AVIC Z1/Z2/Z3 Upgrade to 2012 TomTom Maps Released!
By mikemaan · Aug 18, 2012in Hacks/Mods💬 315 posts👁️ 102,668 views
Page 3 of 13
Posted Aug 28, 2012 · 23:24 UTC#51
I'm still seeding...
I tried a new program called unzbin. It isn't downloading or connecting to anyone. That is why I said it appeared no one was seeding. I have no doubt the program is useless. I was unable to get utorrent or bittorrent to use the torrent file.
Can you PM me the link you used?
Edited Aug 28, 2012 by moellermania
Posted Aug 29, 2012 · 03:04 UTC#52
I may have some bad luck, I took out my present hard drive from Z2 ( not the original HDD ) and now it doesn't work at all. My computers and laptop will not recognize it. I tried AFF Repair Station and it doesn't recognize my HDD. I put it back in my Z2 and radio does not recognize it either. Thank God I still have my original, that works fine. Any ideas of what might of happen?
Posted Aug 29, 2012 · 03:53 UTC#53
Hi,
Can somebody please pm me the torrent link.
Thank you.
Posted Aug 29, 2012 · 04:15 UTC#54
What exactly did you do between "I took out my present hard drive" and "now it doesn't work at all"? I am missing key information :)
Did you connect it incorrectly to a 2.5" adapter and send power down the wrong pins? Does your bios see the drive?
Posted Aug 29, 2012 · 12:27 UTC#55
No, the bios does not see the drive. I even inserted to my laptop, no luck.
After I pulled out the drive from the Z2, I plugged it to my computer. I had the adapter but didn't have the power wire.
So I made my own power, maybe that was a mistake. I just know my drive is probably fried.
Posted Aug 29, 2012 · 12:42 UTC#56
It does sound like it's fried. That blows.
Posted Aug 29, 2012 · 13:10 UTC#57
Does the drive not use a standard sata power connector?
Posted Aug 29, 2012 · 13:33 UTC#58
no, It's a IDE , it uses those large 4 pin connectors.
Posted Aug 29, 2012 · 13:34 UTC#59
I just can't get it to work. I tried everything.
Posted Aug 29, 2012 · 14:15 UTC#60
There should be a molex connector on your motherboard. If not you could use the one from the optical drive. But if there is an extra connector the cables are cheap at most computer stores, a local best buy would have them too. I haven't attempted this yet and if the drive is an IDE drive that is problematic for me. When I built my computer I didn't worry about having legacy connections.
Posted Aug 29, 2012 · 15:29 UTC#61
Sorry for the double post, can't edit from my phone. I just thought about it tho. If you don't have any molex connectors on your board or drive, you can get an adapter for that too.
Posted Aug 29, 2012 · 16:29 UTC#62
I do have them. I finally found the power wire, still drive doesn't work.
Posted Aug 29, 2012 · 16:34 UTC#63
I too have no ide in my computer, I just used an external ide to usb connector, picked it up for 15 bucks which was probably high.
Posted Aug 30, 2012 · 04:33 UTC#64
Can someone PM with the link from where to download the update?
Thanks.
Posted Aug 31, 2012 · 00:35 UTC#65
Can somone please PM me the torrent link. I will seed for couple days after i get it on my server
thanks
Posted Aug 31, 2012 · 01:38 UTC#66
Thanks.
Nobody?
Posted Aug 31, 2012 · 13:20 UTC#67
Have fun.
torrent.zip
Edited Aug 31, 2012 by garrettoomey
Posted Sep 02, 2012 · 20:10 UTC#68
Does anyone have a European image to HD3?
Thanks.
Posted Sep 03, 2012 · 23:46 UTC#69
Thanks.
Some one has to buy it and install it then image the drive for you guys. Maybe a group buy or something similar will help you guys out.
Edited Sep 04, 2012 by garrettoomey
Posted Sep 05, 2012 · 02:24 UTC#70
I was having some problems figuring all this out as I bought my Z2 about 6 months ago and immediately upgraded the hdd to a 2010 Z3 80gb drive. I purchased a kingswin USI-2535 from Frys to connect to my laptop, but nothing. I read some reviews online and saw that it was severely underpowered and causing problems for many others. I returned it and got a SIIG USB 3.0 to IDE/SATA 2.5" enclosure and the magic happened. Im updating as we speak, I'll let you know if it goes smoothly! I read all the posts and all the supplemental info in links and such and was able to figure it out. Thank you to all of you for your help!!!
Posted Sep 14, 2012 · 04:43 UTC#71
My antivirus flags these two files as being potentially malicious. Anyone able to confirm these are safe?
HackTool:Win32/keygen
file:C:\Users\S\Desktop\Z3 2012 CNDV-1100HD HDD IMAGE\Acronis v10.0.4942\keygen-CORE.exe
file:C:\Users\S\Downloads\Z3 2012 CNDV-1100HD HDD IMAGE\Acronis v10.0.4942\keygen-CORE.exe
Posted Sep 14, 2012 · 10:41 UTC#72
It's the same file in 2 places on your pc. It is safe.
Posted Sep 14, 2012 · 10:41 UTC#73
Posted Sep 15, 2012 · 15:07 UTC#74
Thank you. Ever since one of my programmer friends got hacked, I've been paranoid.
Posted Sep 15, 2012 · 21:39 UTC#75
Quick question. I have a Z1 with a Toshiba HDD and the Z3 update and the 2010 maps.
So to install the 2012 map update can I burn the image to a DVD's and update that way or do I have to pull the HDD and hook up to my PC?
Sorry I looked around but couldn't find the answer.
Thank you very much for you help.
Page 3 of 13
