The AVIC Development Mod
By bass_rock · Aug 10, 2015in NEX Series💬 720 posts👁️ 589,887 views
Page 14 of 29
Posted Feb 29, 2016 · 08:16 UTC#326
You should not start synctool after connection with your usb-stick.
After starting your unit you must connect your usb-stick which you did prepare as it was described on page 10 from ASD255 to USB1 from your unit,
After a short time your unit will reboot into the testmode.
At the menu point File Maintenance  you can enter the Filesystem and navigate to the folder speedcam from linuxroot to copy the SpeedcamUpdates.spd into this folder.
The filename must be exactly written as i did it.
After this you have to disconnect your stick and reboot your unit.
Caution, do not erase anything  to prevent a brick of your unit.
If you are not strong in managing filesystems let do this better by an IT-specialist.
Hi Bernd,
i found in speedcam folder(unit) a spud file, should i leave it or remove it?
thanks
Posted Feb 29, 2016 · 09:29 UTC#327
Look at my post from 20. February.
The best database of speedcams you can find at Poibase.com but you have to pay.
oke, its working....
thanks for your help again
Edited Feb 29, 2016 by Tarecco
Posted Feb 29, 2016 · 14:44 UTC#329
If one buy this SpeedcamUpdates.spd is it possible to take it for more than one hu?
yes
Posted Feb 29, 2016 · 21:17 UTC#330
yes
what yes !? :lol: :lol: :lol:
show the working  speedcams in the USA! :wink:
Edited Feb 29, 2016 by Lucca
Posted Mar 02, 2016 · 14:42 UTC#331
cn i update my navigation with the map Q3 using naviextra without loosing the mod files?
Posted Mar 04, 2016 · 17:01 UTC#332
i didn't understand how to build a script in windows 8, in order to install igo and map at once
Posted Mar 05, 2016 · 08:13 UTC#333
You don't need to make a script, the script is on page 10 check your unit and the script.
Edited Mar 05, 2016 by Tarecco
Posted Mar 05, 2016 · 11:36 UTC#334
isn't it onòy for patch the navi? i want to copy also maps and speedcams
Posted Mar 05, 2016 · 13:05 UTC#335
Which unit do u have?? Maps u can't find at gpspower site. And speedcam here, it should be speedcam.sdb
Posted Mar 05, 2016 · 15:09 UTC#336
i have f970dab. I know where find maps and add ons, but i do not know how to transfer to the device, while applying the patch. Maybe i know also how to run the copy script file, but not how to tranfer everything all at once (only the patch).
Posted Mar 05, 2016 · 17:08 UTC#337
Oh oke,
1st copy the script and the file that u want copy in your unit into sd card or usb.
2de connect SD/USB in to your unit.
3rd start your unit.. Between 20 a 30 sec, your unit will restart to DOS(ish) screen. With your volumes and prev and rew buttons, u can navigate the settings.
4th navigate to file maintenance and select the your SD or usb... Use your buttons for copy and paste...
Posted Mar 05, 2016 · 17:39 UTC#338
i will try, thank you! will old map be uninstalled? Because two maps are too large.  So you mean: i transfer the content of modded igo zip file into usb, than i copy also map, and then i connect usb running copy? In addition, can i use the same copy scipt any time i want to insert a content? or is it related only to the content of original file?
Edited Mar 05, 2016 by kimikale
Posted Mar 05, 2016 · 21:30 UTC#339
Anytime, u can see the usb as Windows boot cd... About the maps I don't know...
Posted Mar 07, 2016 · 16:23 UTC#340
This may be a long shot but I'm going to try. I updated my 7000nex to 1.11. Everything seemed to be working until I went to use nav. The nav looks like it is loading then the screen goes back to the main menu. I contacted Poineer and they said the only way to fix is to send it to them. That is crazy! Pay to have it taken out, shipped, fixed, shipped back, and then reinstalled! I have been reading through this thread and it seems like you guys might be able to help me. I'm not looking to change anything, I just want my nav back.
Side note: I did try to go back to 1.10 to no avail
Posted Mar 08, 2016 · 18:51 UTC#341
What is the meaning of the capital letter "R" behind the filename after copying this file.
How can i set the rights of copied files on the unit ?
Posted Mar 14, 2016 · 00:13 UTC#342
are there any options to side load apps without disabling warp. Apps like kodi or even safari on the unit. ( NEX 8100)
Posted Mar 15, 2016 · 01:44 UTC#343
Thats the holy grail.....doesn't appear to be yet.
Posted Mar 15, 2016 · 15:58 UTC#344
can someone hook me up with a ready to go zip file or somethig that i an put on an sd card? i need to get europe maps including germany but dont have the time to do all the sorting through the websites looking for the maps, pois and licenses and stuff. i am more than willing to pay for it
Posted Mar 16, 2016 · 16:59 UTC#345
Any news about working modded avicsync app?
Posted Mar 16, 2016 · 18:33 UTC#346
With all the time you have spent asking this same question you would have had it done by now.
Posted Mar 16, 2016 · 19:52 UTC#347
Please delete.
Edited Mar 17, 2016 by consequential
Posted Mar 16, 2016 · 21:07 UTC#348
Hi all,
I've read through so many threads on this stuff but am really confused.
Does someone have the 8100NEX and successfully got the USA/Canada Q3 update installed?
If so could you please PM me how exactly you did it?
I have the following:
1. MapPackage
2. x100_1.05_9.18.28.610130
3. A whole bunch of USA/Canada Q3 content and a bunch of licenses
4. I've have the following folder structure:
MapPackage-->Updates-->Content-->
-building
-fjw
-fpa
-ftr
-map
-poi
I'm not sure what else I need and I'm not sure I have all of the required licenses...
MapPackage-->Updates-->License-->
What exact licenses should I have?
I'm stuck from here and don't know if I have all of what I'm supposed to have and if it's all in the right place for that matter
I'd appreciate
Take the x100_1.05_9.18.28.610130 folder and put your Update file with the content folder with the diff folders( Put the Lic folder at same level as content.) on the usb key in usb1.  The test key in the patch script(no need to apply the patch again) will get you in, then dig down file maint/root/exdata/igo. I copied my content and lic file off the unit to the usb1. Then I deleted them off the unit. Then I copied the Q3 content and lic file from the usb1 to the unit.
Posted Mar 18, 2016 · 16:47 UTC#349
Hello all!!  Just stumbled into this forum, and I must say, awesome work!!!!!
I have been thinking about pulling the trigger on buying the NEX8100. Now that 8200 came out, the gauges are of interest to me, would I be able to view A/C temperature and settings? Will the 8100 be able to run the new features the 8200 brought?
Posted Mar 22, 2016 · 01:11 UTC#350
i feel stupid because i had no issues with my f90bt and updted it into the next gen software, plus added maps for europe and all that. im stumbling with this one. how do you get into testmode?
Page 14 of 29
