The AVIC Development Mod
By bass_rock · Aug 10, 2015in NEX Series💬 720 posts👁️ 589,887 views
Page 12 of 29
Posted Jan 31, 2016 · 16:39 UTC#276
It don't need to be created. A mod just needs to figure out what derailed this topic and split it into a new thread. The how-to would be a great place to split.
Posted Jan 31, 2016 · 16:42 UTC#277
In this case nobody will maintain first post of topic with actual information.
Posted Feb 01, 2016 · 22:01 UTC#278
Hi All,
I've installed a new set of maps and licence using the USB-Avic script - all has gone well except that I now get an error message "Out of Memory" when iGo launches. Please see screen shot attached.... :(  any help, guidance or assistance would be very much appreciated...
Hi all and congratulations for all the work you do.
I wanted to update the European maps but I also have an error "out of memory". Blob8me, have you solved this problem? I reinstalling the 1.11 firmware so that IGO running. Thanks
Posted Feb 02, 2016 · 11:24 UTC#279
Just copy only the correct license file, not a lot of lincese, because the try to load a lot of maps, building etc...
Posted Feb 02, 2016 · 20:35 UTC#280
Has anyone been able to get traffic to work? After uploading the maps and licence files and the tmc files to the unit I was able to get the 2015q2 map and safety camera to work. But traffic is no go.
This is on the 5000nex
Edited Feb 03, 2016 by alex9025
Posted Feb 03, 2016 · 05:40 UTC#281
Now, you can put any content on the device for which you have a working license.
After installing the patch, your maps software will take any content with any valid license for that content.
Even if the license from another device (check of license hardware id (SWID) is disabled in our libraries).
Hi asd255 and Team.
I have everything set on my 8100NEX and have been trying to transfer the files for Middle East maps on and off for a few days now. I have a problem with the license though where my unit just restarts when I try to start the navigation option and have already tried a few different options to fix but not having any joy at the moment.
The files that I have are for:
Middle_East_HERE_2015.Q2
with licence:
Gulf_countries_NQ_Saudi_Arabia_United_Arab_Emirates_Qatar_Oman_Bahrein_Kuwait_Primo_2015_Q2.lic
Can someone please help and explain if there is anything else that I'm missing and what does the "blue" text that I have highlighted in the original post mean - about checking if the SWID is dissabled???
As usual - any help would be appreciated.
Posted Feb 03, 2016 · 05:42 UTC#282
Hi...
Yes. Deleting the various licences that I didn't need anymore helped. I have a slightly different problem now though...   :|
Posted Feb 03, 2016 · 21:11 UTC#283
Hi asd255 and Team.
with licence:
Delete all LIC files from your licences folder. Only LYC files are accepted by IGO NEXTGEN.
Posted Feb 04, 2016 · 06:20 UTC#284
Hello,
While exploring testmode on my SPH-DA120 and trying different keys I got the following results;
TESTMODE_A.KEY            The unit recognized and read the USB drive but the testmode failed to called up any menu.
TESTMODE_N.KEY (3)        Number 3 key was successful  with "OK" message and instructing to turn off the unit.
TESTMODE_N.KEY (1)        The unit booted up, it called up a menu but it went directly to the "Write Program Forcedlly" menu. From Here
                                             the the soft buttons do not work and I'm not able to navigate or select anything.
I powered down the unit and tried again testmode_a / tesmode_n_1 / testmode_n_2 and last testmode_n_3 and still get the "Write Program Forcedlly" menu with no way of navigating or selecting anything.
Any guidance on where to go next from here, what to try or what went wrong is greatly appreciated.
Edited Feb 04, 2016 by jorgegc73
Posted Feb 04, 2016 · 07:36 UTC#285
Welcome to the club!. Never try testmode keys or settings the purpose of which you don't know :)
You can unbrick your device using USB-UART adapter. But before doing this try to write firmware as device wants, maybe device will switch mode after flashing firmware.
Posted Feb 04, 2016 · 11:51 UTC#286
OK... Thanks.
So now I need a set of maps with a license (in .lyc format) for the Middle East. Can anyone help out or direct me to somewhere or someone that can?
Thanks again.
Posted Feb 04, 2016 · 11:57 UTC#287
Have you tried to google this info? and also this
Edited Feb 04, 2016 by WhatIsWhatIsWhatIsWhat
Posted Feb 04, 2016 · 12:08 UTC#288
Of course... :|  but with no luck so far. My original maps together with the .lic file are there but nothing that I can find with an .lyc license....
Posted Feb 06, 2016 · 16:36 UTC#289
Install ®Market Helper & enjoy any navigation program.. ;-)
Could you please provide more details?
Posted Feb 06, 2016 · 16:51 UTC#290
What I discovered after update
- Maps and TMC works fine
- petrol.3dl files somehow don't appear. I mean still I have flat 2D points on map and only few petrol stations logos are supported ( for example BP is but Shell isn't)
I suppose it has something to do with branding.zip file but I didn;t try it. I don't know how much can we change inside program since it is.
That would be nice to upload our own poi icons from POI PLAZA for example but will our IGO accept it?
- speedcameras work perfectly
- phoneme files I don;t recommend. After installation it destroyed my TTS street pronounciation - when I deleted this folder and files everything returned to normal.
Where is branding.zip file located? I can look into this. I did some of my own modifications to iGO 8 in the past.
Posted Feb 06, 2016 · 17:22 UTC#291
extdata\iGO\content\global_cfg\global_cfg.zip
Edited Feb 06, 2016 by asd255
Posted Feb 06, 2016 · 21:29 UTC#292
How can i use themes with my f70dab?
Thank you
Posted Feb 07, 2016 · 01:01 UTC#293
Thanks! Certainly :smile:.
I loaded a USB with firmware, but no luck.  I get the same sequence;  Custom boot screen, Pioneer loading splash screen then the "Write Program Forcedlly" menu with no response from soft buttons so navigation through menu is not possible. I'm trying to understand the USB-UART method, is this similar to the factory USB cable when restoring Android devices?  Any links to literature on the subject would be helpful. I may not be looking properly for  information on the subject, for some reason I only find non related articles on UART.
Thanks again.
Posted Feb 07, 2016 · 06:38 UTC#294
Hi all. I have an Avic f960dab in Australia and am trying to:
edit the existing poi file
remove nav nag screen
Is it possible to load Garmin maps instead of using igo?
what other benefits/options are available to me for this avic unit
I've spent some time reading most of the posts in this area. While computer literate most of what I'm reading is confusing to me. I understand branding.zip will allow me to add / replace icons? I can't see where this file is made available.
Impressed with this community, sorry if i'm in the wrong area. I am willing to contribute should the need arise.
Posted Feb 07, 2016 · 23:19 UTC#295
you have a backup of your device?
Posted Feb 08, 2016 · 02:46 UTC#296
Only the thumb drive which is updated through Naviextras and then synced to HU
Posted Feb 08, 2016 · 03:46 UTC#297
which version of the maps you now?
Posted Feb 08, 2016 · 05:21 UTC#298
2014 Q2
Posted Feb 09, 2016 · 18:34 UTC#299
Are we able to use Android Auto on the AVIC-5100NEX now? It was the one unit that for whatever reason Pioneer chose not to support it on.
Posted Feb 09, 2016 · 18:36 UTC#300
No you can't that is actually a limitation from Google. unlike CarPlay Google has restrictions on the screen size that Android Auto is supported on which is why it is not on the AppRadio 4 too.
Page 12 of 29
