I successfully upgraded my X920 to version 4 using the guide from the first post and wanted to give some feedback based on my experience. Some of the installation details are somewhat murky because of how long this thread has become. If there isn't one already, a consolidated step by step should be posted in the forum's FAQ area.
- You will need at least a 4GB MicroSD card to do the firmware and map update at the same time. 8GB cards can be found on Amazon for $7.
- The torrent file has a folder inside of it that has a file you need to copy out in addition to the other two files on the original post. I cannot remember the name of the folder at the moment but it has a read me.txt file inside of it that tells you exactly what to do. I didn't do this the first time and I got the "insert correct SD card error". I'm not sure if this is related to not taking the aforementioned step or because I tried un-rar'ing the map update on my Mac. On my second try I did everything on my PC and did the file copy from the torrent folder and everything worked. In addition, the second time I attempted the install the actual unit went into some sort of DOS mode and displayed a message that it had copied some files. At that point I couldn't do anything so I recycled the ignition with the SD card still in the unit and when it booted back up, it went into the firmware update and finished 30 minutes later with no issues.
If anyone is reading this and would like to clarify the above, please feel free. Thanks to all those who contributed to this hack!
