2012 US/CAN Maps - CNSD-310FM/UC upgrade (updated to supereasymethod - beta)
By pionara · Sep 20, 2012in Hacks/Mods💬 645 posts👁️ 199,662 views
Page 24 of 26
Posted Oct 29, 2013 · 22:49 UTC#576
Thank you for responding RonS!
I did unzip all the files to a temporary folder.  However, there are no folders in zip file but there is a file named CARDINFO.cif another named updater.plf but i don't see a file or folder named FIRMWARE?  I downloaded the file twice just in case the first download was missing files.
Any help is appreciated.  Thanks!
Where are you getting the upgrade from and what is the file size (of  the zip file)?
Also are you using a MAC or a PC? What program are you using to unzip?
Posted Oct 29, 2013 · 22:59 UTC#577
Downloaded form anir22 above, the zip file is 2.23GB.  I am using a pc, unziped with WINZIP.
Posted Oct 29, 2013 · 23:08 UTC#578
My initial download was from IAmSuperBleeder post #301.
Posted Oct 29, 2013 · 23:40 UTC#579
Sorry, I never use torrents. Don't trust em. Even using that link I ended up with some malware that a MalwareBytes scan detected and deleted.
I'm also a little rusty with  WINZIP. Does it have an option to extract subdirectories? I know one of the popular zip/unzip programs does.
Posted Oct 30, 2013 · 00:13 UTC#580
Does any one have a link or any other information as to where I could obtain the files needed?
.to upgrade the X930BT.  The image in post #272 shows the files in folders which is different form what i have.
THANKS!!!
Posted Oct 30, 2013 · 11:41 UTC#581
THANKS!!!
This is a snapshot from a Mac.  You'll never get this on the X930BT.  To get these files, download http://thepiratebay.sx/torrent/7672652/Pioneer_2012_US-CAN_Map_Upgrade
Posted Oct 31, 2013 · 21:56 UTC#582
Success!!!
I am using WINZIP Pro and it was extracting all the files out of the folders.  I changed to classic view in WINZIP and it extractid all files and left them in the proper folders.  30min to update my X930BT.
Thanks for trying to help RonS.
Posted Nov 02, 2013 · 01:07 UTC#583
Going to try this with my x920bt ::crossing fingers::
Posted Nov 02, 2013 · 03:24 UTC#584
Having a heck of a time getting this working in my BRZ with the factory X9310BT.  Detects the card just fine, but I never get the upgrade message.  Formatted on a PC (native OS as well as SDformatter), as well as tried on a Mac.  Extracted with winrar, 7zip, and Thearchiver (mac).  This 4GB card was previously used successfully to replace the startup screen, so it reads fine.  All I get when inserting is the page that shows screensaver options/etc.  What could I be missing?
Edited Nov 02, 2013 by nocturne1
Posted Nov 02, 2013 · 04:06 UTC#585
Try a different cardinfo.dat file.
Posted Nov 02, 2013 · 04:08 UTC#586
I left that out.  I did also try the one in step #3.  Are there others that I should be trying?
Posted Nov 02, 2013 · 04:39 UTC#587
Bah.  Nevermind.  Didn't realize that the US BRZs aren't Pioneer - it's a Fujitsu Ten.  Crap.
Posted Nov 16, 2013 · 23:37 UTC#588
just did this update on my z130bt worked like a charm... thanks to everyone for posting this up..
Posted Nov 20, 2013 · 06:07 UTC#589
I just did this update tonight and worked without any issues, many thanks all for your help!  One question - what are the Mecha and CAN versions referring to?  My Mecha version is the same, and the CAN version changed from having values to --------- instead.  Is this indicative of an issue?
Posted Nov 24, 2013 · 01:45 UTC#590
Hey guys if wanting to upgrade from an ORIGINAL z110bt with no previous updates whatsoever can I simply follow the instructions on page 1 and I will have the latest and greatest z140 software AND maps?
Edited Nov 24, 2013 by 02'topaz
Posted Nov 24, 2013 · 04:42 UTC#591
I believe u can go from 110 to this.
I  wouldn't worry so much about that
Edited Nov 24, 2013 by rgarjr
Posted Nov 24, 2013 · 04:43 UTC#592
Yes. That is what I did.
Posted Nov 26, 2013 · 02:57 UTC#593
Worked amazingly! Thanks for all your guys incredible work!
Posted Dec 04, 2013 · 16:06 UTC#595
so, I managed to find this AFTER I updated with the hack to 2011. I thought I saw it in here somewhere, but now I cant find it. will this work as is on the hacked 2011 install? where I used PASSWORDPASSWORD to do the update?
Posted Dec 04, 2013 · 21:36 UTC#596
I put the 3 files on the SD card (after updating the VERINFO.DAT) and the Z110 doesn't do anything after inserting the SD card
Posted Dec 05, 2013 · 19:34 UTC#597
How many files are supposed to be on the SD card? I have 240. I have the X9310bt so I do not have the cardinf file. Is 240 the correct count?
Posted Dec 05, 2013 · 22:42 UTC#598
From what source?  If you're talking about the 2012 US/Canada maps, it should be 228 files (5.61gb).  Well, at least, that's what I have.
Posted Dec 05, 2013 · 22:49 UTC#599
I was talking about the entire .rar downloaded from the torrent. At this point, I'll take any files that work. :)
Posted Dec 06, 2013 · 00:21 UTC#600
I followed the instructions to a tee. I then discovered I have a x9310bt instead of a x930bt. I made it to %51, then the update asked for the SD card. I was stuck at the screen asking for a SD card, so I deleted the file mentioned in #20. This got my radio working but nothing else. At least I had a radio for the ride home. I extracted all the files again and tried it all from the beginning. The radio will not go into update mode now. Does someone have a copy of StartKnd.log?
#20: I think you can kick the unit out of upgrade mode by deleting \USER\SYSTEM\Download\StartKnd.log
(a value of 0 in this file means start normally. 1 means upgrade, and there is 2 and 3 - not sure what those do.) I believe if this file is missing or zero inside, it will try to start normally.
Page 24 of 26
