EssTEye said:
One question before I order. I see that you say that your lights don't flicker, in fact, the CAR doesn't even see the unit installed, however, I also read in your explanation about the duty cycle that it turns on your lights for 1/3000 of a second, promting this question...
Your lights do not flicker. The car will never know it's installed. I'm sure I mentioned something in my duty cycle discussion, but I didn't go back and re-read it and I don't remember what I wrote, but either I mistyped or you misunderstood. I probably wasn't clear enough. In the duty cycle thread your car might be pulsing your interior lights (not your headlights) like that. Your car does this to dim the lights (12V for 1/100 of a second, ground for 1/100 of a second and it does it so fast you won't notice the flicker but the interior bulbs will be dim). I do not do this to anything, but I can sense such a signal which "might" be put out by your car and work off of that if need be. Normally you want to tap off the "ill" wire which is 12V with the lights on and nothing with the lights off, but some cars might have a "signal" like described above for interior lights to allow them to "dim" and I tried to make my circuit smart enough to work off both (in order to make it work better in all sorts of vehicles).
EssTEye said:
Does it actually send a .3 milisecond pulse to the lights or not? I have HID headlights and I see this as wreaking HAVOC on those ballasts, as well as the electrical system in the car seeing that the inital current draw for an HID ballast is EXTREMELY high.
Yah, IF I did something like that it would be bad, but I don't. My circuit is totally benign to your car, your car won't even know it's there. It can send flashes to your head unit at about 1/2 second or so at best. But it does absolutely nothing to your car (unless you hook it up totally wrong).
EssTEye said:
If what I understand is true, and the unit is actually transparent to the car's headlight system, then let me know if you have one in stock, and I'll send the paypal post haste!
Yep totally transparent to the car's headlight system. It will NOT do anything or interfere with your headlights in any way. I do have some in stock, but as the post in the sticky says, I have a family thing going on tonight and tomorrow and won't be able to get one in the mail till Monday. Best I can do at this time. Sorry.
EssTEye said:
Thanks man... you are doing us responsible adults a GREAT service.
Hats off, dude...
Matt
'05 WRB STi
'01 GSXR 750 limited
Thanks! Just all of you "responsible adults" use it safely!
