The AVIC Development Mod
By bass_rock · Aug 10, 2015in NEX Series💬 720 posts👁️ 589,887 views
Page 10 of 29
Posted Jan 23, 2016 · 14:20 UTC#226
Everytime i try to generate a testkey i get this message:
If i dont get it i must send it to pioneer and hope that it will not be so expensive to fix it...
Just ask somebody here in topic. For example, ml_homeboy used this key so he know where you can get binary version of this key.
Yes, you can send device to pioneer, but this will waste your money and time. Also you can restore your device just in 15 minutes using existing backup image.
Posted Jan 23, 2016 · 15:30 UTC#227
You guys DEVELOPERS absolutely ROCK!!!
Just finished and I have everything working -- 2015Q3 with all add ons and TMC full working.
Many thanks - you make a great job.
I will upload my backup if that will help in further development.
Right now I just wait for possibility to install android apps on my avic :)
BTW - should I disable AVICSYNC connection? Or at least should I log out of my naviextras account in the app?
Posted Jan 23, 2016 · 16:31 UTC#228
theres nothing in the updates directory. is it supposed to be like that? im missing a ton of stuff
Posted Jan 23, 2016 · 18:18 UTC#229
Can someone please give me a clean backup image from the AVIC-F70DAB EU? I have no luck with installing the NEX-8100 image.
I have a testmode_n #2
But it always says Fail to get information of main storage please turn the power off so i think it is the imagefile...
Thank you for the help.
Posted Jan 23, 2016 · 18:25 UTC#230
Now I'm just a little confused, so hopefully someone can clear out things for me. :-P
Which script must I use for my AVIC-F77DAB, to do a map-upgrade?
Can I make a backup of my system to USB og SD-card, before doing anything else?
How to restore, if things go wrong?
And after that, copy system to USB and copy new maps and licens to USB and then copy back to system?
Where can I find correct maps for Europe and license? Would appriciate direct links:-)
Can I use same maps and license for the Avisync-app on my Galaxy S4?
Which capacity must USB/SD-card have?
Posted Jan 23, 2016 · 19:42 UTC#231
1. Apply this patch
2. Use this scripts to copy directory of iGO navigation software to your usb stick. Then modify this directory on your PC/Mac, add needed maps, licenses and other content. Then copy this modified iGo directory back to device.
https://www.google.com/?q=igo+maps+europe
Yes.
=> 4GB for european maps.
Edited Jan 23, 2016 by WhatIsWhatIsWhatIsWhat
Posted Jan 23, 2016 · 20:47 UTC#232
Thank you WhatIs.. for your help. I have downloaded must of the stuff incl. IGO-R3_HERE(Navteq)_2015_Q3_EUROPE maps, which I hope can be used?
I'm not quite sure which license to use. Is there a specifik name for the license file to look for?
Posted Jan 23, 2016 · 23:13 UTC#233
What I discovered after update
- Maps and TMC works fine
- petrol.3dl files somehow don't appear. I mean still I have flat 2D points on map and only few petrol stations logos are supported ( for example BP is but Shell isn't)
I suppose it has something to do with branding.zip file but I didn;t try it. I don't know how much can we change inside program since it is.
That would be nice to upload our own poi icons from POI PLAZA for example but will our IGO accept it?
- speedcameras work perfectly
- phoneme files I don;t recommend. After installation it destroyed my TTS street pronounciation - when I deleted this folder and files everything returned to normal.
Posted Jan 23, 2016 · 23:43 UTC#234
I think that Kura can help you with licenses and other European content. He just installed latest available European maps
Posted Jan 24, 2016 · 13:33 UTC#235
can someone just hook me up with all the work done for a 8100 with maps and poi for europe, especially germany, france, belgium, italy, switzerland, czech, austria, netherlands? i dont have time to try to figure this out. i will gladly pay for it, paypal ready to go. seriously, my schedule is totally loaded and i need this done. its hard to justify the 8100 price tag when i have a blank gps to stare at while here in germany
Posted Jan 24, 2016 · 16:26 UTC#236
Stupid question I know but instead of USB1 can I use a properly formatted SD card? Kinda a PITA to remove my HU...thanks
Posted Jan 24, 2016 · 16:51 UTC#237
Device searching for testmode keys in three places: external sd card, usb1, usb2. So you can use fat32-formatted sd-card if you device comes with sd-card slot.
Posted Jan 24, 2016 · 16:54 UTC#238
Thanks to some people here. My headunit is back again. I am so happy :mrgreen: :mrgreen: :mrgreen:.
Best worldwide community here ;)
Posted Jan 24, 2016 · 17:39 UTC#239
When I unpack manual_map_update_for_AVICx60x70.zip there is a root file with a lot of funny characters
The name of the file is: Ã‰Ã’þ¡«Ñ «í¡«ó½Ñ¡¿Ã‘ ¬«¡ÔÑ¡Ôá.txt and inside the file the text is something like this:
Ãåðåä èñïîëüçîâàíèåì îáíîâëåíèÿ íóæíî ïðèìåíèòü patch äëÿ iGO
Ñîäåðæàíèå àðõèâà:
1. AVICtoUSB - ñêðèïò äëÿ êîïèðîâàíèÿ c AVIC íà USB
2. USBtoAVIC - ñêðèïò äëÿ êîïèðîâàíèÿ ñ USB íà AVCI
Ãðîöåäóðà ñîñòîèò èç 3õ ýòàïîâ.
Äëÿ äàííîé ïðîöåäóðû ïîòðåáóåòñÿ USB äèñê íå ìåíåå 4Gb â FAT32
1. Êîïèðîâàíèå ïàïêè iGO c AVIC íà USB
2. Îáíîâëåíèå ôàéëîâ íà USB äèñêå
3. Êîïèðîâàíèå ïàïêè iGO c USB íà AVIC
Is it supposed to look like this?
Edited Jan 24, 2016 by kgse
Posted Jan 24, 2016 · 18:38 UTC#240
Glad to here!
Posted Jan 25, 2016 · 00:40 UTC#241
seriously, willing to pay someone to put it all together for me so all i need to do is put it on a sd card or usb and do the rest.
Posted Jan 25, 2016 · 16:14 UTC#242
1. Apply this patch
Could do with a litlle more help.
Applied the patch and everything seemed to go all right. By the way, when in testmode, how do I end testmode and go back to normal radio-use?
Should I unpack the scrip to same USB-stick where the patch is on or should I unzip just the "AVIC to USB folder" to a new empty USB-stick. I think I have tried both options, but nothing seems to work. So would appreciate a little help here.
If I finally succeds in getting the script to work, will it then copy to USB2 or...?
Posted Jan 25, 2016 · 16:53 UTC#243
ml_homeboy, kgse - have you read your private messages?
Posted Jan 25, 2016 · 20:16 UTC#244
If soemeone would be so nice. I have no backup of my extdata/igo folder. Can someone make a backup 8100NEX or F70DAB please.
Thank you.
Everything is ok again thanks to the help of  WhatIsWhatIsWhatIsWhat
Greetings.
Edited Jan 26, 2016 by JhonnyB
Posted Jan 27, 2016 · 03:24 UTC#245
First off I want to thank all who contributed to this thread. I got the HERE_2015.Q2 loaded on a 6100.
The maps work.
The only issue w the ones below give a "partially incompatible" message:
North_America_HERE_Easy_2015.Q2_150925 / North_America_HERE_Economical_2015.Q2_150925
North_America_HERE_Fast_2015.Q2_150925
North_America_HERE_Green_2015.Q2_150925
North_America_HERE_Short_2015.Q2_150925
Anyone get this & have a fix?
Posted Jan 27, 2016 · 03:31 UTC#246
Can someone PM me the test mode file? I am a Pioneer dealer and I would like to help a customer get their password on the 4100. I've done the old avic 750/850 before.
Can I just load on an SD card, boot, get in view and get out like the old units? Do I have to do on a flash drive?
Would you mind walking me through the password part. I've read this and I'm a little thrown about writing stuff down because it clears ect. Just would like to get in, see the password and get out if it's as easy as the old ones.
Thanks,
Chris @ Car Toys
Posted Jan 27, 2016 · 17:25 UTC#247
I have test mode on a usb, and can see the options on boot up. Can someone lead me through the steps to see the password please.
Chris
Posted Jan 27, 2016 · 18:26 UTC#248
Chris
yo, dat password is in da BSP yo. You can use the Customize BSP job o'er at C-Dev. https://jenkins.casual-dev.com/job/Customize%20BSP/build?delay=0sec
To remove the password, use test key 3. It's a bit tricky tho. Yous best burn a new SD from one of the images floating 'round, yo.
Posted Jan 27, 2016 · 18:45 UTC#249
There's a guy on here an multiple on ebay selling a simple fix for password lock out. I believe its test mode... there must be a simple walk through step by step that hes selling.
Posted Jan 27, 2016 · 19:25 UTC#250
Yo, m3_chris is talking about user-defined password to lock device startup after power loss, yo.
Yo, user-defined password is not the same thing as SD card lock password (stored in BSP), used to protect sd card contents, yo.
Edited Jan 27, 2016 by WhatIsWhatIsWhatIsWhat
Page 10 of 29
