Hi Bento,
can you explain what is the ntq_2012Q1.zip.nzb for? I haven't used it and my Avic F900BT works just fine...
What is it for?
Thanks a lot!
Hi Bento,
What is it for?
Thanks a lot!
It's an NZB file to download the maps from Usenet.
I have found newer maps last night TA 2012 Q2. I installed Firmware version 4 on my unit with the Windows CE upgrade and those Q2 maps. The unit feels a lot snappier and my speedcams and POI's are working again ![]()
Will post later this week.I still need a Dutch sys.txt because the navigation part of my AVIC is now in English.
Hi Bento,
yesterday I installed again the 4.01 of Encrypt3d, with your maps, my buildings, Robser's radars... everything is working fine, including TMC, but I am only able to use the Phillipa UK voice. I put several Spanish voices on the Voice folder but don't seem to work...
Is there something else I have to do besides adding the voice zips into the voice folder??? I am getting tired of trying different things and noone works!!
Thanks for your help!
Btw, there is another thing I would like to know. When I tick Speed Warning alarms, depending on what installation I have done, sometimes I can see a menu that it says "SIMPLE, APPROACHING, DISCONNECTED", and sometimes the same menu shows "ONLY IF OVERSPEEDING, APPROACHING, DISCONNECTED".
Does anyone knows what file is responsible for this??? I would like to select "ONLY IF OVERSPEEDING", and unfortunately, it is showing right now "SIMPLE"...
Hi,
I finally changed one of the spanish.zip files in the voice folder and voila! works! Now I can get directions in Spanish...
Regarding the Warnings of Speedcams, it depending on the day, sometimes shows "simple", sometimes shows "only if overspeeding"... that is really weird! How it can happen that without changing any file, the speedcams options change?? I am really surprised...
Have a nice weekend!
@Trulf
Just read your posts above. When you said you got your TMC working? did you mean you can use both Blouetooth and TMC (traffic ifno) at same time. Because I can only get one thing working. If i use "UC" command in sys.txt then bluetooth works but TMC don't. However when I select EW, then TMC works not bluetooth.
Any help much appriciated.
@Fred3112
If you still couldn't extract the file, use 7-zip because Winrar or Winzip wont work with it as I had the same issue and only 7-zip worked.
Matyana,
My backup 4.01 works perfectly fine... both bluetooth and tmc (for Europe). If you send me a PM we can try to arrange something so you can get my backup.
Best,
Alfonso
Hello ![]()
My sister bought used car with AVIC-HD3. Problem is that she doesn't have slovenian maps and also others are quite old. I am wondering if this TomTom release would work and what updates would i need?
Yesterday i succesfully unlocked disk but problem is that i have no proper maps and *fdl files are not suitable for that firmware.
Help appreciated.
Thanks in advance.
iztokmlk - avic-hd3 is not same kind of unit
more like avic-z3 i think... check those forums
http://www.pioneer.eu/uk/products/25/38/301/CNDV-1100HD/page.html
Problem with CNDV -1100HD is that it doesn't have maps for Slovenia. There are only 26 other European countries. Any other possible solution?
@Alfonso
Thanks. Msg sent
I did everything in the guide, but still no luck. Tried deleting unneeded voices and other stuff, but it still complains about insufficient storage space when copying your maps to iGo/Content folder. What am i doing wrong? my unit is a F900bt
Good luck!
I did that... Deleted Maps and poi folders, as the guide says, and then copyed the new maps and poi, but it still says "not enough disk space". How do you other guys get enough space?
The new maps with poi is over 2 Gigs and the old which i deleted is around 1,5 Gigs. How much internal space, does the F900bt have?
Flash Disk capacity is 2gb... but I have maps, pois, buildings and everything with 1.5gb, don't know what you are putting in your SD!!!
but the maps from this thread/guide is much larger than 2gb when extracted?
Not in my case... I don't know what you are doing wrong. The size of the flash disk is 2gb, so total amount of data must be 1.5gb, 1.9gb... no more, and that includes LPT1, LPT2 and LPT3 (not just the igo/maps folder).
okay, so if the total size of the flash disk is 2GB, how on earth do you want me to extract the content of the 9 zip files from Bento, to the flash disk, when the extracted files from the 9 zip files, is 2.04GB? Am i freeking stupid, or what is going on here?Even if i delete the MAPS, POI and License folder, whitch i did every time i tried making this work, that will only free up 1.5GB of space, not even close to be enough, to get the 2.04GB from this guide on the flash disk:-P
I too have 2.04 GB when NTQ_2012.Q1 from rapidshare is unpacked with 7-Zip:
ezrider.exe = 5.99MB
POI (folder) = 274MB
MAP (folder) = 1.76GB
LICENSE (folder) = 16KB
On my 900BT flash disk the folders (as found using this guide) are the following:
ezrider.exe = 6.38MB
POI (folder) = 62MB
MAP (folder) = 1.01GB
LICENSE (folder) = 5KB
I am prepared to delete some of the countries to squeeze it on the unit but do i need to? I have a 32GB SD Card but I do not want to run into the same problems as others - can someone confirm how they got this to work? Basically, have I messed up somehow and, if not, will this extra approx 1GB just copy straight across?
I am moving to Germany on monday and really want to get my 900BT updated before I go. Alfonso / Trulf you are the most recent poster who references the 4.01.zip from elsewhere, any idea where i can find a working link for this I would love to emulate your efforts but cannot find it anymore.
And (sorry) can anyone confirm that I am ok to install these maps over:
Map version: 02.000600
Version: 3.021000
Again on a F900BT Europe.
Send me a PM and I will try to send you a copy of my backup 4.01, that's all I can do.
Try winrar or winzip
Second SD card after you started WIN CE should just work fine
There are a lot of mods here. Make sure you read and understand the basics.
hello mate i am currently on very first version, is there any guide or could you tell me how can i get to version 3.021, f900bt UK,
my current version is 2.009, map version 1.0000.. something like that.
please tell me how to update it to version 3.021 or the latest firmware.
thanks my systems never been updated before, also i have took my backup incase something goes wrong.
thanks
Hi Bento,
Had any time to upload the Q2 maps?
Kind regards
didnt work for me
avic f900bt firmware 3.00 maps 2.00
just hangs on splash screen then reboots
i noticed that the license folder on my unit was in the same as ezrider not sure if thats anything to do with it.
