Hey guys, I'm Adam Outler. I'm new here. I'm pretty well known on the XDA-Developers forums and I'm interested in working on this platform. I own two AVIC-8100NEX units. One is on my bench and the other is in my car. I posted quite a bit of information the other day before I found this post.
I'm very saddened by the lack of communication on this forum. People are making progress independently without sharing any changes or methodologies. I'd like to (without overstepping my bounds) encourage people to post cool new hacking techniques in the relevant forums. You see, without sharing the how of your work, noone can learn anything. If noone learns anything, noone can reproduce your work. If noone can reproduce your work, then the product suffers from lack of development. If the product suffers, you suffer.
So, if I am bringing one bit of the XDA-Developers spirit with me, that's the GPL. Not the GPL itself, but the spirit of the GPL.
Remember that anything you do to the firmware on this unit is not your own work. There were developers at Pioneer who came before you and did the work. You're undoing their work so you can add a few lines of code. You owe it to the developers and the community to share it.
For those curious or with development experience, I just created a shell script that opens up the PRG file, waits for modifications and then merges it back together with the correct CRC32 checks and sizes. It is located here: https://gist.github.com/bassrock/8053d22493785b92958f
The only issue is it uses ext4fuse which is read-only, so just change that to whatever ext4 mounting program you have that allows write access and then code away.
I updated the gist to instead use http://www.paragon-software.com/home/extfs-mac/ which has write support.
I've heavily modified your work to operate on Linux. I've also added a license header which is desperately needed on these forums. I want to ensure anything based on your/my work is propagated and anyone who uses it is forced to "pay it forward".
I made the assumption that the headers on the 5000 are the same as the 5100 and therefore the 8100 as well, because the firmware is apparently compatible as per post #1 in this thread, and the fact that the 5100NEX firware is used on the 8100. Is this correct? If so, then this should work properly.
Workflow:
- On a Linux computer, copy this to a file called AVIC.sh
- download a firmware update
- run
"AVIC.sh /path_to/MY_FW-update.zip".
If you're not using AVIC5000, you can add in the Model and Version parameters. So a model avic8100-NEX with version pj150plt.prg would be
"AVIC.sh /path_to/MY_FW-update.zip 8100 150"
- The script will tell you where it mounted the image file. Modify it utilizing methods available on xda-developers.com for creating custom ROMs.
- Press any key to continue, and it will repackage the ROM utilizing methods by bass-rock
#! /bin/bash
# AVIC.sh - Unpacks SYSTEM.img from the AVIC firmware for modification, waits for an input, then repackages.
# THIS FILE AND DERRIVITIVE WORKS ARE SUBJECT TO ALL TERMS OF LICENSING BELOW!
# License:
# Term 0: If you modify this file, you must share any changes with the file creators and/or publicly on AVIC411.com
# Term 1: If you find a new use, share changes on AVIC411.com
# Term 2: If it worked say thanks.
# Term 3: IF anyone claims this is black magic, I'm going to flip.
# By bass_rock http://avic411.com/index.php?/user/116652-bass-rock/
# Heavily modified by AdamOutler [email protected]
# http://avic411.com/index.php?/topic/80945-upgrading-nex4000-to-nex4100-work-in-progress/page-19#entry332704
#this function is called when system is not Linux, user is not root, or user did not specify a file
usage() {
echo "usage:"
echo " AVIC.sh /path_to/firmware.zip [AVIC Model] [AVIC firmware version]"
echo "where AVIC Model = 5000, or 8100"
echo "where AVIC firmware version = 140 or 150"
exit
#exit on any error
set -e
#verify system is Linux and user is root and specifed a file
test "$(uname)" = "Linux" || $(echo "this only works on linux" && usage)
test $(id -u) -eq "0" || $(echo "you must run as root" && usage)
test -z "$1" && $(echo "you must specify a file"&& usage)
#set variables for use (default AVIC-5000NEX, Version 140)
AVICZIP="$1"
m=$2
model=${m:="5000"}
v=$3
version=${v:="140"}
#create absolute paths for reference
workdir=$(pwd)"/work"
imageDir="$workdir/AVIC${model}NEX/PLATFORM"
SYSTEMmount="$workdir/AVIC${model}NEX/PLATFORM/SYSTEM"
#set up file and extract properly
mkdir -p $workdir/
unzip -o "$AVICZIP" -d $workdir/
cd "$imageDir"
#remove header from image
dd if=PJ${version}PLT.PRG of=PJ${version}PLT.IMG bs=512 skip=1
dd if=PJ${version}PLT.PRG of=PJ${version}PLT.HEADER bs=512 count=1
#ignore errors while we create a new folder for working with image
set +e
umount "$SYSTEMmount" 2>&1
test -e "$SYSTEMmount" && rm -rf "$SYSTEMmount"
mkdir $SYSTEMmount
set -e
#mount the image
mount PJ${version}PLT.IMG "$SYSTEMmount"
echo "You can now modify the img located in"
echo "$SYSTEMmount"
read -n 1 -p "Press any key to continue" isdone
sync #ensure all changes are written to disk
defaultheader="00010801010000000100000000000000504A313430504C5402100000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF"
#get image size
# for mac
# SIZE="$(stat -f%z PJ${version}PLT.IMG)"
#for linux
SIZE="$(stat -c%s PJ${version}PLT.IMG)"
echo "IMG size is: $SIZE"
#We have to swap the hex values from big endian to little endian cause the NEX is arm.
UNSWAPPEDHEXSIZE="$(printf '%x\n' $SIZE)"
vSIZE="$UNSWAPPEDHEXSIZE"
SWAPPEDHEXSIZE="${vSIZE:6:2}${vSIZE:4:2}${vSIZE:2:2}${vSIZE:0:2}"
UNSWAPPEDHEXCRC="$(crc32 PJ${version}PLT.IMG)"
vCRC="$UNSWAPPEDHEXCRC"
SWAPPEDHEXCRC="${vCRC:6:2}${vCRC:4:2}${vCRC:2:2}${vCRC:0:2}"
echo "Unswapped size hex is: $UNSWAPPEDHEXSIZE"
echo "Swapped size hex is: $SWAPPEDHEXSIZE"
echo "Unswapped crc hex is: $UNSWAPPEDHEXCRC"
echo "Swapped crc hex is: $SWAPPEDHEXCRC"
#create new header
perl -e "print pack 'H*', 'A55A5AA5${SWAPPEDHEXSIZE}${SWAPPEDHEXCRC}${defaultheader}'" > PJ${version}PLT.HEADERNEW
cat PJ${version}PLT.HEADERNEW PJ${version}PLT.IMG > PJ${version}PLT.PRG
rm -rf PJ${version}PLT.IMG
rm -rf PJ${version}PLT.HEADERNEW
defaultheaderver="A55A5AA5C00000000001080101000000010000002C000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF010000000100000050004C004100540046004F0052004D000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000050004A0031003400300050004C0054002E005000520047000000000000000000000000000000000000000000000000000000000000000000"
SIZE="$(stat -c%s PJ${version}PLT.PRG)"
echo "PRG size is: $SIZE"
UNSWAPPEDHEXCRC="$(crc32 PJ${version}PLT.PRG)"
echo "Unswapped prg size hex is: $UNSWAPPEDHEXSIZE"
echo "Swapped prg size hex is: $SWAPPEDHEXSIZE"
echo "Unswapped prg crc hex is: $UNSWAPPEDHEXCRC"
echo "Swapped prg crc hex is: $SWAPPEDHEXCRC"
perl -e "print pack 'H*', '${defaultheaderver}${SWAPPEDHEXSIZE}${SWAPPEDHEXCRC}A55A5AA5'" > PJ${version}PLT.VERSTART
UNSWAPPEDHEXCRC="$(crc32 PJ${version}PLT.VERSTART)"
echo "Unswapped verstart crc hex is: $UNSWAPPEDHEXCRC"
echo "Swapped verstart crc hex is: $SWAPPEDHEXCRC"
perl -e "print pack 'H*', '${SWAPPEDHEXCRC}'" > PJ${version}PLT.VERSTART1
cat PJ${version}PLT.VERSTART PJ${version}PLT.VERSTART1 > PJ${version}PLT.VER
rm -rf PJ${version}PLT.VERSTART
rm -rf PJ${version}PLT.VERSTART1
cd "$workdir"
This script will produce an output like this:
root@adamoutler-desktop:/home/adamoutler/Desktop/pioneer/8053d22493785b92958f# ./AVIC.sh /home/adamoutler/Downloads/15MY_FW-Update_v1.03_16G_20150318\ \(2\).zip 5100 150
Archive: /home/adamoutler/Downloads/15MY_FW-Update_v1.03_16G_20150318 (2).zip
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/BLUETOOTH/PJ150BTHBTL.PRG
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/BLUETOOTH/PJ150BTHSAF.PRG
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/BLUETOOTH/PJ150BTHUDP.PRG
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/BOOT/PJ150BOT.PRG
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/DTV/PJ150DTV.PRG
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/GPS/PJ150GPS.PRG
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/HIBENDIR/HIBENDIR.PRG
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/HIBENDIR.VER
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/PJ150BOT.VER
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/PJ150BT.VER
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/PJ150BTL.VER
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/PJ150DAT.VER
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/PJ150DTV.VER
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/PJ150ERY.VER
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/PJ150GPS.VER
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/PJ150OPN/PJ150OPN.PRG
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/PJ150OPN.VER
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/PJ150PLT.VER
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/PJ150REC.VER
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/PJ150WWR.VER
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/PLATFORM/PJ150PLT.PRG
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/RECOVERY/PJ150REC.PRG
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/RECOVERYEASY/PJ150ERY.PRG
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/SNAPSHOT/SNAPSHOT.PRG
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/SNAPSHOT.VER
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/USERDATA/PJ150DAT.PRG
inflating: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/WWR/PJ150WWR.PRG
1048568+0 records in
1048568+0 records out
536866816 bytes (537 MB) copied, 2.55588 s, 210 MB/s
1+0 records in
1+0 records out
512 bytes (512 copied, 0.192484 s, 2.7 kB/s
umount: /home/adamoutler/Desktop/pioneer/8053d22493785b92958f/work/AVIC5100NEX/PLATFORM/SYSTEM: not found
#########Make your changes at this point before hitting any key#############
IMG size is: 536866816
Unswapped size hex is: 1ffff000
Swapped size hex is: 00f0ff1f
Unswapped crc hex is: 9c1d9cf5
Swapped crc hex is: f59c1d9c
PRG size is: 536867328
Unswapped prg size hex is: 1ffff200
Swapped prg size hex is: 00f2ff1f
Unswapped prg crc hex is: f97384af
Swapped prg crc hex is: af8473f9
Unswapped verstart crc hex is: 86818fcd
Swapped verstart crc hex is: cd8f8186
I'm still testing this and have not yet tried it. I wanted to document my work so as not to hold up progress from interested parties. I won't have time to test today, but this should help any Linux users to get started.
@bass_rock: this is how to launch an app. https://stackoverflow.com/questions/3872063/launch-an-application-from-another-application-on-android. You would create a button, say 200dip above the SET_OFF button. Then you would create an event listener on the button and have it execute the linked code. I'd say it would be useful to have it launch "com.android.launcher", and if that package doesn't work, then it needs to be added to /system/app.
Does anyone have an example of a properly formatted SDCard? I own a very fast web server which I use for ROM image hosting. Without something to work with, it's going to be difficult to get any sort of custom ROM going here. If the size is the barrier, I can help.
