App Radio/App Radio 2 Bypass Confirmed!!!
By VBLUE42 · Jun 11, 2012in AppRadio, AppRadio 2, AppRadio 3💬 314 posts👁️ 185,710 views
Page 3 of 13
Posted Jul 03, 2012 · 23:22 UTC#51
now my phone reboots when tryin to connect it with appradio, something really went wrong. Im going to look t my wiring and reprogram it all over to make sure i'm doing it right ;;)
Posted Jul 04, 2012 · 20:34 UTC#52
i have problem programmin the tr7 module.
I twist the green and red wires together and then twist them around the red wire from the car, i do the same with the blck from the tr7 with the black from the car.
i turn the key to "on"" position and then i move the switch on the tr7 to "on" whcihafter i ground the brown wire 17 times but the module never flashes 17 times back at me?
am I doing something wrong?
Posted Jul 04, 2012 · 20:39 UTC#53
for programming to work, only the red and black wires are hooked up to acc and ground (respectively) and then it will allow you to program. took me a couple minutes the first time to figure that one out.
Posted Jul 04, 2012 · 20:46 UTC#54
ooooh, wait, im going back in the garage to test it out ;) lol. thanks ;)
Posted Jul 04, 2012 · 21:58 UTC#55
is there like a reset function for the tr7, cuz i have two units and i think i messed up both of them.
one of them doesnt do anthing after the 17 grounds, and the light on the other one goes on and stays on when i ground the brown wire....
Posted Jul 05, 2012 · 00:14 UTC#56
Hmmm, I'd say unplug it for a few minutes then before you plug back in the power turn the programming switch to on and connect the power. From there you should be able to program it. Make sure none of the other wires are connected to anything or grounding out
Posted Jul 09, 2012 · 02:13 UTC#57
Would some one from this tread be willing to put one of these together and program it and sell it to me for a fair price? I am more than willing to pay for parts your labor time and shipping. Please email me at: [email protected] and let me know the total cost. I can pay through PayPal or send you a money order.
Thanks In Advance For Your Help,
James
Posted Jul 09, 2012 · 05:03 UTC#58
lol, im almost to the point where i will pay someone to program mine as well :) I have some local buddies that have experience with car audio stuff and will ask them to help me and maybe I'll put a video together that shows step by step how to program this damn thing.
Posted Jul 09, 2012 · 20:26 UTC#59
why dont you guys find a local shop to help you out! that way then you can get it done much sooner, but more importantly you can try to find a good tech to have with any future issues you may have.
Posted Jul 09, 2012 · 20:27 UTC#60
also has anybody called PAC's tech support, they will walk you through programming it over the phone.
Posted Jul 09, 2012 · 20:47 UTC#61
i felt the programming was pretty straight forward (after i screwed up about 10 times, then i figured it out)
Posted Jul 10, 2012 · 02:50 UTC#62
^ i agree, its not figuring out how to program it that was hard, it was just making it through the entire sequence with out making a mistake that was the challenge.
but then again, if they wanted to make it easy, they would just let you ground the wire!
Edited Jul 10, 2012 by 1loudls
Posted Jul 10, 2012 · 03:40 UTC#63
Are you still having problems with both of your units? The one thing I read online that helped to get it in programming mode is, turn programming mode on before you hook up the power source. That was the only way I could reliably get it into programming mode.
Other then that I followed the directions on pg 3 and it just took a couple tries to get the count right
Posted Jul 10, 2012 · 06:07 UTC#64
^^ i haven't had time to sit down and play with it, but i will probably get to it this weekend and hopefully i will have good news ;)
Posted Jul 10, 2012 · 14:04 UTC#65
How I did mine: tr7_wiring.jpg
Then for programming:
1. Have only the red and black wires of the pac connected.
2. Turn car on or to accessory power.
3. Move the programming switch to ON.
4. Ground the brown wire 17 times.
5. Wait 3 seconds and ensure the light on the pac flashes 17 times.
6. Ground the brown wire 1 time to enter timing mode.
7. Wait 3 seconds for minutes timeout, light will flash.
8. Wait 3 seconds for tens place timeout, light will flash.
9. Ground the brown wire 3 times.
10. Wait 3 seconds and ensure pac flashes 3 times, then goes to fast flash.
11. Move programming switch to OFF.
12. Turn vehicle off.
13. Reconnect/connect the blue wire from TR7 to parking brake wire, green wire from TR7 to accessory power.
14. Profit!
So no relay is necessary if you choose this method?
Posted Jul 10, 2012 · 20:45 UTC#66
thats what he said
Posted Jul 11, 2012 · 00:03 UTC#67
correct
Posted Jul 11, 2012 · 01:58 UTC#68
Dumb question then...why use a relay? I am doing my install myself on Saturday, and although I had initially planned NOT to bypass, I want to make sure I am not choosing a method I'll regret later.
Posted Jul 11, 2012 · 16:02 UTC#69
relay is required with the appradio 1, the no relay method only works with the appradio 2.
Posted Jul 12, 2012 · 01:47 UTC#70
Ah! Thanks for the heads up. I now have a relay for which I don't have a use for. LOL, if anyone wants it in The Bronx area, you can have it for free.
Posted Jul 12, 2012 · 19:32 UTC#71
the PAC TR7 (not to be confused with the older PAC TR-7 in the black case) can also be configured to be used in mode 17 (clarion) without the need for a relay and is much simpler to program BUT PAC tech support does not have any other information other than that the new modules can do modes 17-23
http://www.pac-audio...ulletin_002.pdf
but they can not answer any questions you might have on it (or at least the two simple fellows that i got to talk to couldn't)
so i was wondering if anybody set theirs up for the clarion mode (17) and how they wired it up???
!!!ALSO THERE IS A SMALL TYPO IN THE ABOVE QUOTE!!!
it may cause some small confusion
near the bottom
"Option 3 - 1 delayed for Orange" should be :Option 3 - 1 delayed ON for Orange
The TR7 and the TR-7 are the same module. Yes the housing have changed a bit but they are still and always have been the same module.
Here is how to set it up with version 17. This is for a clarion radio so the timing may need to be changed.
Clarion-Jensenl-Dual-Marine-Mode_ver2.pdf
Posted Jul 13, 2012 · 00:29 UTC#72
not according to paper work that PAC includes with their modules.
Posted Jul 13, 2012 · 16:00 UTC#73
1loudls is correct
proof: pdf from their site http://www.pac-audio...ulletin_002.pdf
The TR7 has 7 additional Bonus Features not documented in the instructions. These Features are 17-23 as
listed below. Only the TR7 supports these features. The older TR-7 in the black case does not support these
features.
also looks like there is a new tr7 pro out. http://www.pac-audio.com/productDetails.aspx?ProductId=1137&CategoryID=31
can program it from your pc
Edited Jul 13, 2012 by late
Posted Jul 13, 2012 · 17:31 UTC#74
1loudls is correct
features.
also looks like there is a new tr7 pro out. http://www.pac-audio...7&CategoryID=31
Weird.... Go to their website http://www.pac-audio.com/productDetails.aspx?ProductId=717&CategoryID=31
Click on tech docs and click on the instructions..... It has the TR-7 instructions. coincidence? I think not.
Yes, some of the very first revisions on the module didn't support the bonus features. Anything you buy or come across now will have it regardless of whether or not it has the - in the part number. Especially since that document has a date of 4-08-08. I mean I only work for PAC.... What would I know?
Posted Jul 13, 2012 · 21:22 UTC#75
14. Profit!
Having trouble with mine too, tried the switch method and did not work so going to try this. When you say ground the brown wire...do you mean take the brown wire with the end exposed off the tr-7 and just touch it to bare metal? Is that grounding it? Thanks for the awesome post, instructions and pics. VERY NICE!!!!!!!!
Page 3 of 13
