CNDV-70MTP
By LUNARFX · Jun 28, 2007in General💬 65 posts👁️ 17,922 views
Page 3 of 3
Posted Aug 12, 2007 · 19:20 UTC#51
So has anyone successfully added their own backgrounds and/or Boot screen on the 70 Nav data? :?
Posted Aug 12, 2007 · 19:41 UTC#52
Just a FYI.. IsoBuster shows the whole file structure, including PIM2DIN... The good-ole boys at Pioneer added bad data to mess us up..
Posted Aug 12, 2007 · 23:09 UTC#53
I tried to modify the BGOpen & BGOpen2. I get the "Insert app.....". Using ISOBuster, I copied the whole DVD to my local drive, modded the files then burn it on a DL DVD with Nero.. No Luck.
Why can't hacking be easy (because it wouldn't be fun!!!!) :roll:
Posted Aug 13, 2007 · 03:04 UTC#54
YUP!!!! PERFECT!!!
Posted Aug 13, 2007 · 14:31 UTC#55
When I get a chance, I will look at what Pioneer was screwing with on the DVD's allocation table. Sometimes, the easiest things to fix, are the hardest thing to find! :lol:
Posted Aug 16, 2007 · 15:07 UTC#56
i went to isohunt.com and search for "CNDV-70MTP"...it returns nothing...can someone post a link?
Posted Aug 16, 2007 · 15:26 UTC#57
No one (that I know of) has been seeding the ISOs. Maybe because it's easier to just buy them off MR XM then downloading 8 - 16 GBs, burning on DL DVDs to find that they are bad or corrupted (I know you can check the ChkSum but..). You could buy a DVD and seed it.... :wink:
That's my 2 cents, and I don't give refunds!!
Meanwhile... Back at the Hall of Justice...........
Posted Aug 20, 2007 · 16:22 UTC#59
I did a bad thing, though, now that I think about it. I wanted to preserve my boot up screen and also add some custom backgrounds (my previous attempt failed because I didn't use all uppercase letters in the filename AND extensions). So, my first stop was my computer. I didn't need anything special to read the contents of the disc, so I copied the files to my hard drive, inserted my own files in place of BGOPEN2.JPG and in the BG2DIN (you know what I mean) directory, and then just burned a copy of the files to a DVD+R DL disc, named the same as the original. Then I used my copy to perform the upgrade. Good thing it worked. I probably should have upgraded from the original and then inserted my copy just to ensure no mishaps from a corrupted file created during the copy/burn process. But everything seems to be ok.
For all of you that are asking, YES I was able to add my own custom backgrounds. Using Win XP Pro, I copied the DVD to my hard drive, inserted my desired files, and burned a dual layer DVD using Roxio 6 and the "create ISO" setting.
Posted Aug 20, 2007 · 16:28 UTC#60
That's strange?? Are you using the CNDV-70 DVDs?? The DVD shows 0kb files for some bootup images. It also ilooks like it's missing files if you look at it in MS Explorer. You need to use a ISO scanner like ISO Buster to see the missing files?
Posted Aug 21, 2007 · 02:09 UTC#61
I'm using the CNDV-70MT discs. With the purchased disc in my DVD-ROM, I don't see that any of the image files are 0 KB in size. BGOPEN2.JPG is 115 KB and is dated 2/28/2007. The PIM2DIN directory is present as well, with a date of 5/22/2007.
As I said before, I simply copied the purchased disc to my hard drive, inserted my own files, and burned a copy to a Verbatim DVD+R DL. I'm using a Plextor burner, and the free version of Roxio 6 that came w/ the burner.
Posted Aug 21, 2007 · 10:38 UTC#62
I never thought about it, but I opened the ISO with WinRAR and the directory structure and files look fine, where as with UltraISO I get the 0k files on the same exact ISO.
When I get home from work tonight I will try injecting a few BG's with WinRAR and report back.
Posted Aug 23, 2007 · 06:44 UTC#63
any news PaisanNYC ? ... pm me
Posted Aug 28, 2007 · 22:30 UTC#64
anyone having trouble burning the torrent? it keeps failing and also asking me what data type.
grrrr
Posted Aug 30, 2007 · 23:08 UTC#65
stathound,
I have been a member of this forum for just a few months now, but I've been reading the posts for quite a long time. I just wanted to say "thanks" to all who contribute here. After using this link to download the East file, then unraring it, I was able to burn to a DL disk using alcohol 120. (Nero didn't work) The upgrade works perfectly.
Fish
Page 3 of 3
