 21:59 UTC#1
Starting a new thread to highlight this finding. This has been confirmed by our resident installer 1Loudls as well as the folks at my local shop. This also works with the AVH-8400 as well. This is now the official bypass thread and all other threads will be locked.
To bypass the radio, you will need to get a Pac TR7 and a standard relay. The relay wiring will be:
85 - Blue wire on the TR7
86 - White eand Orange wire from the TR7
87 - Tied to 86 on the relay
30 - parking break wire on the Pioneer
Wiring for the TR7:
Red - ignition source
Black - ground
Green - remote wire on the Pioneer
Orange - 86 & 87 on the relay
White - 86 & 87 on the relay
Blue - 85 on the relay
The TR7 will need to be setup for feature 12. The settings will be:
Option 1 - 1 delayed on for Blue
Option 2 - 2 delayed off for White
Option 3 - 1 delayed for Orange
Duration 1 - 040 (40 seconds)
Duration 2 - 045 (45 seconds)
Duration 3 - 050 (50 seconds)
The way that it works is: the radio remote provides the + trigger to the TR7. The TR7 then supplies ground to the white wire for 45 seconds. After 40 seconds, the TR7 supplies power to the blue wire. This triggers the relay and sends ground to the pioneer parking break wire. After 5 seconds, the TR7 then puts the white wire to open and the relay then goes to open for 5 seconds. After that, the TR7 will then put ground on the orange wire causing the relay to trigger sending ground to the pioneer.
this is exactly what i did, and it worked like a champ on three cars (two app radios and one app radio 2)
Edited Jun 11, 2012 by VBLUE42
Posted Jun 11, 2012 · 22:30 UTC#2
the PAC TR7 (not to be confused with the older PAC TR-7 in the black case) can also be configured to be used in mode 17 (clarion) without the need for a relay and is much simpler to program BUT PAC tech support does not have any other information other than that the new modules can do modes 17-23
http://www.pac-audio...ulletin_002.pdf
but they can not answer any questions you might have on it (or at least the two simple fellows that i got to talk to couldn't)
so i was wondering if anybody set theirs up for the clarion mode (17) and how they wired it up???
!!!ALSO THERE IS A SMALL TYPO IN THE ABOVE QUOTE!!!
it may cause some small confusion
near the bottom
"Option 3 - 1 delayed for Orange" should be :Option 3 - 1 delayed ON for Orange
Edited Jun 11, 2012 by 1loudls
Posted Jun 11, 2012 · 22:31 UTC#3
!!!EURO UNITS DO NOT NEED ANYTHING EXTRA TO BYPASS THEIR UNITS!!!
to bypass a Euro unit, just ground the P-brake wire.
doesn't matter where you ground it, can be connected to the chassis of the radio, the body of the car, or even just wired into the black ground wire in the main wire harness.
Edited Jun 12, 2013 by 1loudls
Posted Jun 13, 2012 · 04:42 UTC#4
Okay did this tonight and it works flawlessly. It took me and my son a while to figure out the programming. When you get the the features part, referred to above as options, simply pulse once for the blue wire, twice for white and then once again for orange. We thought you had to pulse once to select the wire and then again for the option. Once we got past that it was simple and immediately worked. Very happy with this and with Mikes AppExtensions getting closer to my ideal;)
Posted Jun 13, 2012 · 17:10 UTC#6
are these the correct units?
yes they are.
Posted Jun 13, 2012 · 18:48 UTC#7
yes they are.
thanks, i see you have a lincoln ls as well did everything fit behind the stereo good for you? i have the metra steering wheel adapter behidn mine and i already feel like its a squeeze getting the stereo in
just noticed you do not appear to have the appradio in that car
Edited Jun 13, 2012 by late
Posted Jun 13, 2012 · 20:57 UTC#8
Hi, I'm new on this Site but bought an appradio2 and I'm interested in the bypass :)
When I try to see the items which were linked here , I was "automaticaly" proposed another one
http://www.amazon.com/Parking-Override-Automatic-Pioneer-AVH-P8400BH/dp/B007QE03IM/ref=pd_cp_e_1
Which seems easier to install but that I don't heard about before .. did someone try it ?
Another question : Is the lack of this overide a reason not to see the picture on the appradio2 when connected in advanced app ? (I see a still picture of my android phone (SG2), the app is launched on the phone and I can slide on the appradio unit (and see that it works on the phone :) ) but there is no picture on the unit .
Thanks for your site by the way :)
Posted Jun 13, 2012 · 22:03 UTC#9
those micro bypasses have worked for past AVH models that use a similar sequence, but i have heard that there are people experiencing problems with the newer pioneer firmware's, as of now, i have not been able to replicate this issue yet to try to track down the reason for it not working.
I am also curious to see if anybody there is having issues with their bypass AND running the most current firmware???
Posted Jun 13, 2012 · 22:15 UTC#10
yes, not easy by any means, with all of the add ons and custom wiring needed, there is very little extra room back there, for starters any extra cables (IP-Bus, GPS, mic, XM, BU camera, usb, and AV) have been coiled under the end caps of each side of the dash instead of behind the radio (which i recommend with any car possible) then the xm tuner and SWI-PS are mounted above the glove box, then as it is being put back into the dash, you have to stop every couple of inches to tuck all of the other harnesses and wires off to each side of the radio cavity to make more room.
wont matter, all of pioneers units are all about the same depth
Posted Jun 14, 2012 · 14:37 UTC#11
Just wanted to give my experience using the PAC TR7/relay method being discussed here. I too had this setup working with my AppRadio. While it worked flawlessly for a few weeks, out of nowhere it stopped working. Didn't have the time to troubleshoot what happened, but went to the switch bypass method for now until I have time to figure out what happened.
Edited Jun 14, 2012 by rsquared
Posted Jun 14, 2012 · 17:59 UTC#12
Could just be a loose wire or bad relay.
Posted Jun 14, 2012 · 18:28 UTC#13
were you using mode 12 or 17?
as far as it quit working, was the relay still being triggered on, off, and back on?
if not, i would start looking at the wiring to make sure that nothing came loose, or try reprogramming the TR7.
Posted Jun 14, 2012 · 18:45 UTC#14
Mode 12, I programmed it exactly as listed in the first post of this thread. Not sure exactly what stopped working, as I haven't had a chance to troubleshoot. I know that I used to be able to here the setup clicking, but then the clicking just stopped.
Posted Jun 14, 2012 · 21:30 UTC#15
The relay more than likely went bad if the clicking stopped.
Posted Jun 14, 2012 · 22:10 UTC#16
Install TR7 and relay today. I set the timer to go off at 3 seconds, 5 seconds and 7 seconds. Works everytime on the appradio2. Not sure why a 40 second delay would be needed. Also, wish I had wired the green wire on the TR7 to the ignition source instead of the remote wire. The relay only gets triggered if audio is playing (which sends power to the remote wire). Also when I unplug my phone, it kills the relay because it kills the power to the remote wire. The TR7 will trigger again once I start the radio or plug my phone. Not sure why I couldn't have plugged it into something that gets power all the time. Thanks for the suggestion on the hardware!
Posted Jun 14, 2012 · 22:38 UTC#17
1Loudls what are your thoughts on this? I would also be interested in much shorter delay times.
Edited Jun 14, 2012 by VBLUE42
Posted Jun 15, 2012 · 00:38 UTC#18
I tried it at 20 sec, 25 & 30 and even that seemed excessively long of a delay. I quickly reprogrammed it to 3,5,7 and it's worked 100%. Probably 3,4,5 would work too but it's not worrying playing with. Removing the dash again to rewire the green to always on is probably worth it, when the unit starts with no audio playing it doesn't trigger. Tried to load the Apps screen without starting music (ie applying voltage to the green wire) and the appradio didn't recognize the parking break as on. Had to back out and start the radio manually to get it to work. Might as well have a switch in that case.
Posted Jun 15, 2012 · 04:49 UTC#19
well at least if the clicking stopped, then it should be real easy to find the culprit when you have time,its either a bad relay (i would think the least likely, but the quickest to check) a wiring issue (first place i would inspect) or the TR7 either lost its programming or went bad.
Posted Jun 15, 2012 · 05:00 UTC#20
you definitely can do this, and since the amp turn on wire does go off on the app radio it probably would work better for most cases if hooked to accessory.
as we talked about it the other day, i dont see why it couldn't be much shorter, as long as it works consistently, thats all that matters. it can be programmed to be as short as the app radios software will let it, if hooked to accessory as mentioned above, the time would probably have have boot time taken into consideration (but we are not talking about F-series boot time here either :) ) but remember, when the amp turn on wire gets is switched on, the radio is already fully booted
Edited Jun 15, 2012 by 1loudls
Posted Jun 15, 2012 · 14:07 UTC#21
Good afternoon all,
Just thought I would share my experience with the App Radio 2 (SPH-DA100). I bought the UK model from Halfords and can confirm that the switch or relay is not needed for the UK model (at least for the model I have anyway...). I simply connected the handbrake wire to the ground on vehicle wiring harness and I am able to access all menus at any time - including youtube etc when I have my phone connected (HTC Sensation).
I have installed the unit in my Alfa Romeo Spider (2008), at some point I will put up some pics and installation guide over on Alfa Owner and post a link on here for anyone interested.
Ali
Posted Jun 15, 2012 · 14:53 UTC#22
I installed mine with the longer times suggested in the first post but once my Appradio boots up its ready. The time delay does not slow down anything.
Posted Jun 16, 2012 · 11:41 UTC#23
Is that on the original appradio or the appradio2? I'm just curious because my appradio2 boots instantly when I start my car. I wouldn't even use the phrase "boots up" with it, it just turns on with the car
Posted Jun 16, 2012 · 16:35 UTC#24
I have the App1, it takes about 30 seconds to boot up (screen on), very annoying. With this bypass by the time it's ready there is a warning screen, I press okay and it's ready to go.
Posted Jun 16, 2012 · 21:32 UTC#25
Complicated bypass schemes have always been US units only. We should probably state that in our threads from now on.
Page 1 of 13
