AF Magnum,
I'm not sure I understand. Now you are saying that this file upload is
"Actually, the files I linked to IS the image of the Pioneer update disks. Method 2, "CDROM ISO" is the actual upgrade disks from Pioneer. If applied to a pre-june Z2, it makes it bypassable. It's the same disks you use to upgrade your Z1 to a Z2 but will not work without an unlock code.
only for the CD ROM image that you use to make a Z1 into a Z2, but that you still need a code on Pioneers website for this to work."
Thats not what your post says below. A lot of us were led to beleive that you uploaded an image of a bypassable Z2 that we can load onto our Z1's and have it update the Z1 into a Z2 and have updated maps and still use our two wire bypass.
What exactly are you uploading?
Posted: Fri Aug 10, 2007 5:17 pm Post subject:
Ok, I installed the Z2 image on my Z1 with great success. Everything is bypassed using the 2-wire bypass. So far I have 400+ miles from a trip I took yesterday and everything is still bypassed.
When I installed the drive, it took a few moments for "system updates" then everything came online. The version now reads 2.000 and I verified the maps were updated.
By the end of today, I will have over 600 miles with the new image. Assuming everything stays bypassed, I will do a level-4 reset, remove the drive and create a Bypassed Z2 image.
Right now, the image was 9.4 Gbs before I inserted back into my AVIC. I still don't have a good solution on how to share the image. Distributing DVDs is the last thing I want to do. I can WinRar the file into 1 Gb portions if needed.
