AVIC-Z2 Pre/Post-June Bypass Files
By Hyperite · Jul 22, 2007in Hacks/Mods💬 951 posts👁️ 310,660 views
Page 33 of 39
Posted Jun 07, 2008 · 22:29 UTC#801
Do the 2-wire bypass
http://www.sminntech.com/z1flash.html#newbypass
OK, My Avic Z2 was made on july 2007, so i went to circuit city to get it installed and bypassed, but the guy told me that he couldn't bypass it because of the date it was done and there was no way to do it unless i go back to the Z1, and why would i want to do that? so im here out of luck until i found this website. great info. So i downloaded the update since it said post june, but when i inserted it in a screen popped up and indicated that there was no need to update.
so what should i do now?
anyone out there to help. i looked through the posts, but none that can help me out and frustration kicked in.
thanks!
Posted Jun 08, 2008 · 20:37 UTC#802
I searched but I can't search this specific thread with this forum software.
I want to verify that the iso images does 2 things:
1. 2-wire bypass (I know that it does that)
2. Freeze update (or do I have to do that separately)
If you could update the 1st post in this thread to clarify that is does specifically remedy the freeze as well that would be great.
Posted Jun 11, 2008 · 23:08 UTC#803
I tried the CD download and it says that i need the updated version. i cant find any updated version that is the only one that i have found and i tried many different sites and it says the saything
please help
Posted Jun 23, 2008 · 16:55 UTC#804
I have a brand new Z2 unit and when i try to apply the softwar it comes up and says this is an old version and i will need a new version. Is there a newer version?
Posted Jun 23, 2008 · 23:03 UTC#805
no
Posted Jun 25, 2008 · 19:47 UTC#806
does it HAVE to be the mute wire thats moved? or can another wire be substituted?
Posted Jun 25, 2008 · 19:56 UTC#807
You can use another unused wire as long as the correct pin gets grounded.
Posted Jun 30, 2008 · 01:06 UTC#809
I have a Z1 with the Z3 drive from Garrett Tommey. Is the bypass at the link below still the correct one for me?
Posted Jul 08, 2008 · 01:54 UTC#810
Hi all,
Just registered. I bought the Z2 a few days ago. I was wondering if someone can confirm that Hyperite's "Method 2" from original post will still work? If so, looks like all I have to do is download the ISO file, correct?
Thanks,
Paul
Posted Jul 08, 2008 · 02:12 UTC#811
yes
Posted Jul 08, 2008 · 02:13 UTC#812
Hi all,
Thanks,
Paul
yes...and you might not even need it. install and do the 2-wire bypass and see if it works. if not, grab the iso.
Posted Jul 08, 2008 · 02:23 UTC#813
Hey Hyper,
First off, thanks for creating this thread and for your hard work. Best Buy actually installed this for me. So I'd rather not take the dash apart as I am not well-schooled in installation. So the ISO appears to be the way to go for me, right?
Also...I have Sonic CD burner on my PC but I believe that is Windows-based. So I guess I should download another burner program?
Thanks again!
Posted Jul 08, 2008 · 03:45 UTC#814
Hey Hyper,
Thanks again!
Well, if you didn't specifically have them do the 2-wire bypass, the ISO won't help you.
Posted Jul 08, 2008 · 04:14 UTC#815
Hey Hyper,
Thanks again!
OK. So if i go back to Best Buy...will they know exactly what a 2-wire bypass is? Will I have to show them those specific directions? The DVD was what really made me want this unit.
Thanks again.
Posted Jul 08, 2008 · 12:27 UTC#816
Thanks again.
No, they won't know what it is, and even if you tell them...they SHOULD refuse to do it, since it violates corporate policy. You gotta do this one yourself.
Posted Jul 08, 2008 · 21:49 UTC#817
Looks like I'm screwed. Thanks for your help though.
Posted Jul 09, 2008 · 00:45 UTC#818
You're not screwed, you're just overwhelmed. Take some time and read through the threads here. Also try to find a forum for your car specific, or get install documents from Crutchfield.
Late model cars are getting easier and easier to modify...just take your time 8)
I've got an F-150 with a Z1, XM tuner, back up cam, 2 10's, 3 amps and components in all 4 doors...this was my first car install and I did it with the help of the folks here and on the F150 owners forum.
Remember Happy Gilmore---> "You can do eeit" :)
Posted Jul 09, 2008 · 04:31 UTC#819
Thanks Big. I will give it a try and a manual from Crutchfield is on its way!
I downloaded the update but because I just bought the Z2 I know Hyperite said I may not need it. It wouldn't affect the unit if I tried to download it anyway, will it?
I'd rather make sure the update is straightened away before doing the 2-wire bypass.
Posted Jul 10, 2008 · 00:53 UTC#820
If I'm not mistaken, when you put the CD in and if the deck has already been updated, then you'll get a message telling you so. Shouldn't cause any harm. I'm about 95% positive on that one, but someone with a higher post count may want to verify that one :wink:
Posted Jul 10, 2008 · 02:11 UTC#821
I did the mod a few days ago and it worked Fine but now it gets stuck on the Pioneer loading screen when i start up the car. i reset it a few times and it came back, but now its stuck again.anyone have an idea on how to fix this?
Posted Jul 12, 2008 · 19:23 UTC#822
I haven't installed my Z2 upgraded to Z3 so it's just hooked up to a battery in my house... however, simply grounding the park brake wire seems to work as the bypass.
Since it seems to work, does the Z3 need a 2-wire bypass? Is the only reason it works is because I don't have the VSS hooked up? Or could it be the Z3 only needs a 1-wire bypass?
Unfortunately, I didn't really play around with it much with the old Z2 software so don't know if it's acting differently with the Z3 software or not.
Posted Jul 12, 2008 · 21:49 UTC#823
Uhh... that's the proper function... it's SUPPOSED to play movies when the parking brake is set and you're standing still. Nice job, you're using it as instructed! :)
Posted Jul 12, 2008 · 22:00 UTC#824
No, I mean it never tells me my parking brake is hooked up incorrectly or complains about anything. It doesn't complain even if I kill 12V constant power to the whole thing. From my understanding, the 2nd wire needs to be hooked up because hooking up just the P-brake wire alone will cause it to complain about the P-brake wire being hooked up incorrectly if it's powered up with ONLY the P-brake wire grounded. However, mine w/Z3 image doesn't do that.
Posted Jul 12, 2008 · 22:34 UTC#825
Yes, I understood what you said.... why would it tell you your brake is hooked up incorrectly if it's hooked up correctly?
Page 33 of 39
