2012 US/CAN Maps - CNSD-310FM/UC upgrade (updated to supereasymethod - beta)
By pionara · Sep 20, 2012in Hacks/Mods💬 645 posts👁️ 199,662 views
Page 21 of 26
Posted Jun 03, 2013 · 12:02 UTC#501
Ok, I did everything in the instructions for my X920BT and when it hits 99% i get incorrect SD card error.  This happened twice then I switched to another sd card that I used for the previous update to to 3.0  and I got the same error again at 99%.  I'm at a loss for what to do.  Now my radio is stuck in the update mode.
Please help
Kevin
Are you sure your download was successful?  Even if you copy the files on 20 different SD cards, they will all fail if the download itself wasn't good.
You didn't happen to be using a Mac to unzip the archive, did you? I recall that this has caused corrupted files. It might depend on which program you use. Search for mac or iWhatever (sorry, I don't follow Apple). If you can't find a PC, maybe you can find out what programs are known to work.
Edited Jun 03, 2013 by RonS
Posted Jun 07, 2013 · 20:22 UTC#502
Where can i find 3.01 for z130bt so that i can downgrade
Posted Jun 10, 2013 · 23:06 UTC#503
Successfully upgraded my X920bt that had been previously upgraded to 3.0. Did everything as listed on first post and had just 1 issue. It was one of my Micro SD cards wouldn't read. But I think it was because there was a name associated to the card. The 2nd card I had I formated and didn't name the card. That one worked with no issues. Also upgraded the BT Firmware with no issues. It's nice to have Iheartradio!
Posted Jun 21, 2013 · 23:53 UTC#504
Update works perfectly on a x930bt with 3.001. Thanks for the hard work looking forward to the next update.
Edited Jun 22, 2013 by Danthaman2786
Posted Jun 22, 2013 · 19:34 UTC#505
Worked great on my X920.  Now I just need to find a way to get video out from my iPhone 5.  Thanks!
Posted Jul 01, 2013 · 21:23 UTC#507
When I try to enter PASSWORDPASSWORD for the asked password it keeps asking me if I want to retype the password.  Do you know how to fix it?
Posted Jul 01, 2013 · 21:42 UTC#508
Where in post #1 does it say anything about entering a password?
Posted Jul 01, 2013 · 21:45 UTC#509
Answer no :mrgreen:
But seriously, by downloading TestMode (see http://avic411.com/index.php?/topic/31534-condis-hackmode-v14-diskrw-gpsgate-textfiller-regeditor-with-reg-files-associated-updated-13062011/ and make sure you use v1.4), you can access the text file that has your current password.  You can view this file to ensure the password you use is the right password.
Posted Jul 10, 2013 · 11:35 UTC#510
Upgrade worked perfectly on a Z110 upgraded to Z120. Bluetooth update said it failed but shows as version 3.24? Only thing that does not work is streaming Pandora via Bluetooth. I changed the App from wired to bluetooth with no luck. I am using a iPhone4S. Any ideas?
Posted Jul 10, 2013 · 11:58 UTC#511
I don't have an iPhone, but I recall you must use "wired" because apple OS doesn't support BT SPP (Serial Port Profile) required for BT apps. The Z140 manual pg 132. What isn't clear is whether the old usb/ipod cable (CD-IU50V) works, or if the newer CD-UI51V is required. Someone can probably answer, or you could try whatever you have.
Posted Jul 12, 2013 · 03:13 UTC#512
Can someone tell us how to downgrade please
Posted Jul 15, 2013 · 16:50 UTC#513
I second the downgrade instruction request.  Obviously someone on here accomplished it and I have all the old files, but I can't get the unit to do a thing.  It's ignoring my SD card with the older firmware.  I read in a previous post regarding different equipment that you needed to change the file containing the firmware version to a larger number, but the file referred to in that post is not present on the Z1xxx firmware as far as I can tell (MPU.bin).  Any help would be greatly appreciated.  As it stands, the unit tries to take me anywhere from a few miles to hundreds of miles out of the way when using the nav function - it's bizarre..
Thanks in advance,
Posted Jul 15, 2013 · 17:51 UTC#514
There was a post from someone who did it a while back.He didn't give any details but said to use Testmode and the "Program Force Write" operation - menu item 3 Careful, sounds dangerous. Just make sure you have a backup.
Posted Jul 25, 2013 · 04:44 UTC#515
I just did this upgrade on my avic-z110bt worked great , So I now have a avic-z140 bt           :)
Posted Jul 25, 2013 · 05:54 UTC#516
Ok having a bit of an issue after moving my z110 to my wife's car.
it is asking for a password.  I have tried every thing for a password and no luck.
you can read more details in my other thread.  (sorry for duplicate just want this to work for our trip on friday)
http://avic411.com/index.php?/topic/37133-z110-w-2012-maps-password-required-after-battery-disconnect/
if anyone can help it would be greatly appreciated.
Posted Jul 25, 2013 · 12:49 UTC#517
There are already several threads on how to find and/or remove passwords - using TestMode file manager to delete the password file.
I think the process is about the same as this -> http://avic411.com/index.php?/topic/37025-how-to-retrieve-your-avic-x850bts-forgotten-password/?hl=password
I also think you can just remove the Security.dat file to totally remove the password. Be sure to read the whole thread, there are some helpful comments at the end.
Edited Jul 25, 2013 by RonS
Posted Aug 10, 2013 · 14:15 UTC#518
Howdy everyone. This is my first post. I just used this to update my X920bt and it worked flawlessly! Thanks to all who contributed! Keep up the good work. JB
Posted Aug 11, 2013 · 02:25 UTC#519
Big Thanks to Pionara - for providing this procedure - and all your hard work.
I follow the first post - then read the rest of this forum, gave it try and followed your directions, and it worked like a charm.  I have an AVIC X920BT that had been upgraded to CNSD-210FM.  Wanted to get the latest maps and BT software - seems to work well on my machine with an Iphone 4S.
Shout out to all the others who worked to make this happen, this forum really is great.
Posted Aug 12, 2013 · 13:54 UTC#520
Anyone had issues with Bluetooth after completing this upgrade?  My phone has issues staying connected to the Bluetooth, which worked fine before I ran the upgrade.  Is there something I'm missing here?
Posted Aug 12, 2013 · 14:00 UTC#521
Did you install the BT update on the SD? It is a separate step after the CNSD-310FM upgrade.
Posted Aug 12, 2013 · 14:58 UTC#522
Yeah, ran the firmware update first.  Once that completed, went in and ran the Bluetooth upgrade.  Everything completed successfully as far as I could tell.
Posted Aug 12, 2013 · 15:16 UTC#523
OK, just checking. To answer your original question, no - I'm not noticing any difference in connection reliability. I often need to re-pair due to frequent Android OS updates (I am using a very hacked phone which was originally running WinCE (HTC HD2)).  Someimes it takes a couple tries before everything settles-down and works properly.
Posted Aug 14, 2013 · 03:54 UTC#524
to catzcatz or any other member, did this work from version 1.0000 or did i need to do an update from 1.0000 to 1.0001 first?
sorry for the noob question but it wasnt addressed from the first post and I would not like to brick my unit.
Posted Aug 14, 2013 · 12:43 UTC#525
You can go directly from any version to CNSD-310FM using the "supereasy" method. The old way required using an intermediate "patch" release to install the hacked  password-checking code before installing the upgrade..
Page 21 of 26
