2012 US/CAN Maps - CNSD-310FM/UC upgrade (updated to supereasymethod - beta)
By pionara · Sep 20, 2012in Hacks/Mods💬 645 posts👁️ 199,662 views
Page 10 of 26
Posted Nov 10, 2012 · 15:14 UTC#226
Anybody willing or able to post the EU/UK 2012 Update to get this going for us UK folk?? :-)
Posted Nov 10, 2012 · 16:44 UTC#227
Gonna test now hope i don't brick this ish
The new method should not brick it. Either it will just work and do the upgrade, or do nothing at all and you will have to follow original method.
Posted Nov 10, 2012 · 16:56 UTC#228
Pionara everything worked perfect used the fix you provided only had to change out was the one file."If your unit does not prompt for upgrade when you put the sd card in the unit, then you may need a different CARDINFO.CIF file in the root of the SD card to get the unit to recognize the upgrade. (identityexpired reported that he had to use the cardinfo.cif from CNSD-210FM update in order to get his Z130BT to recognize the update, see post #12)."
Z110-BT that made its way to Z130-BT format and now updated to the latest.
Edited Nov 10, 2012 by mandroid2010
Posted Nov 11, 2012 · 15:15 UTC#229
i found a super simple method to update. I updated first post.. need some folks that havent updated yet to test and let me know if it works without hacks, dlls, password, testmode, etc etc
I want the updated maps, but don't want to give up voice control of navigation, otherwise I'd be all over this. Thanks for the hard work!
Posted Nov 11, 2012 · 20:11 UTC#230
did this update with success on a z130bt
1. unzipped update directly to sd card that was formatted fat32
2. copied the new verinfo.dat file
3. popped the card in and the update started immediately
note: at first i did copy the cardinfo file from the CNSD-210FM update. but that did not do anything at all. so i used the one from the original update zip and it worked like a charm.
Posted Nov 13, 2012 · 01:22 UTC#231
Went through the whole new easy process and it worked!
However it does not show the new ui. Is it supposed to?
Posted Nov 13, 2012 · 01:38 UTC#232
can you be more specific? what do you mean by new ui?
please go to settings, service info, and hold very top left corner down.
Report all of the versions here. Please do NOT post your device number.
Edited Nov 13, 2012 by pionara
Posted Nov 13, 2012 · 11:53 UTC#233
New VERINFO.DAT
I can also use it for cnsd-210fm EU
thanks
Posted Nov 13, 2012 · 15:02 UTC#234
No the VERINFO.DAT i posted on this thread is only for CNSD-310FM/UC.
If you can send me the VERINFO.DAT from cnsd-210fm EU, I can generate a version of it that does not require password, and will post it on the cnsd-210fm EU thread.
Posted Nov 14, 2012 · 01:23 UTC#235
Perfectly working,
Thank You SHEKA, PIONARA, AND CONDI to made this upgrade possible!
Posted Nov 14, 2012 · 01:52 UTC#236
i had to download the appradio app to get appradio mode working.
it's ok i guess. i think it just mirrors certain compatible (native and 3rd party) apps out on the video display.
What would be cool if pioneer would release the specs on how to make your app appradio compatible.
What appradio app are you referring to? Is it Pioneer Appradio app for Android or Iphone?
I am asking this since Pioneer claims that the Android app is for Pioneer SPH-DA01, which is not the same as AVIC-X920 or AVIC-Z110, etc.
What is appradio mode? Is it the screen where Pioneer GUI has icons/shortcuts listed vertically on the left?
I upgraded my X920BT to 4.0.0.1 (system) and 3.24 (bluetooth), but I see no AHA or Pandora icons/ anywhere on its GUI.
Should they appear right after booting up? Or only after Pioneer pairs with the phone that run AHA radio or Pandora apps?
I am asking as I am trying to understand why I don't see those icons on Pioneer screen.
Posted Nov 14, 2012 · 02:06 UTC#237
i only saw pandora/aha icons on the left icon bar (along w/ ipod icon) when I have iphone plugged in. Dont have android so not sure on that one.
Posted Nov 14, 2012 · 02:33 UTC#238
I got this to work. My appmode was set to wired rather than bluetooth. Everything now works just fine!
Posted Nov 14, 2012 · 03:51 UTC#239
What works? Android AppRadio???? What apps? Or just the built-in Pandora and AHA?
Posted Nov 14, 2012 · 06:42 UTC#240
What works for me:
AHA Radio and Pandora can now be controlled directly from my Pioneer AVIC-x920BT. This happened as soon as I changed the appradio mode (on Pioneer) from wired to Bluetooth.
The appradio app that Pionara referred to (I guess) is an Apple Store App that can be used for Pioneer integration. However I am not too sure how that works, as I don't use iPhone.
The Pioneer Appradio App for Android is made specifically for Pioneer SPH-DA01 or similar units, and therefore does not apply for Pioneer AVIC-X920BT.
Edited Nov 14, 2012 by krekeris
Posted Nov 14, 2012 · 12:48 UTC#241
What works for me:
OK, so nothing new. From your "I got this to work" post, I wondered if you found a way to get Advanced App Mode to work with Android.
Before you couldn't find the AHA and Pandora icons. Did they show-up in the AV source wheel after you switched to BT in the AV System settings? I thought they were always there
Posted Nov 15, 2012 · 17:14 UTC#242
I was able to upgrade my X930BT with out any issues. Thanks for putting all this together!
The appradio features are cool. Though the picture quality of the apps don't look as sharp as on the pioneer website.
Posted Nov 16, 2012 · 02:49 UTC#243
I know - all of their marketing makes it look as if they have Retina screens on them ;)
Posted Nov 16, 2012 · 04:46 UTC#244
Gonna give this a try on my x930bt I just recently installed. Im looking forward to the android features. Is there any other perks than the android connectivity?
Posted Nov 16, 2012 · 15:03 UTC#245
After reading a lot of posts en looking at the Pioneer website, I am a bit confused...will the appradio functions work with Android on a X/F900BT series HU, upgraded to the latest firmware (940BT)? or is this functionality only for iPhone?
Posted Nov 16, 2012 · 15:28 UTC#246
bnwgraaf,
what I have heard is that appmode/bluetooth for android only works for aha/pandora apps. The actual "advanced appmode" is only for iphone, and only AppRadio2 (SPH-DA100?) supports android "advanced appmode"
It is on the pioneer website. I found their exact support matrix somwhere, and posted it on another thread about this (but cant find it now).
Posted Nov 16, 2012 · 16:35 UTC#247
Thanks for all the work on this!
I have an X920 and a Z120, both of which had been upgraded to x30
I used pionara's super-easy method, and they are both now x40
Only problem(unrelated to upgrade) is that the X940 bluetooth isn't working, and it seems from some older threads here that's it's a hardware problem. Grrrr!
Posted Nov 16, 2012 · 16:47 UTC#248
bnwgraaf,
Thanks for the clarification I too was a bit confused on the android functions! On another note does this upgrade prevent you from doing other mods ex. removing the warning screen when switching to navigation?
Posted Nov 16, 2012 · 16:54 UTC#249
No. you will just need to reapply the mod to the new version after updating. In my thread for removing nag screen, I have info about the navi.exe with this version (4.010)
Edited Nov 16, 2012 by pionara
Posted Nov 16, 2012 · 16:59 UTC#250
Sweet thanks again for the info!
Page 10 of 26
