Posted Jul 05, 2006 · 00:39 UTC#201
Have you guys ever tried to disable locking on the stock drive and putting it back in the Z1 to see what happens?
03Aviator said:Isn't pulp fiction successfully using another (larger) drive? I believe he had to manipulate the partitions to accomplish that didn't he?
Pulp_Fiction said:03Aviator said:Isn't pulp fiction successfully using another (larger) drive? I believe he had to manipulate the partitions to accomplish that didn't he?
No partition manipulation. Just creating standard WIN32 partitions and applying the ghost image. Only manipulation was disabling the drivelock.
ducatiboy said:Pulp_Fiction said:03Aviator said:Isn't pulp fiction successfully using another (larger) drive? I believe he had to manipulate the partitions to accomplish that didn't he?
Oh and if you do a ghost image of the whole drive from one to the other and let it resize the partitions, it will by default try to increase the LDATA partition, just drop down the size to the stock size and tell it to increase the MVS partition. It should work just ghosting the whole drive over, instead of partition by partition.
Pulp_Fiction said:Good to know. I didn't try doing that. Now lets wait until you confirm the larger drive works to put that in gold. :D
ducatiboy said:Well, bad news. Mine is not working well. Last night I booted it up a few times, saw that it worked, played a few songs last night, etc. Seemed like it was working.
But this morning I left the new drive in on the way to work, after 5 mintues or so, the screen just froze on whatever it was on. And the thing locked up. It still played what ever it was on (happened to be a cd-rom of mp3's this morning). The volume buttons worked. The volume buttons in me steering wheel worked. The eject button on the front panel worked, but the screen didn't change to the eject screen. Nothing else worked.
What was pretty funny, was on my way to work, at stop lights I would turn off the truck and turn it back on and let it reboot, and it kept putting my gps position back near my house. Then as I was driving, it would fight between putting me on 2 diverging roads and then gave up and said I was driving through a field and then it locked up.
When I got to work, in the parking lot, I restarted and it put my position there correctly, then it locked up eventually there as well.
So my drive experiment didn't go so well either.
It still works with the stock drive (I knew I should have brought that to work) :) I have the image and can try a different drive, I can use a 30 gig that I have as well. Who knows. I think I did it just like Pulp's one.
Cirbirus said:Well at least I know it's not that I'm grossly incompetent...
ducatiboy said:Cirbirus said:Well at least I know it's not that I'm grossly incompetent...
Are you sure that it would rule it out? :)
ducatiboy said:We already tried changing the password to something we knew and relocking the drive, when the drive was put back into the Z1, the hard drive password was changed to what the Z1 wanted and was re-locked. The master and user passwords are overwritten every time the drive is re-inserted (or maybe every time it's powered up).
And one guy has unlocked a drive and disabled unlocking (at least on the stock drive) and the new non-lockabe drives worked fine (at least in one Z1). So it's not a locking issue (at least as far as we know).
03Aviator said:I really think it's just some process or hard part you are using that is working Pulp...not the Z1. I think this is provable by trying your drive in another Z1. Maybe you could set up another drive just EXACTLY like yours and ship it to Ducatiboy and see how it works. If it works in yours, and not his...then we have problems.
