ducatiboy said:
Pulp_Fiction, now that you figured out how to change the background screen, I think I want to switch out the drive and play with some stuff my self. If you don't mind, before getting into this, could I ask a few questions?
If I unlock the drive and just make changes, as soon as I put it back in the Z1 it will re-lock the drive.
If so I will need a drive that doesn't support locking? If so how do I know what does or does not support locking?
Do you have a drive you recommend? Brand/Model?
How did you connect your drive to your computer? Using one of these?
http://www.cablestogo.com/product.asp?c ... &sku=17705
Or did you use a USB interface?
What did you use to copy your partitions from one drive to the other? Ghost? Did you just create the partitions yourself and copy them partition by partition or did you do the whole drive at once and then go back in and change the sizes with partition magic or something?
Sorry for all the noob like questions, been too busy building circuits to keep up with all the threads here ;)
OK, noob status temp granted. :lol:
Yes it will relock it. Use MHDD to disable the security features on the drive before you put it back in.
They ALL support locking (I'm assuming this as it is part of the IEEE standard for ATA-5 and above). Very old drives do not but they are too small anyway. You could spend $$$$ on a 44 pin flash drive. This may not support locking. <--- Ignore this idea, just posted because it it possible, not prefered or tested and is def. more costly.
Any laptop IDE drive should work fine. If you can get automotve drive (like what comes with the Z1) it is advertised to be more shock resistant. I'm using a standard Hitachi laptop drive and it's been fine so far.
To unlock the drive you need to be able to connect it to the IDE channel directly if you use the service I did. The USB connector is helpful but not for unlocking, only for reading and writing later (hotswap ok with this).
Yes, Ghost. Created images off of original drive. Partition new drive with larger partitions. Use Ghost to restore original partions to new drive's partions, one at a time without letting Ghost resize.
I did not try to use a resizing tool like PM but now that we know more about the system (Windows CE automotive) I think that would work too.
That cable adapter you linked to should work fine.
Noob status revoked. Get back to your soldering iron now!!!
