FINALLY THE MOMENT WE'VE BEEN WAITING FOR....THE Z2 BYPASS
By nissan07 · Apr 22, 2007in Hacks/Mods💬 49 posts👁️ 15,472 views
Page 2 of 2
Posted Apr 23, 2007 · 15:37 UTC#26
In my mind, this is still not a full bypass if it requires the absence of the VSS wire. The goal is normal function of the GPS and all the features that get locked to be available while moving. The true answer is still eluding us, but if you guys are happy with what you've got, have at it. At least people are trying!
Agreed. This seems more like a bandaid for a broken leg. Congrats on getting "something" to work, but I'll continue to be patient.
Posted Apr 23, 2007 · 16:57 UTC#27
Is there a certain type of switch, like as far as power handling wise i should use?
Posted Apr 23, 2007 · 18:18 UTC#28
Nope, just about anything would be fine. There is so little power here it's not funny. Any toggle switch radio shack sells would be fine. As a mater of fact, just about any toggle switch anyone ever sells would be fine. I would go for whatever is small, non-obtrusive and easy for you to get your hands on.
Just a SPST (single pole single throw) or a SPDT (single pole double throw) is fine, stay away from anything momentary or with a "center off" position.
Posted Apr 24, 2007 · 00:39 UTC#29
Here's my setup:
Toggle Switch to ground and e-brake
VSS wire cut (disconnected)
Reset all calibrations (saying sensor initializing...)
I followed the directions on what I'm supposed to do and the FIRST time it worked. After that it comes and goes whenever it feels like it. It works till 30 mph, 40 mph, and sometimes only at 10 mph.
I checked the wiring and made sure everything is connected properly but nothing is helping.
Any suggestions? Mahalo in advance for the replies.
Posted Apr 24, 2007 · 02:19 UTC#30
I had the same thing happen, but then reset the system as outlined in the first post, and all is well for now... we will see tomorrow. im thinking that after a few miles of driving, i.e. 50-100 miles it will show the warning and not work anymore
Posted Apr 24, 2007 · 02:37 UTC#31
Once you get it to work, it doesn't stop working through calibration. My tests and Nissan's tests have shown this. Coweyeboy, why don't you reset the unit as described and wait for the "learning...sensors initializing" to change to "learning..simple hybrid". At that point the GPS is calibrated and the switch should work.
It's crazy how variable people's results are. I'm not sure if it's voltage diff in vehicles (unlikely), accessories, software diff (doubtful), reset methods, when people try the switch, or what. Until people post EXACTLY what they have and do it may be hard to figure this all out. Well, for those of you who have it working, congrats and share your experiences on how and what you did. At least everyone could use a temp backdoor for now.
Posted Apr 24, 2007 · 05:09 UTC#32
I have the same problem as coweyeboy, and I followed the instruction to the T.
1. I grounded the parking brake.
2. I added a SPST switch between the grounded cable and the parking brake wire.
3. I disconnected my VSS, pink wire on harness.
4. And finally I reset everything I could find.
It works for a while and then the video goes away and I get the “Viewing while driving warning†and I lose picture from the DVD.
After reading the success others had I think I may be doing something wrong.
HELP!!!
Posted Apr 24, 2007 · 14:41 UTC#33
i have the same problem. I think that once the gps is calibrated it wont let the video show. even when you reset it, it only works for 20-30 miles, then once it has shown the warning it dosnt work again.
Posted Apr 24, 2007 · 15:23 UTC#34
Guys,
Timvan has his VSS on a toggle. He states when he toggles the VSS only for a split second the video will come back on for a while....I guess this tells the unit to start a recallibration process. I don't know why my video never goes out except that my VSS was never connected but it might be grounded (my friend installed it.)
Beachdoc
Posted Apr 24, 2007 · 16:01 UTC#35
why dont you find out if yor friend grounded it
Posted Apr 24, 2007 · 16:22 UTC#36
Beachdoc, I think it's unlikely that your VSS is grounded. I originally had a Z1 and the first time I installed it I did not connect the VSS and I remember getting the message for VSS not connected. I am going to do some driving today, and like I said yesterday, I believe that after driving some distance with the VSS unhooked the unit will realize I disconnected it and give me the warning. After that I have faith this bypass will work.
Posted Apr 24, 2007 · 16:46 UTC#37
I asked and he just cut the end off the wire. Someone might try unhooking the negative battery lead for a minute or two then starting over in case something is remaining in flashmem from power even with the vehicle off. Just a thought.
Posted Apr 24, 2007 · 19:31 UTC#38
I did finally get the vss not connected message, and I didn't have to drive far after the reset to get it. I mentioned in the other thread my newest find, which involved waiting until my calibration went to simple hybrid to flip the switch. It is working better than before, over 10 miles and still no error.
Posted Apr 24, 2007 · 19:40 UTC#39
YzRacer,
I think you've got it. There is a "key" getting into this backdoor. Folks at Pioneer are prob either laughing or rewriting the software as we speak. :)
Beachdoc
Posted Apr 25, 2007 · 01:47 UTC#40
mine stoped working. it took about 20 miles or so, but its not working:-(
any ideas?
Posted Apr 25, 2007 · 02:23 UTC#41
I wonder what YzRacer and others have found now. Are they still having problems? DarkMcNight did you try to reset with e-brake on then turn off ignition for 1-2 min. Restart with it off, drive while it states "initializing sensors" and flip the e-brake on until it changes to "initializing...simple hybrid". Stop turn off the vehicle restart with the e-brake off and drive for 10+ miles with e-brake off and let the GPS callibrate. (For some reason, these steps tell the unit not to turn off the video after the GPS gets callibrated). Once, the NAV seems accurate, turn off the vehicle. Restart with e-brake off then turn it on after like 25mph or so and drive for 10-20 miles and see what happens. That's my only suggestion until we investigate the HDD images.
Posted May 14, 2007 · 17:51 UTC#42
18 year installer here, Pioneer dealer as well. I have confirmed with Pioneer Tech as of last week, that no VSS connection will cause the 3D calibration NOT to work. Once the VSS is connected, it will restart calibration, but if not, the right/left turn gyros will never calibrate.
Will post more info as I glean it, I have many reps and insiders looking into this.
I currently have a Z2 in my demo vehicle, but almost wish I got my Z1 back from the customer I sold it too....
Posted May 14, 2007 · 21:26 UTC#43
FYI, Its pretty common knowledge that not connecting the VSS will prevent the 3D hybrid from kicking in, all Pioneer navs have been like that. If you look at the hardware info screen, the left, right, and distance still calibrate, so the gyros are kicking in which is definitely one of the factors contributing to the lockout
Posted May 15, 2007 · 02:04 UTC#44
Sorry, you are right, I phrased that wrong, it will not 3D Hybrid, but instead will eventually switch to Simple Hybrid.
Posted May 15, 2007 · 04:01 UTC#45
Since I had my unit professionally installed instead of doing myself, how do I find the wire to connect to the VSS? Should I make the dealer do it? They told me they never connect it, and didn't know where to find the speed sensor wire in my car. '06 Toyota Highlander Hybrid.
Thanks.
Posted May 15, 2007 · 12:41 UTC#46
Beachdoc: Can't say I would call that a professional installer... It's either an incredibly lazy installer or a poorly equipped novice installer. If they do installations they should know this stuff. Get the original installer to fix it or get them to pay someone who can. In my book that's a half arse installation... My guess is a dealer wouldn't touch it since it's aftermarket and not their work / product. That's at least my experience with Caddy dealers...
Posted May 15, 2007 · 14:07 UTC#47
Sorry, I meant it's an electronic shop, not the Toyota dealer. They didn't know where to find it. I guess they should have access to all vehicle info if they are an authorized Pioneer seller and installer I would think.
Posted May 15, 2007 · 19:45 UTC#49
Thanks for the info rjedlich!
Page 2 of 2
