That's a shame I found a pair of them brand new in the box at a wholesaler of mine for $200 each. I really want the ability to use Android Auto though.
The AVIC Development Mod
anyone tried to write a clean NEX8100 img inside a sd card and put in another Pioneer HU like Nex5100 ou Nex5000? If this works, we can enable Android Auto in this units?
Hmmm, I don't know but I thought I read that Bluetooth does not work if you do that. (at least when flashing the AVIC-8000NEX with the AVIC-8100NEX image)
After reading about bushing's passing I recalled the fail0verflow blogpost he wrote some time ago, which in turn prompted me to see if anything happened over here. Very nice to see so much progress! As I understand it, right now the biggest issue is in recreating a new lineo warp image with modified firmware contents? Is there any progress on that? Can I offer any help in testing (I don't mind the HU being on the bench for a while).
Hello, and thank you for help on updating maps, I'm now in 2015.Q3.
Today, I would like to set the speedcam for France. I have the file France2015q3.spc but when I put it in the Speedcam folder, nothing appears on the map while for Belgium it works. The file is good, it works on IGO 9.6 on Android. I can't find sys.txt file for editing. Could you help me?
I need them for Germany but there are no
how can i install new maps and speed camera on my new AVIC-F70DAB... can anyone help me with that...
thanks
thanks
Not sure if this is good in your country, but , www.naviextras.com
U are joking right??? This site for mod, so not to pay and u are sending me to pay for maps and speed camera
thanks
Hi,
first you have to look at page 10 where you can find a tutorial to enter the filesystem form your unit.
Then you can copy your e.g SpeedcamUpdates.spd from Poibase into the folder speedcam from your unit.
Enjoy !
hello all map morroco for pioneer avic-f960bt plz
I believe that mode actually does the reverse of what you were trying to accomplish. I recommend opening up your unit and replacing the internal SD Card with a new one that has the appropriate image.
is there any instruction guide to show how to open the unit to have access to internal SD card without breaking them?
is there anyone can share clean img for NEX4000?
i brick my nex4000 during the 1.08 -> 1.10 firmware update.
now all i c is display with software error msg.
how can i review the speedcams of switzerland and france on the map of my avic-f70dab ?
In all other european countries the speedcams are visible.
Can u tel me how did u manage the speed cams on your unit??? Did u buy them or add from here?? Thankshow can i review the speedcams of switzerland and france on the map of my avic-f70dab ?
Btw I have also 70DAB PLEASE some help, thanks........
Look at my post from 20. February.
The best database of speedcams you can find at Poibase.com but you have to pay.
do you have a picture of the speed cam on your unit to compare it with mine? thanks
im sorry dude, maybe im still doing something wrong... i have follow page 10 and i have copy speedcamupdate.spd to a usb, just copied. when i connect the usb in the unit and start syncTool, my usb get re-build and nothing happend, the speedcam folder is gone. what do you think?
thanks
thanks
You should not start synctool after connection with your usb-stick.
After starting your unit you must connect your usb-stick which you did prepare as it was described on page 10 from ASD255 to USB1 from your unit,
After a short time your unit will reboot into the testmode.
At the menu point File Maintenance you can enter the Filesystem and navigate to the folder speedcam from linuxroot to copy the SpeedcamUpdates.spd into this folder.
The filename must be exactly written as i did it.
After this you have to disconnect your stick and reboot your unit.
Caution, do not erase anything to prevent a brick of your unit.
If you are not strong in managing filesystems let do this better by an IT-specialist.
If one buy this SpeedcamUpdates.spd is it possible to take it for more than one hu?
thanks, im a IT specialist, maybe i missed to copy the file spd into the usb before the testmode.
so for me and for everyone.
1 copy the files to USB (done)
2 test mode (done)
3 remove the usb copy the spd file in it from the laptop (not done yet)
4 connect the usb again in the unit (not done yet)
5 navigate to spd on the usb and copy it in to the unit (not done yet)
right?
maybe an idea to make screenshots walkthrought ???
thanks again
I have buyed DACH and copied it with testmodekey. now it is working. thank you @Bernd25
Danke sehr für den Tip ![]()
has anyone a solution for the blocked speedcams of switzerland and france ?
Did u try poiplaza???
