AVIC-Z2 Pre/Post-June Bypass Files
By Hyperite · Jul 22, 2007in Hacks/Mods💬 951 posts👁️ 310,660 views
Page 34 of 39
Posted Jul 13, 2008 · 06:55 UTC#826
No, I mean it never tells me my parking brake is hooked up incorrectly or complains about anything. It doesn't complain even if I kill 12V constant power to the whole thing. From my understanding, the 2nd wire needs to be hooked up because hooking up just the P-brake wire alone will cause it to complain about the P-brake wire being hooked up incorrectly if it's powered up with ONLY the P-brake wire grounded. However, mine w/Z3 image doesn't do that.
Yes, I understood what you said.... why would it tell you your brake is hooked up incorrectly if it's hooked up correctly?
The way I thought it's supposed to work is it senses a change in state from non-grounded to grounded, and if it detects that wire is constantly grounded, then it will alert you the p-brake wire isn't hooked up correctly like all the other AVICs.
If there was never any problem having ONLY the p-brake wire constantly grounded, then what purpose is there to ground that 2nd wire?
What I am saying is after the Z3 upgrade it doesn't seem to care whether that 2nd wire is grounded or not.
Posted Jul 13, 2008 · 15:14 UTC#827
Right, but you're not moving if you're bench testing. It only claims improper hookup if it detects movement (via gps or accelerometer) while the brake is grounded. Standing still with the parking brake set, you're allowed to watch movies all day. The second wire bypasses the motion lockout.
Posted Jul 13, 2008 · 18:38 UTC#828
Got it, thanks. That's what I trying to find out - whether it monitors anything other than the p-brake wire like VSS, GPS, etc. Sorry I didn't make that clear!
Posted Jul 22, 2008 · 18:37 UTC#829
Hello i did the update and it works fine but the other day i tried to watch tv in the back seat and there was no video it shows the menu options and the time but no video on the back screens it shows video on the front screen did i do something wrong
Posted Jul 23, 2008 · 20:02 UTC#830
Hey greenman did u find out how to fix the back screens to get them working i can figure it does anyone know how to fix it im have the same problem as greenman did the the update file that i use turn the back screens off so they wont play video please help
Posted Jul 23, 2008 · 20:11 UTC#831
its probably a stupid question but both of you put the yellow rca from the tv's and used a y-adaptor to attach it to video in....and then you changed the settings in the unit, right?
Posted Jul 23, 2008 · 21:37 UTC#832
yes i did that but it shows navigation on the back screens and i have the avicz2 set to mirror front screen to back screens it show ervything on the back screens except for the video it also shows the clock in the upper right hander corner and when i change the tv chanel it also shows the chanel on the rear screans but still no video
Posted Jul 23, 2008 · 22:27 UTC#833
is there a setting for video? and im sorry i meant to write plug it into video out
Posted Jul 23, 2008 · 22:52 UTC#834
no not that i know of it used to just send it all to the back screens but after i did the video bypass the back screens dont play video they show everything else but video
Posted Jul 24, 2008 · 01:11 UTC#835
so i just purchased a Avic z2 off ebay and was attempting to bypass it...
I read the post made on the page and grounded the yellow wire with the black stripe and the light green wire first... then i put in the CD with the image, hit map and the cd said that the upgrade was already installed so i just hit reset and it all worked fine for about 10 minutes, the movie that was playing stopped and a message popped up saying something along the lines of "you can not watch videos while the car is in moving" and "the parking lead wire seems to be hooked up incorrectly"... i dont understand what is going wrong... can anybody help me!?!?
Posted Jul 24, 2008 · 02:46 UTC#836
did u take the black and yellow wire of out the harness and relocate it in the empty slot in the other connector? cuz thats half the bypass and you made no mention of that
Posted Jul 24, 2008 · 15:33 UTC#837
Yes i did now here is somethink weird when i put a dvd in it plays the dvd on the back screens like it soposed to but why is my tv tuner not get broadcasted to the back screens
Posted Jul 24, 2008 · 22:27 UTC#838
Does METHOD 2 work on the z3?... or should i say Z1 with a upgraded Z3 Harddrive?
Posted Jul 24, 2008 · 22:30 UTC#839
for the z1 all you have to do is the 2 wire bypass. its just z1's and early z2's that need the extra work done.
Posted Jul 24, 2008 · 23:57 UTC#840
for the z3 all you have to do is the 2 wire bypass. its just non-bluetooth-updated z1's and early z2's that need the extra work done.
fixed.
Posted Jul 25, 2008 · 02:27 UTC#841
fixed.
the BT update for the z1 is the extra work i was referring to.
Posted Jul 25, 2008 · 03:17 UTC#842
Right, but some Z1s shipped with the bluetooth update.
Posted Jul 25, 2008 · 03:19 UTC#843
o, arite i didnt know that about the 1's. i stand corrected.
Posted Jul 26, 2008 · 19:35 UTC#844
my friend hooked it up so he's the one that knows all about the wires and crap so i just need to know what to tell him so i can fix it... the two wires that we connected to the ground were a yellow wire with a black stripe running down the middle and a light green wire... what else do i have to tell him to do?
Posted Jul 27, 2008 · 07:27 UTC#845
did he relocate the black n yellow wire to the empty slot in the other connector?
Posted Jul 27, 2008 · 18:39 UTC#846
did he relocate the black n yellow wire to the empty slot above its original slot?
all he did was connect the light green and yellow wire with the black stripe to the ground wire... when you talk about him relocating the black n yellow wire into an empty slot do you mean the yellow wire with the black stripe or two different wires that are in the wire harness? if you can just simply give me instructions on what i can tell him i would appreciate it because i know nothing when it comes to hookin up car audio
Posted Jul 27, 2008 · 19:39 UTC#847
take the black and yellow wire and unlock/pull it out of the harness. relocate it in the end slot on the other connector. THEN ground the black/yellow and green wires. otherwise itll lock you out as soon as u start moving
Posted Aug 10, 2008 · 23:34 UTC#848
so i did what you told me, i took out the yellow and black wires from the harness and moved them into an empty slot and then i have the light green and yellow wire with a black stripe grounded to the black ground wire and everytime i turn on my car the first thing that comes up is still there is improper connection of the parking brake lead and it locks me out of shit when im moving... i cant figure out what to do... i even tried resetting it once... please help!!!
Posted Aug 11, 2008 · 00:27 UTC#849
nonononono......the yellow wire and the black wire are not to be touched!! thats your constant and ground wires, put them back where they belong. you take the yellow wire with the black stripe and move it TO THE EMPTY SLOT IN THE OTHER CONNECTOR, not just any empty slot. check the manual. its the "cell phone mute wire"
Posted Aug 14, 2008 · 20:23 UTC#850
Hi all,
I'm getting ready to install a Z3 into my 06 Mustang this weekend.
I've located the light green parking brake wire, as well as moved the yellow wire, with two black stripes, marked MUTE (CRW1358-A) into the bottom right location on the connector 2 socket. Now my question is, and it may be really stupid, but I have absolutely no knowledge of anything electrical:
How do you attach these wires to ground them? I understand you attach them to an unpainted piece of metal on your car, but how? The black grounding wire looks like it could be attached under a screw because of the washer-like end on it, but what about the other two? How do they get attached in a way that secures them? Can they all be connected together into a happy grounding wire family, or should they be separate from each other?
Any input is appreciated!
Thanks,
Tom
Page 34 of 39
