2012 US/CAN Maps - CNSD-310FM/UC upgrade (updated to supereasymethod - beta)
By pionara · Sep 20, 2012in Hacks/Mods💬 645 posts👁️ 199,662 views
Page 6 of 26
Posted Sep 24, 2012 · 23:06 UTC#126
Wow. Everything worked. All my radio, phone Bluetooth etc all retained.
Thanks for the help guys. Reformatting worked. Also If you have 130bt, just extract the 140 Zipfile and use it straight up. No need to swap files.
Posted Sep 24, 2012 · 23:07 UTC#127
Coolin72
No redownload. Just reformat the sd
Posted Sep 24, 2012 · 23:08 UTC#128
Okay...now start up navi screen bypass hack. Lol.
Okay may be I'm asking too much :)
Posted Sep 24, 2012 · 23:50 UTC#129
Hi Guys,
Just to be clear, does this upgrade only work if you have upgraded from CNSD-210FM or on a z130bt/x930bt? For example, can one go directly from Z120bt stock to Z140 using the hack described in this post?
Thanks in advance.
Posted Sep 25, 2012 · 01:14 UTC#130
I tried to do this on an X920BT which I previously upgraded to the X930BT firmware (legit upgrade)
When I ran the SD card that I extracted the RenewalIFLib-AUTO-REPLACER v1.1 to, the screen turned red with the error
ErrInfo0 = 294 ErrInfo1 = 0
VERSION = $Id: TST_ScriptCopyCmd.cpp 4230 2009-09-18 00:47:26Z otsuki $
I wasn't sure if that was expected or not, so I placed the other SD that I extracted the Z140 firmware update to, booted up the unit with the card inserted, but it didn't boot off of it.. It just booted into the normal mode.
Anyone have any suggestions?
-Keith
Posted Sep 25, 2012 · 01:16 UTC#131
-Keith
Oh NM.. I think I see what I did wrong.. I thought the script included the .dll.. it doesn't... I'll try that now..
Posted Sep 25, 2012 · 01:21 UTC#132
How do you get the DLL? That is where I am stuck. I can't seem to figure it out.
Ok, found the DLL. Ran the auto replacer and now it won't update. Trying to reformat the card and trying again.
Edited Sep 25, 2012 by KraziJoe
Posted Sep 25, 2012 · 03:09 UTC#133
Posted Sep 25, 2012 · 03:11 UTC#134
I got it! I'm going to post the complete steps I took tomorrow, but I copied the dll from my prog0 folder, not prog1. I had to use the cardinfo.cif from my 930 update for it to load the firmware.. I now I have x940 firmware on my x920!-Keith
Posted Sep 25, 2012 · 04:38 UTC#135
I got it! I'm going to post the complete steps I took tomorrow, but I copied the dll from my prog0 folder, not prog1. I had to use the cardinfo.ciperma 930 update for it to load the firmware.. I now I have x940 firmware on my x920!-Keith
Lucky.
Mine seems to be messed up. Now nothing loads.
Ran the dll replacer and replaced it. Put in the 140 update and nothing happens. Tried 3 different cardinfo files and nothing worked. I hope its not permanently hosed
Posted Sep 25, 2012 · 08:43 UTC#136
Hi Guys,
Thanks in advance.
To answer my own question, yes one can go directly from Z120bt directly to the CNSD-210FM to get to a z140bt. The only change was to replace the CARDINFO file with the one found in post #12. Update went well, took about 20 min.
Posted Sep 25, 2012 · 10:19 UTC#137
Before I do the upgrade I am curious if the VR still works on the X920 ?
If I remember correctly the X940 has no VR
Posted Sep 25, 2012 · 11:46 UTC#138
Did you see post #58? There are lots of changes in features between the models. Some are subtle, some might be show-stoppers (especially if you don't really need the latest maps). No POI VR for Nav in the X940 or Z140.
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/AVIC-Z110BT-Z120BT-X920BT_UpgradeInstructions_NAVTEQ.pdf
BTW, a dash "-" in a column of the table on pgs 17-19 doesn't mean that feature isn't available, it just means "no change" for that group. It can be confusing.
Edited Sep 25, 2012 by RonS
Posted Sep 26, 2012 · 00:42 UTC#139
I did the upgrade and it worked like a charm
Thanks to everyone that worked on putting this together
The x920 still has VR and I haven't noticed anything missing
It also still has the issue with not being accurate when at a intersection
But I am used to dealing with that
Posted Sep 26, 2012 · 01:27 UTC#140
Are you saying your VR still works for Phone, changing audio source, and iPod control.... Not NAV POI or destination address?
I just want to make sure I understand what VR still works.
Posted Sep 26, 2012 · 04:32 UTC#141
Pretty easy upgrade.
Units : Z110BTs that have been upgraded twice (--> Z120BT, --> Z130BT).
Used two freshly verified/tested (using h2testw 1.4) and formatted (FAT32) SD cards (1GB, 16GB).
1 ) Extracted "RenewalIFLib-AUTO-REPLACER v1.1" to 1GB SD card
2 ) Extracted "Modified - RenewalIFLib" (from http://avic411.com/i...de/#entry255690 ) to 1GB SD card
3 ) Inserted SD card into units
4 ) Booted up Z110BTs @ Z130BT - Condi's script executed successfully and replace the units' RenewallFLib file
5 ) Rebooted units to verify that they were still working (no problem)
6 ) Extracted contents of "Z140 Files.rar" to 16GB SD card (root contained "FIRMWARE", "Update" and "CARDINFO.cif")
7 ) Replaced CARDINFO.cif with the one from http://avic411.com/i...de/#entry255690 )
8 ) Inserted SD card into units
9 ) Update
10) DONE! :D
Edited Sep 26, 2012 by whobedaplaya
Posted Sep 26, 2012 · 04:53 UTC#142
you forgot step 11 = beer
Posted Sep 26, 2012 · 05:23 UTC#143
Heh, no worries, I didn't forget. I need to PayPal you and Condi a beer each :)
Notes :
A ) No nav VR (completely gone from the VR menu)
B ) AV Menu (especially for the iPod) scrolls smoother and seems more responsive than before (Z110BT @ Z130BT)
C ) POI results are now listed in ascending distance order (I always had to hit "Sort" twice to get it to list the closest ones first in all previous nav software versions)
Edited Sep 27, 2012 by whobedaplaya
Posted Sep 26, 2012 · 08:45 UTC#144
VR still works for calling and music
However VR for nav is gone
Not sure about IPod control as the IPhone currently doesn't work with the AVIC
One thing I wish they would have included was the ability to enter a zip or postal code
That feature was in my old F700 and it was great for entering a address
Posted Sep 26, 2012 · 08:47 UTC#145
Sorry ment to say iPhone5 currently doesn't work with the avic
Posted Sep 26, 2012 · 15:34 UTC#146
Ok, one I haven't seen definitively answered yet. I have a Z110 that is completely original. Do I have to upgrade to any other version first, or will this upgrade directly?
Thanks much!
Posted Sep 26, 2012 · 17:46 UTC#147
same question for me..... I have a "virgin" Z110BT. nothing has been ever updated on this unit. It's been sitting in my garage for a while and I want to install it in my truck. I want to update it to the Z140BH software. From what I understand from reading this thread, I have to first update to the cracked z120 software, then do this Z140BH procedure? Am I going to get all the same functions on my Z110 as the new Z140 has? or is the actual hardware of the Z140 different?
also, is it worth updating to the Z140 software? Or should I just go to the Z130 version and retain the VC feature?
Edited Sep 26, 2012 by xpl0sive22
Posted Sep 26, 2012 · 18:21 UTC#148
iPod voice control still works just fine. Without it, navigating my iPod Classic 160GB would be very, very painful.
To be honest, the voice recognition for nav was always kind of "meh" for me (across all software releases - Z110BT, Z120BT, Z130BT) so I don't think I'll miss it much, eg. I'll ask it for the nearest Fry's Electronics, and it'll give me directions to Bone Daddy's (not that I'm complaining :P )
Posted Sep 26, 2012 · 21:22 UTC#149
Thanks worked great !
Upgraded 930BT took about 30 mins. .
Posted Sep 26, 2012 · 23:05 UTC#150
I post this in the event anyone with a native z130 was as confused as I was after getting to page 10 of this thread and is experiencing issues trying to upgrade.
I read the entire thread several times but still had some issues. I believe I got confused with the different Condi Hackmode/testmode versions/stuff. This is what I did:
I initially attempted to use the Condi Hack v2.0 by installing it on a card separate from the z140 files. This gave me a RED SCREEN which I hoped was normal. When I installed the z140 CD card it recognized the update and asked for a password. It wouldn't take the password. So I figured the RED SCREEN meant something didn't work right.
Then, I did the following and it seems to work. I have two SD cards; one for the Hackmode/Testmode stuff and one for the z140 files
SD CARD 1 - Testmode Files
1. On SD card 1 I put the contents of "RenewalIFLib-AUTO-REPLACER v1.1" in the root.
2. I then put the contents of "Modified - RenewalIFLib" (which is just a .dll file) in the root as well.
SD CARD 2
3. Installed the extracted files from the z140 upgrade to the root of the card. I changed nothing.
I then:
4. Installed SD CARD 1 to the z130 and got a "Success!" message. The .dll file copied successfully.
5. Installed SD CARD 2 to the z130. It recognized the update and asked for the password. This time it took the 16 digit password and the update started. It read: UPDATING... Time Left: 22min
At the end of 22min it did another install (as mentioned) that took less than a minute.
6. Unit rebooted and everything looked good. I had to go back through setup.
7. Navigated to bluetooth setup and selected upgrade firmware. Current version was 3.22. It upgraded to 3.24 and it took about 5 minutes.
Page 6 of 26
