AVIC Z1/Z2/Z3 Upgrade to 2012 TomTom Maps Released!
By mikemaan · Aug 18, 2012in Hacks/Mods💬 315 posts👁️ 102,668 views
Page 4 of 13
Posted Sep 15, 2012 · 23:16 UTC#76
Drive must be pulled. The instructions are included in the download.
Posted Sep 16, 2012 · 03:31 UTC#77
Thank you very much sir!
Posted Sep 17, 2012 · 08:45 UTC#78
Hi....in the torrent file is included the map of Italy?
Posted Sep 17, 2012 · 12:31 UTC#79
No. Sorry.
Posted Sep 17, 2012 · 15:17 UTC#80
Hi everyone thanks for the hard work and always giving out the best info on all avic units. i have a z1 converted to z3 i dowloaded the 2012 maps and i also dowloaded the Part 125 & 132 files. these are in a rar form but iam not able to open them with unrar. is there some where else i can get these files or is there another rar software that i could use to un zip these thank you
Posted Sep 17, 2012 · 16:19 UTC#81
You don't have all the files. You need all 10 .tib files.
Posted Sep 18, 2012 · 04:47 UTC#82
Hi garrett i dowloaded the 2012 zip and i also downloaded the 125 and the 132 rar files but the 125 and the 132 won't allow me to unzip them do you know where i can get these files in working order thank you.
Posted Sep 18, 2012 · 04:52 UTC#83
garrett you say that there are only 10 tib files is that all that's neede to do the 2012 map upgrade?
Posted Sep 18, 2012 · 14:16 UTC#84
Yes, 10 .tib files from the torrent and acronis to install.
Posted Sep 18, 2012 · 22:36 UTC#85
thanks alot garrett keep up the good work
Posted Sep 19, 2012 · 09:02 UTC#86
Hi garrett...do you know where can I find the torrent of the European version?
thank you so much...
Posted Sep 19, 2012 · 11:45 UTC#87
I don't. sorry.
Posted Sep 22, 2012 · 19:28 UTC#88
with the RAR files... you need all of them... I don't remember how many... the two parts mentioned above were corrupted when uploaded and someone (using the PAR2 files included in upload) repaired them and posted them so no one would have to repair them themselves.
Posted Sep 22, 2012 · 20:51 UTC#89
Have fun.
Thanks.
Posted Sep 22, 2012 · 21:13 UTC#90
Have fun.
I downloaded the files but I'm getting an error from Acronis - the archive is corrupted.
Any sugestions?
Posted Sep 23, 2012 · 05:23 UTC#91
Make sure your using arconis 10... I tried using arconis 2012 and I got a corrupted error as well... once I used Arconis 10... all worked! hope that helps!
Posted Sep 23, 2012 · 21:55 UTC#92
It is Acronis 10 - Acronis® True Image Home® version 10.0 (build 4,942).
I'm trying to download the files again and give another try.
Thx
Posted Sep 26, 2012 · 21:23 UTC#93
Quick question for those with a successful update:
I'm coming from a stock Z2 and making the leap to upgrade to the Z3 software and the 2012 maps. So far everything matches up according to the threads however I'm wondering if there is supposed to be a noticeable difference on the maps. I haven't road tested it but they appear to look the same.
Posted Sep 27, 2012 · 00:52 UTC#94
They will "look" the same, but the database driving the images are updated.
Posted Sep 27, 2012 · 03:29 UTC#95
Thank you Garrett! I appreciate all the time you donate to this.
Posted Sep 30, 2012 · 13:46 UTC#96
I successfully performed the 2012 map upgrade, the unit is a Z1 which was originally upgraded to Z3 code and 2010 maps back 2 years ago. Everything works perfectly, but I now get this red as the crow flies line to my destination and I find it very annoying and useless. I looked at the configuration options and don't see a way to get rid of it. I'm sure this has been discussed, but I couldn't find the answer with a search either. Anyone know?
Posted Oct 02, 2012 · 17:45 UTC#97
Is this a dumb question or is there no answer to my question? What am I missing?
Posted Oct 03, 2012 · 04:44 UTC#98
The line showing your straight line to destination is something that has always been on my Z1... and i've upgraded every update... z1 to z2 to z3 2010 to z3 2012... every version on mine had that line. not sure if you just never noticed it or if mine was just different. Hope that helps!
Posted Oct 03, 2012 · 14:24 UTC#99
I guess it is possible I missed it on the previous release, but I would've bet it wasn't there when I was using 2010 maps. I guess I could put the old disk back in to confirm.
Posted Oct 03, 2012 · 15:26 UTC#100
I concur with dtomcat. It's always been there.
Page 4 of 13
