AVIC-Z2 Pre/Post-June Bypass Files
By Hyperite · Jul 22, 2007in Hacks/Mods💬 951 posts👁️ 310,660 views
Page 23 of 39
Posted Oct 23, 2007 · 17:29 UTC#551
Don't ground the speed wire. Ground the parking brake and the extra wire you stuck in the "bypass" hole
Sorry, I mis-wrote. Yes the extra wire and the brake wire.
[THIS ADDED LATER]
As suspected, when I was reinstalling the dash, I pulled out the "extra" wire and the system was not bypassed at all. I had re-used the "Mute" wire and it has a little connector that I used to extend the wire. It simple pulled out. It is now soldered.
I jumped the gun with my question and apologize for cluttering up this thread.
Greg
Posted Oct 29, 2007 · 22:26 UTC#552
Never mind
Posted Oct 30, 2007 · 05:28 UTC#553
Hey Hyp! Newbie here. Name's Jason. Thanks for your efforts here on the bypass and to those who helped. The link to the 2 wire bypass, is it the same for the Z2? cause it says Z1 in the instructions. My brake was already grounded by the installers so now which wire do I terminate to ground on the Z2 harness? I downloaded the bypass ISO and will install tomorrow. Your help will be greatly appreciated and a donation will be sent your way.
Posted Oct 30, 2007 · 06:13 UTC#554
Yes, its the same for the Z2. You will need to move the mute wire to the new spot shown in the pictures and ground that wire
Posted Oct 30, 2007 · 14:01 UTC#555
Thank you whtcrxghst!
Posted Oct 30, 2007 · 22:20 UTC#556
So, you quoted the whole first post, which says in big bold letters...but... eh forget it. I hate this thread too.
Posted Oct 30, 2007 · 22:56 UTC#557
Sorry man! I know, I feel like a semi-tard for doing that! Anyway, any thoughts on my post about BT or do you hate those too? lol!
http://avic411.com/forum/viewtopic.php?t=10996
Posted Oct 31, 2007 · 00:00 UTC#558
Hah, I never check the general forum, just this one. I replied.
PS- I hate cross posting :lol:
Posted Oct 31, 2007 · 00:03 UTC#559
use NERO http://www.nero.com
and you may wan't to try this update
you dont need the bypass files there included in this 1 also
http://www.pioneerelectronics.com/pna/v ... 48,00.html
If you use the above link...it instructs you to just download two files...AvicZ1HD1 folder and the basefile.dat...is this the same in the megaupload link? Just curious....Thanks in advance.
Posted Oct 31, 2007 · 01:41 UTC#560
No, the megaupload link is only to bypass your deck. The pioneer link you listed is to fix the heat freezing issue, but by coincidence :wink: also makes your deck bypassable
Posted Nov 02, 2007 · 20:33 UTC#561
Just installed the Z 2 in my F 150 07 King Ranch. I have the factory amp. The by-pass works. When I first turn on my truck I get a quick pop my my sub-amp for about 1 sec. Is this norm or is there something I have to do. I used the harness from CrutchField for the the Z2 to hook up the sub amp.
Posted Nov 02, 2007 · 21:10 UTC#562
Are you talking about after market subs and amp? If it was the factory amp, you would get it through all speakers.
did you run your remote(turn-on) to the adapter, or the Avic?
Posted Nov 03, 2007 · 12:15 UTC#563
I ran it from the AVIC. I have the steering wheel controls also. It only happens for sec. when I start the truck up. Is that correct? How should it be done? It is a factory Sub. The pop comes from the Sub not all the speakers.
quote="dawgbone"]
Posted Nov 04, 2007 · 00:04 UTC#564
Hello to all, I just had my z2 installed in my Charger SRT8. the shop that did it, did a great job but did not want to do the whole bypass for me. no biggie, still happy with the work. they did hook up the brake wire to a ground but that was the only wire. now my question is, i know if you are not using the mute wire, to move it and use that as a ground. what if you are using that wire because of the blue tooth. what other wire or how should i ground out the second wire location. thank you.
Posted Nov 04, 2007 · 00:28 UTC#565
See if there are other wires back there that you are not using. Or you can rob one from another Pioneer harness if you have access to one.
P.S. If you are using the Pioneer bluetooth, you don't use the mute wire.
Posted Nov 04, 2007 · 00:49 UTC#566
thank u, i just read on how to use the wires. i am going down to try the bypass. i will let u know how it works. i have the burned cd to load.
Posted Nov 04, 2007 · 02:05 UTC#567
well i just did the 2-wire bypass and loaded in the update. first it said unreadable cd, then it said update already done. so i put in a movie and went for a drive and everything worked. i did not have to load the update or hit the reset button, just the 2-wire bypass. i am guessing because my unit is new and Pioneer already did the update. thanks to all..
Posted Nov 05, 2007 · 21:14 UTC#568
can anybody tell me if a june 07 Z2 needs the update before the 2 wire bypass will work?
Posted Nov 05, 2007 · 21:49 UTC#569
Impossible to tell, the switch was made sometime in June. Just burn the patch just in case. If you stick it in and it says 'already updated,' no harm done. If it updates, then you are good to go
Posted Nov 06, 2007 · 22:08 UTC#570
Hi Guys I'm planning on getting my new Z2 within a week or two. WHat do I need to look for for the shop to do the bypass for me?
1. Tell then I need a Z2 made after Mid. June?
2. What is the 2 wire bypass and how is it done? So I can tell them what needs to be done?
Thanks so much for any info.
P.S. Can I just the Video on my Ipod video on the Z2? If so how would I do it and what do I need to make it work?
Thanks.
Posted Nov 07, 2007 · 01:16 UTC#571
1. Or just download the patch that makes all Z2s bypassable. Can be found here: http://www.avic411.com/forum/viewtopic. ... 83&start=0
2. Follow these instructions even though it says Z1...Same for both
http://www.sminntech.com/z1flash.html#newbypass
Thanks.
Posted Nov 07, 2007 · 16:26 UTC#572
I think I have read the majority of the threads regarding this issue, but im still having probs. I downloaded the "Alcohol 120" program as well as the ISO image. When I try to burn it to a disk, it goes all the way to 99% then takes a crap and states it cant finish there was an error. I have already done the 2 wire bypass and am good to go, I just need to figure out how to get this image on a disk. I have a AV\IC-Z2.
Any suggestions?
Posted Nov 07, 2007 · 18:14 UTC#573
Try a different brand of CDRs
Posted Nov 07, 2007 · 18:32 UTC#574
Does the bypass cause you to loose the speed pulse ?
Posted Nov 07, 2007 · 19:18 UTC#575
No. The bypass doesn't effect anything except the ability to use functions while in motion
Page 23 of 39
