AVIC-Z2 Pre/Post-June Bypass Files
By Hyperite · Jul 22, 2007in Hacks/Mods💬 951 posts👁️ 310,660 views
Page 22 of 39
Posted Oct 18, 2007 · 16:16 UTC#526
i have z2 navigation in my car.for bypass what i have to do? i need to go to my installer for 2 wire bypass? or just i have to burn[z2 bypass]? but i tried for burn it i couldn"t. i need nero program? culd you explain me one by one.thanks for you advice.
Posted Oct 18, 2007 · 16:48 UTC#527
You definitely need to do the 2-wire bypass. Depending on what month yours was made, you will also need to burn the CD
Posted Oct 19, 2007 · 00:36 UTC#528
had my installer do the two wire bypass...and did method 2 it is still giving me the message to not use it while driving
edit i had a dumb moment....
i had him place the wire 2 in the wrong place...whooopsss but hes fixing tomorrow! :-)
Posted Oct 19, 2007 · 17:11 UTC#529
i have navigation z2 i installed about 3 -4 weeks ago. i"d like to have dvd when i"m driving. i needimage file for by pass. i burn z2 bypass on the website but after put in my navigation seems inerted cd-rom. the same after put map.what"s wrong did i? i have to burn it with nero program? i tried more then 15 times but i couldn"t get good result? some body explain me exaclty what i have to doing for this prublems. i need to go to my installer for bypass? or just load and burn image file[bypass z2] is ok? i realy need your help.thanks for your advice.
Posted Oct 19, 2007 · 17:25 UTC#530
Yes, go to your installer
Posted Oct 21, 2007 · 12:02 UTC#531
I am still a little confused, I am purchasing an Z 2, what is better to get a unit pre-made before June 07 or a unit made in June 07 and later ?? And what whould the difference be??? The store has a unit manfuactored FEb 07 and June 07 and they are getting a new shippment in next week. Could anyone help me out on this
Posted Oct 21, 2007 · 15:53 UTC#532
Later is better, as you probably won't need to run the software update.
Posted Oct 21, 2007 · 16:46 UTC#533
Can I still do the bypass you posted on the later model?
Posted Oct 21, 2007 · 17:23 UTC#534
Yes, and you probably won't need to run the software update...
Posted Oct 21, 2007 · 19:09 UTC#535
So all I have to do is method 2 of your early post for the later models?
Posted Oct 21, 2007 · 19:16 UTC#536
Later models only require doing the 2-wire bypass
Posted Oct 21, 2007 · 19:27 UTC#537
Thanks that help tremendously
Posted Oct 21, 2007 · 21:24 UTC#538
How the hell did you not get that from what I said...
Posted Oct 21, 2007 · 23:32 UTC#539
I read "probably will not need update" and was not sure, Sorry but thanks for the reply.
Posted Oct 22, 2007 · 13:53 UTC#540
Hey,
I used the second method on for the bypass. When i put the cd into my Z2 the screen said that it had already been updated. But when I tried to use my nav functions without the parking break down i was denied. Any advice?
Posted Oct 22, 2007 · 15:46 UTC#541
Hey,
Hopefull Hyperite should be abel to answer this. He knows this unit inside out. The only thing I have read was to check and make sure the 2 wire bypass is correct. I have not done mine yet, I am scheduled for Nov. 2 install. If you find out please advise.
Good Luck
Posted Oct 22, 2007 · 17:04 UTC#542
Hey,
Good Luck
Yep, sounds like the 2-wire bypass was not done.
Posted Oct 22, 2007 · 18:52 UTC#543
Is it okay to ground both of the wires together or should I use a separate ground for each wire. Also does my speed sensor wire have to be connected or is it okay to leave it unconnected on my Z2?
I am tring to make sure i get this right this time because i had a z1 a week ago. I tried the z1 bypass and it worked but i ended up having to by a new unit because a weird noise was coming through my unit. If anyone wants to buy it I will sell it for a little of nothing. Everything works well just getting a weird noise when connected through the amp.
Posted Oct 22, 2007 · 18:58 UTC#544
Doesn't matter if you ground them together or seperately. I would connect the VSS if I were you...Its simple enough to do and will improve your accuracy
Posted Oct 22, 2007 · 19:37 UTC#545
I have a chrysler 300 C. Does anyone know where the speed sensor is on this car. Or possible places to to connect it to?
Posted Oct 23, 2007 · 03:23 UTC#546
check you wiring
Posted Oct 23, 2007 · 03:50 UTC#547
I have completed a new installation and the 2-wire bypass. Almost everything is working.
I can play DVD and operate the Nav while moving. However, there are bluetooth functions locked out when I am moving.
Is there anything I can do about this?
Greg
Posted Oct 23, 2007 · 05:07 UTC#548
Which functions, and is your phone connected?
They're enabled when at a stop, but gray out when you move?
Posted Oct 23, 2007 · 17:22 UTC#549
I spoke too fast...
I got back in the car with a DVD and a pad of paper prepared to take detailed notes. It seems that the entire 2-wire hack is no longer working. I just first noticed it on my bluetooth.
I am pretty sure the bypass was working right after I did the 2-wire hack. I will go back and make sure that the 2-wires are all still attached and grounded correctly. I am grounding the "extra wire" wire and the brake wire per the sticky and the link in the sticky
Also, I get a hand brake warning at boot.
Greg
(corrected my mis-statement about grounding the speed wire)
Posted Oct 23, 2007 · 17:25 UTC#550
Don't ground the speed wire. Ground the parking brake and the extra wire you stuck in the "bypass" hole
I spoke too fast...
I am pretty sure the bypass was working right after I did the 2-wire hack. I will go back and make sure that the 2-wires are all still attached and grounded correctly. I am grounding the speed wire and the brake wire per the sticky and the link in the sticky
Greg
Page 22 of 39
